Robin B Skrevet 16. april 2004 Del Skrevet 16. april 2004 (endret) Får vel ta det med en klype salt. http://www.theinquirer.net/?article=15377 EVEN THOUGH ATI doesn't want us in Canada without signing one of its famous NDAs, we always have our ways of getting information about its future plans. Back at CeBIT we heard that new chip will be called X800 but simply could not confirm it at that time and we also heard that this chip will be introduced at System Builder Summit. The date that is apparently being suggested is the 5th of May, and it could be that ATI will launch this chip during the SBS event. Sources close to ATI claim that it can actually ship this card at the same day of launch and we know that there are quite some samples ready as we speak. As for the specs, the R420PRO or should we call it X800PRO will be clocked at 475 MHz, 25 MHZ higher then we suggested since yields are better, while the memory will be clocked at 900MHz as we suggested before. Everything is packed into 180 millions of transistors and the card has 12 pipelines as we suggested. The R420XT, Radeon X800XT will be higher clocked card with 16 pipelines which came as a huge surprise to us. This card is meant to fight Geforce 6800 non Ultra - the one with 12 pipelines and should be in retail as soon as ATI launches it. This means that you should be able to buy one on the 4th of May but let's wait and see if ATI can deliver on that day. Faster Radeon X800XT will come just after E3, and soon after the 14th of May we are told. I cannot remember if I said this before, but the R420 is chip based on R300 marchitecture and you can clearly see this from its 96 bit precision support and lack of PS 3.0. Performance wise it will give NV40 a good run for its money. µ Endret 16. april 2004 av Robin B Lenke til kommentar
TDK Skrevet 16. april 2004 Del Skrevet 16. april 2004 Spennende! Selv om jeg ikke skal kjøpe hverken det eller 6800ultra..... Lenke til kommentar
lizon Skrevet 16. april 2004 Del Skrevet 16. april 2004 skal ha det selv, hvis jeg har rå da. Lenke til kommentar
