colinux
Fra Wikien deres:
" * Q4. Why doesn't my X server work under coLinux?
coLinux currently doesn't support running an X server that requires a graphic adapter, because such virtual adapter doesn't exist at the moment. If you want to use X, you can run a Windows X server such as Cygwin/X, and launch an X session across the virtual network.
Bart Kerver took Cygwin/X and made a package untied from the Cygwin installer: http://speeldoos.showcase.surfnet.nl/startx.zip
You can find lots more information on using X with coLinux here"
http://www.colinux.org/wiki/index.php/XCoLinux
Endret av moyner
