shamanix Skrevet 15. april 2004 Del Skrevet 15. april 2004 Jeg har brukt Azureus de 2 siste månedene, det har funka fint intil for 1 uke siden, da har den downloaded sakte hele tiden. Hver fil ligger på 0-5kb/sec... Jeg har åpnet port 6881, så det er ikke der probøemet ligger. Vet noen hva som er galt? Lenke til kommentar
shamanix Skrevet 15. april 2004 Forfatter Del Skrevet 15. april 2004 Det funka bedre for meg etter at jeg skrudde på "LMHOSTS lookup". properties på: Local Area Connection -> properties på internet protocol -> advanced -> WINS si fra hvis det funker for andre. Lenke til kommentar
Baldiman Skrevet 15. april 2004 Del Skrevet 15. april 2004 Fant dette på torrentbits forumet ------------------------------------ Important tracker changes!!!! We have modified the tracker to treat anyone connecting with certain ports (see below) as if they are unconnectable. This is because many ISPs (including mine, which I learned earlier today) throttles the speed on these ports. The following commonly throttled ports are now blocked by the tracker... 411 through 413 - Direct Connect 1214 - Kazaa 4662 - eMule/eDonkey 6346 through 6347 - Gnutella 6881 through 6889 - BitTorrent Please make sure not to choose port(s) in these ranges!. If you do, the tracker will consider you "unconnectable" and your download speed will suffer. BTW, if anyone knows other ports of interest, please PM Redbeard. A "Mini-FAQ" (stolen from a post written by wyz): How large should my range be? It depends... If you use a single-port client (like Azureus) your range should consist of a single port. Pick up any from 49152-65535. If you use a multi-port client (like original, Shad0ws's, ABC, Burst, Experimental, UPnP, ...) think of the maximum number of torrents you will ever have open at the same time. That's how many ports you need. If you want at most 6 simultaneous torrents, choose any number x in 49152-65535 and use the range x to x + 5. (e.g. 50500 to 50505. Pick your own numbers, do not use these.) Will I be able to connect to peers that are still using the standard ports? Yes. Will my client still work with other trackers? Yes. Why don't you tell us what ports to choose? Because the more random the choice is the harder it will be for ISPs to catch up to us and start limiting speeds on the ports we use. If we define another range ISPs will just start throtlling that range. How do I change the ports in my client? Most of them have an advanced option that allows you to specify the range. Those of you running the original client may want to look at http://dessent.net/btfaq/#wincmdline and http://dessent.net/btfaq/cmdline.shtml (There are also good posts on this above.) I changed the ports and now my speed is lower!? Give the torrent some time, and make sure you also changed your router and/or firewall configuration (if you have them). If the problems persists, try some other range. Last, a section copied from the FAQ You must start by configuring your client to use any port range other than those listed above. (Any other range in the ephemeral region, i.e. 1024 through 65535, will do, but the region 49152 through 65535 is preferable). Notice that some clients, like Azureus, use a single port for all torrents, others use one port per open torrent. The size of the range you choose should take this into account. (These ports are used for connections between peers, not client-tracker. This change will not interfere with your ability to use other trackers. If your client does not allow custom ports to be used, change to one that does.) Last edited by Redbeard at 2004-04-15 13:15:03 GMT Lenke til kommentar
