Får ikke vekk w32.Randex.gen og W32.Netspree.wo
ei venninne mailet meg noe info om problem hun hadde fått. med disse.
Ser at det går an å gjøre noen endringer i reg etc, men da må jeg til maskin hennes og hun bor et stykke unna ..
Her er noe av meldingen hun fikk.
"); document.writeln(arrDetails); document.writeln("
"); } C:\symantec32.exe is infected with W32.Randex.gen
C:\WINNT\system32\winload.exe is infected with W32.Netspree.Worm
Kan noen hjelpe med noe enkle hjelpemidler å forklare hvordan jeg kan å de vekk
PÅ forhånd takk
:hmm: ....
fikk litt lite informasjon her men hvis du har Norton eller fungerende opptadert virusprogram kan kanskje dette hjelpe deg
Netspree removal instructions
These instructions pertain to all current and recent Symantec antivirus products, including the Symantec AntiVirus and Norton AntiVirus product lines.
Update the virus definitions.
Do one of the following:
Windows 95/98/Me: Restart the computer in Safe mode.
Windows NT/2000/XP: End the Trojan process.
Run a full system scan and delete all the files detected as W32.Netspree.Worm.
Reverse the changes that the Trojan made to the registry.
For details on each of these procedures, read the following instructions.
1. Updating the virus definitions
Symantec Security Response fully tests all the virus definitions for quality assurance before they are posted to our servers. There are two ways to obtain the most recent virus definitions:
Running LiveUpdate, which is the easiest way to obtain the virus definitions. These virus definitions are posted to the LiveUpdate servers once each week (usually on Wednesdays), unless there is a major virus outbreak. To determine whether definitions for this threat are available by LiveUpdate, refer to the Virus Definitions (LiveUpdate), in the "Protection" section, at the top of this writeup.
Downloading the definitions using the Intelligent Updater. The Intelligent Updater virus definitions are posted on U.S. business days (Monday through Friday). You should download the definitions from the Symantec Security Response Web site and manually install them. To determine whether definitions for this threat are available by the Intelligent Updater, refer to the Virus Definitions (Intelligent Updater), in the "Protection" section, at the top of this writeup.
The Intelligent Updater virus definitions are available here. For detailed instructions on how to download and install the Intelligent Updater virus definitions from the Symantec Security Response Web site, click here.
Hvis du ikke har norton og er en person som klarer å skaffe slike virus uten at du vet hvor de kommer fra, burde du skaffe det. Det er ikke SÅ dyrt å skaffe det lovlig lenger, og dersom du er DnB nettbank kunde kan du laste det ned fra dem... Det er selvfölgelig mulig å få tak i piratkopierte versjoner, og de er vanligvis fullt fungerende, men har noen ulemper i forhold til fullversjon.. i tillegg til at de er ulovlige.
