Redigere innholdet i en .iso fil
WINISO er kjempe.
WinISO is a CD-ROM image file utility that can convert BIN to ISO, extract/edit/create ISO files directly, make bootable CDs and as a BIN/ISO converter/extractor/editor.
It can process almost all CD-ROM image file(s) including ISO and BIN. With WinISO, you can add/delete/rename/extract file(s) within image files. You can convert image files to the standard ISO format and you have the ability to create ISO image file(s) from a CD-ROM.
