b0nna Skrevet 5. april 2004 Del Skrevet 5. april 2004 Numerous sources have confirmed that a Futuremark 3DMark 2003 score of12,535 has apparently been demonstrated by Nvidia on its pre- production engineering samples. To put this in perspective, this story is brought to you by a tweaked AMD Athlon 64 FX system based on a Gigabyte GA-K8NNXP-940 mainboard with 1GB of Corsair XMS DDR, and is equipped with the current king of 3D gaming cards, an ATI Radeon 9800XT. This rock steady, real-world system benches a strong 7382 under 3DMark 2003 Build 340 at default settings, and indeed anything that can deliver a score over 7000 is pretty rapid. http://69.56.255.194/?article=15169 Lenke til kommentar
Lacim Skrevet 5. april 2004 Del Skrevet 5. april 2004 Vær litt kritiske da, se hvor det er publisert... Lenke til kommentar
Robin B Skrevet 5. april 2004 Del Skrevet 5. april 2004 Skal vi se litt tilbake?? ____________________________________________________________________ As for performance, the Nvidia NV30 card will be about 30 per cent faster than Radeon 9700 PRO in FSAA, Anisotropic filtering is set for maximum settings. Performance wise you should be able to see 20000 to 22000 3dmarks 2001 SE on the fastest processors but we will keep our powder dry on those claims until we've seen it in action. http://www.theinquirer.net/?article=6260 ____________________________________________________________________ Lenke til kommentar
pronoob Skrevet 5. april 2004 Del Skrevet 5. april 2004 tviler litt på det der.. er tross alt the inquirer Lenke til kommentar
Traxco Skrevet 5. april 2004 Del Skrevet 5. april 2004 har ikke mye tro på dette.. husker da amd 64 3000+ kom,da skulle man få lett 20000 i 3d mark(2001) med et 9700pro kort.. viste seg at 17000-17500 var mere rett. nei..blir nok mere 6-8000,kansje 9000 i score i 3d mark 2003 for de beste kortene(tror jeg) Lenke til kommentar
Rikky Skrevet 5. april 2004 Del Skrevet 5. april 2004 Jeg velger å ta det der med en klype salt inntil videre, men hvis det stemmer er jo det helt topp. Lenke til kommentar
Tim Skrevet 5. april 2004 Del Skrevet 5. april 2004 Håper denne skjermkort generasjonen blir BRA! Håper på bedre enn det som er vist der! Lenke til kommentar
pronoob Skrevet 5. april 2004 Del Skrevet 5. april 2004 Håper denne skjermkort generasjonen blir BRA! Håper på bedre enn det som er vist der! bedre enn det? , tviler STERKT på det , du forventer tydeligvis fotorealistisk grafikk mens du sitter å ser på en dataskjerm? Lenke til kommentar
tor_erik Skrevet 5. april 2004 Del Skrevet 5. april 2004 (endret) Hmmm, synes at denne artikkelen stinker tabloid. Men i tillegg kan vi se at de brukte en Pentium 4, overklokket til sinnsyke 4,5 Ghz til testen... Vil bare også qoute Robin B, jeg er nemlig veldig enig: ____________________________________________________________________As for performance, the Nvidia NV30 card will be about 30 per cent faster than Radeon 9700 PRO in FSAA, Anisotropic filtering is set for maximum settings. Performance wise you should be able to see 20000 to 22000 3dmarks 2001 SE on the fastest processors but we will keep our powder dry on those claims until we've seen it in action. http://www.theinquirer.net/?article=6260 Endret 5. april 2004 av tor_erik Lenke til kommentar
j0sh Skrevet 5. april 2004 Del Skrevet 5. april 2004 De brukte ikke en overklokket P4 4.5 i testen, det er rekorden i dag (på 10008) som kjørte på de frekvensene. Lenke til kommentar
pronoob Skrevet 5. april 2004 Del Skrevet 5. april 2004 (endret) Så lenge man kan kjøre s.t.a.l.k.e.r og lignende spill glatt på dagens maskiner er jeg fornøyd ( også hl2 da men ingen vet jo når det kommer ) Endret 5. april 2004 av pronoob Lenke til kommentar
sindre313 Skrevet 5. april 2004 Del Skrevet 5. april 2004 Hva er vitsen med at aller skriver ? Lenke til kommentar
Nikkor Skrevet 5. april 2004 Del Skrevet 5. april 2004 Hva er vitsen med at aller skriver ? Fordi det er en veldig god score... Lenke til kommentar
lperik Skrevet 5. april 2004 Del Skrevet 5. april 2004 Hva er vitsen med at aller skriver ? ingen vet men fra spøk til halvor, tviler sterkt på at man vil se så høye scores med nv40... Lenke til kommentar
sindre313 Skrevet 5. april 2004 Del Skrevet 5. april 2004 Hva er vitsen med at aller skriver ? Fordi det er en veldig god score... Det er nokk at en skriver det... Ellers blir det bare spam... Lenke til kommentar
