Opera 7.5 P4 er ute!
dan1el
Dette er en hellig dag.
http://my.opera.com/forums/showthread.php?...2639#post512639
Ladies and gentlemen, you're witnessing history. With this release, Opera Software marks the first time in its history that updates for all our desktop platforms based on the same code have been released simultaneously.
Opera 7.50 Preview 4 for Windows is available for download. As usual, discuss the new version in opera.beta and in the my.opera.com Beta Testing forum. Please do not distribute the download link directly, but link to the post in opera.beta or in the my.opera.com Beta Testing forum.
Due to the experimental nature of this release, upgrading a previous Opera installation is not recommended. If you'd like to test your mail from 7.23 in this release, delete the \Opera\Mail\ folder, then copy your entire Mail folder from 7.23 to your 7.50 Preview 4 installation.
Download Preview 4:
http://snapshot.opera.com/windows/o750p4_3714.exe (build 3714)
=== Major Changes ===
* Continued User Interface Experimentation*
In our efforts to improve the user interface, there have been a couple more changes in this preview. The Personal bar has been reenabled by default, the Start panel has been replaced by a Search panel, and maximized panels and manage dialogs have been dropped in favor of manage pages/windows. There's also a new <q>New page</q> button on the Page bar that makes it easy to open a new page.
*Improved Opera Mail Resource Usage *
Opera Mail (the mail client formerly known as M2) has received lots of attention this time around. It should use less memory, require less time to start-up, and clean-up after itself better.
* Optimized Performance *
In our on-going effort to be "The fastest browser in the world," this release should start-up and exit faster. Doing routine user interface actions like toggling and resizing panels should also be faster.
A detailed list of changes is available at http://snapshot.opera.com/windows/w750p4.html#detail.
genialt!!
var veldig skeptisk de første 5 minuttene... før jeg hadde skjønt hvordan og fått konfigurert menyene...
men den er rett og slett GENIAL! mye raskere enn den gamle! Slet litt med at opera 7.23 frøs totalt når den ventet på data (f.eks en proxy som slet litt), men dette er ut til å være en saga blott nå...
Har bare testa i ca 15min enda :p men ser bra ut hittil!
edit:
:scared: de har fjerna keyboard shortcut'en for transfer vinduet :(
... kan sikkert fixes manuellt :p
Endret av DJ-JK
vell... det er jo en preview da :p
edit: bruker kanskje litt mye minne? min ligger på ca 45mb uten noen vinduer åpne. Husker ikke hvor mye den gamle brukte. Jeg gjorde den i-utgangspunktet-ikke-så-lure-tingen å installere den over den gamle, men har ikke hatt prob. enda ... enda vel og merke :p
Endret av DJ-JK
Du kan begrense hvor mye minne Opera skal bruke om du vil. Desuten så tar Opera så mye minne den trenger, og hvis andre programmer trenger minne frigjør Opera minne.
og det går ikke lengre an å dra et bilde litt til siden for å åpne det seperat.
Det vil være mulig i fremtiden å skru på dette igjen. Kanskje i neste preview om du er heldig.
Endret av dan1el
