Klarer ikke å redde jenta
Samme bug som hos meg.
Spilte gjennom hele brettet en gang til, fra siste save på forrige brett uten at det hjalp. Løsningen ble å få save game av en annen. Stor takk til ham.
To mutanter kom seg dermed unna, jeg tok det igjen på neste brett.
Hva gjør 1.1 patchen og hvor kan den lastes ned?
di finner patchen her: http://www.gamershell.com/download_5446.shtml
liste over forandringar på patchen
-Fixed issue with FarCry anti-cheat kicking players connecting to non-similar regions due to post process copy protection
-Integrated Punkbuster anti-cheat system (special thanks to Tony Ray for his help)
-Support for All Seeing Eye
-Fixed a number of issues with language localization
-Added crouch toggle feature so players can bind a "one touch" button to cycle prone/crouch
-Added zoom toggle (see above)
-Fixed bug with AI autobalance that sometimes caused it not to initialize outside of DEVMODE
-Fixed issue where player spawns a little higher in the air after a load from checkpoint.
-Improved AI saving state at checkpoints.
-Added new netcode optimizations, vehicles now use significantly less bandwidth in client to server updates. We are still investigating netcode issues, it is currently our highest priority
-LAN servers now restricted to LAN IP's
-Fixed some issues with sv_port variable not working correctly
-Added network commands to help players tune the network rates for better performance, including the following commands:
cl_cmdrate - Limit the number of command packets sent from client to server
sv_maxcmdrate - Limit the max cmd rate clients can specify
cl_updaterate - Limit the number of update packets sent from the server
sv_maxupdaterate - Limit the max updates clients can specify
cl_maxrate - Max bits per second can be adjusted
sv_maxrate_lan or sv_maxrate (for non lan, ie internet) will limit the cl_rate allowed on the clients
sv_DedicatedMaxRate - To change the server update speed
-Open query protocol to allow monitoring of the server with external tools
-Server config can now be anywhere with any name
-Fixed bug where "Join game" button no longer worked in multiplayer UI
-Fixed issue with dedicated server running on Windows 2003 Server edition
-Fixed bug when players get out from a vehicle, the player will go in standing pose (no crouch or prone).
-The message "drop your weapon to take this other weapon" will disappear only when the player go away from this weapon, not immediately.
-Fixed no pain sounds if an explosion didn't really hurt the player.
-Improved shader speed (up to two times faster) for NVidia Geforce FX cards on very high settings
-Fixed fog bug with NVidia drivers
-Fixed realtime shadows from blended trees
-Made improvements to lighting shaders on very high settings
-Fixed bug with lake reflections
-Added support fro PS3.0 shader profile
-Set default dedicated server log_verbosity 0 to print out console data. Before it displayed no info because logging was set to 0.
-Fixed an issue with command line game joining with the FarCry shortcut
eg har spelt igjennom den aktuelle bana utan å ha instalert 1.1 patchen, og eg hadde ingen problem. eg har derimot fått fleire problem etter at eg la den inn.
men eg har klart spelet no :yes:
prater dere om Archives ?  er der selv.. nettopp startet.. første jeg møtte på var en usynelig mutant  :scared:
du vill møte flere..(BeVare)
Fant ut at hvis jeg bruker thermalvision or whatever så så jeg dem :p gjord det litt lettere.. men de klikker jo helt me HK'en..lol
Jeg klarer heller ikke denne banen, der jeg skal redde jenta.
Jeg starter med oversvømme et stort rom, så svømme opptil ventilasjongreia, videre kommer en svær mutant, jeg dreper han, men han kaster raketter og jeg mister mye liv, så kommer det 2 mutanter til i rommet før der jenta er i, men alltid har jeg lite liv.
Klarer bare ikke å redde jenta. :no:
Hva skal jeg gjøre. :cry::(
Men ellers skikkelig rått spill og musikken er konge, mulig å få tak i den???
Hvis du kaster endel granater hvor du vet mutantene kommer så skal det ikke så mange magasin før du klarer de. Først møter du den store mutanten som skyter raketter, hvis du er i bevegelse og rygger bak i det rommet du kom fra, samtidig som du kaster granater, så er sjansen stor for at du tar han uten å miste så mye health. Når du fortsetter fram vil 2 mutanter komme ut av ei dør, kast 2 granater før du nærmer deg døren, rygg bak under rørene som henger fra taket. Mutantene bruker ei stund før de kommer under rørene, før den tid har du forhåpentlig tatt dem. I rommet hvor Natalie står, kast granat mot høyre i rommet, skyt det som er igjen av mutantene. Funket for meg etter ca 3 timer spilletid, Måtte starte en tidligere checkpoint og hente mer ammo. Lykke til
Yuhuuuuuuuu
Klarte det, endelig assssss.
Jeg lot ikke bolern med rakettene komme forbi hjørnet kasta granater på han så han fløtta seg bak så kasta jeg enda fler på han.
5granater.
Noen som har lagd merke til klokka i det rommet som kommer før der jenta er i.
Klokka på veggen i spillet går etter klokka på skrivebordet ditt.
Kult....
.... I rommet hvor Natalie står....
Natalie?? kven er det. trur du tenker på Valerie ;)
Deus Ex
Kult....
har lagt merke til dette ja. det er ein av mange easter eggs i spelet
har nå kommet til missionen Cooler... Er jeg langt i fra Val ? å er det lenge til jeg kommer ut i "naturen" igjen ?
Du har 7 brett igjenn og du er på brettet der du skal redde val, det neste brettet heiter boat! :roll:
Endret av Zernick
