Format ved filming med dv-kamera
Går ut fra at du mener 16:9. Og ja, de fleste litt mer avanserte program skal kunne fikse den biffen. Ellers er det verdt å merke seg at praktisk talt alle "amatør"-kameraer jukser når man filmer i 16:9 modus og at du vil få samme oppløsning om du filmer i 4:3 og så masker av topp og bunn...
  • 2 uker senere...
Eneste "billige" DV kameraet jeg kjenner til som tar EKTE 16:9 (og da ekte EKTE) er Sony DSR-PDX10
La meg like godt hente noe tekst fra en test:
16:9 - Almost all cameras in this range feature a 16:9 mode but the DSR-PDX10 has an edge here. Most of the three chip presume cameras have CCDs with pixel counts that range from 280,000 to 410,000. The problem with 16:9 modes on most cameras is that their chips are actually 4:3 in format so in order to acquire in 16:9 they have to throw out some of the vertical image resolution. The DSR-PDX10 is different because it has 1,070,000 pixels for each of its ¼.7 inch CCDs. Obviously the DSR-PDX10 is not a Hi Def camera and it uses most of the extra pixels for still resolution. The advantage is that when the CCD crops down to get the 16:9 image it has roughly two times as many pixels to crop. This means that the final image will still have over 480 lines of vertical resolution even after the crop.
( Hentet i fra http://www.camcorderinfo.com/content/sony-...rder-review.htm )
