et lite problem med kontakt skjema...
mailen blir send til meg men samtidig så får jeg denne feilkoden:
"Warning: OpenDir: No such file or directory (errno 2) in /mnt/home4/y/ym/ymerx/public_html/ramailv2/ramail.php on line 40
Warning: Supplied argument is not a valid Directory resource in /mnt/home4/y/ym/ymerx/public_html/ramailv2/ramail.php on line 41
Warning: Wrong datatype in sort() call in /mnt/home4/y/ym/ymerx/public_html/ramailv2/ramail.php on line 42
Warning: The argument needs to be an array in /mnt/home4/y/ym/ymerx/public_html/ramailv2/ramail.php on line 43
Warning: fopen(".ramailv2/logg/041092148.txt", "w") - No such file or directory in /mnt/home4/y/ym/ymerx/public_html/ramailv2/ramail.php on line 56
Warning: Supplied argument is not a valid File-Handle resource in /mnt/home4/y/ym/ymerx/public_html/ramailv2/ramail.php on line 57
Warning: Supplied argument is not a valid File-Handle resource in /mnt/home4/y/ym/ymerx/public_html/ramailv2/ramail.php on line 58
Warning: file(".ramailv2/logg/041092148.txt") - No such file or directory in /mnt/home4/y/ym/ymerx/public_html/ramailv2/ramail.php on line 61
Warning: Wrong datatype for second argument in call to in_array in /mnt/home4/y/ym/ymerx/public_html/ramailv2/ramail.php on line 63
Warning: fopen(".ramailv2/logg/041092148.txt", "a+") - No such file or directory in /mnt/home4/y/ym/ymerx/public_html/ramailv2/ramail.php on line 140
Warning: Supplied argument is not a valid File-Handle resource in /mnt/home4/y/ym/ymerx/public_html/ramailv2/ramail.php on line 141
Warning: Supplied argument is not a valid File-Handle resource in /mnt/home4/y/ym/ymerx/public_html/ramailv2/ramail.php on line 142"
noen som vet hva jeg har gjort feil?
håper noen vet, vil så gjærne får ordnet på dette :roll:
Edit: Siden er http://remynet.tk gå på "kontakt meg" også sender du skjema, så kommer dette opp...
Endret av remy5
takker skal se igjennom en gang til ;)
Edit: $FormPage: Path til skjemasiden (form.php).
hva mener dem med det? skal jeg skrive inn path til: http://remynet.tk/kontaktmeg.php eller hva? :-s
Edit2: /* Brukeravhengig informasjon */
$YourEmail = "[email protected]";
$FormPage = "http://home.no.net/ymerx/ramailv2/form.php";
$LogDir = ".ramailv2/logg";
$MaxLenSubject = 30;
$MaxLenName = 30;
$MaxLenEmail = 30;
$MaxLenHomepage = 50;
$MaxLenMessage = 2000;
$MaxLenWordMessage = 30;
det er i ramail.php feil ligger ser det ut som, men spør dere meg ser alt riktig ut.
Endret av remy5
ellers skjer det noe kult om du trykker på kontakt i den horisontale menyen..
hva mente du med dette? :hmm:
Edit: skjønnte hva du mente det er fordi jeg ikke har ordna på alle linkene enda, det er "kontakt meg" på menyen til venstre som virker dem som ligger på toppen av siden er ikke satt ibruk enda ;)
starta med hjemmesiden for ikke så lenge siden derfor.
Endret av remy5
