Matrox Parhelia
Hei, har en problem med skjermkort Matrox Parhelia i Suse 9.0!
Problemet er No screens not found, hva skal jeg gjøre?
Her er loggen:
This is a pre-release version of XFree86, and is not supported in any
way. Bugs may be reported to [email protected] and patches submitted
to [email protected]. Before reporting bugs in pre-release versions,
please check the latest version in the XFree86 CVS repository
(http://www.XFree86.Org/cvs).
XFree86 Version 4.3.0.1
Release Date: 9 May 2003
X Protocol Version 11, Revision 0, Release 6.6
Build Operating System: SuSE Linux [ELF] SuSE
Build Date: 02 October 2003
Before reporting problems, check http://www.XFree86.Org/
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/XFree86.0.log", Time: Wed Apr 7 23:46:12 2004
(==) Using config file: "/etc/X11/XF86Config"
Parse error on line 2 of section Files in file /etc/X11/XF86Config
" " is not a valid keyword in this section.
(EE) Problem parsing the config file
(EE) Error from xf86HandleConfigFile()
Fatal server error:
no screens found
When reporting a problem related to a server crash, please send
the full server output, not just the last messages.
This can be found in the log file "/var/log/XFree86.0.log".
Please report problems to http://www.suse.de/feedback.
Den funket ikke på en av de 3 skjermene som er tilkoblet. Hjelp meg.
Ehm, les feilmeldingen! Det er en feil i konfigurasjonen i /etc/X11/XF86Config
Den sier jo alt.
Du kan evt poste /etc/X11/XF86Config her.
Endret av objorkum
Jeg prøvde å installere driveren mtxdrivers-rh9.0-v1.1.0-beta.run
Feilmelding:
Matrox MTX kernel driver (mtx.o)
The device driver enables busmastering and other features for doing
accelerated graphics on a Linux system. It is also required by the GL
library.
There's no binaries for your kernel version
Compile mtx kernel module driver (y/n)? y
Messages are being logged in make.log
This might take some time
Compiling mtx.o...There has been an error compiling the kernel module.
A log file has been created in make.log
Your kernel is not supported by this driver,
cannot update your kernel module
Press any key to continue
