Tray icon og showintaskbar=false
Hallo
Når Jeg minmerer vinduet og lager et tray icon, nede i høyre hjørne, med showintaskbar = true så funker det fint, men da går jo litt av poenget med opplegget bort. Jeg vil ha showintaskbar = false! Men når jeg da minimerer vinduer og lager icon kommer det en liten "Seek bar" i venstre hjørne! Koden for å lage icon er sånn her:
        With nid
           .cbSize = Len(nid)
           .hwnd = Me.hwnd
           .uId = vbNull
           .uFlags = NIF_ICON Or NIF_TIP Or NIF_MESSAGE
           .uCallBackMessage = WM_MOUSEMOVE
           .hIcon = Me.Icon
           .szTip = "Media Player" & vbNullChar
       End With
   Shell_NotifyIcon NIM_ADD, nid
Modulen er slik:
Public Type NOTIFYICONDATA
cbSize As Long
hwnd As Long
uId As Long
uFlags As Long
uCallBackMessage As Long
hIcon As Long
szTip As String * 64
End Type
Public Const NIM_ADD = &H0 'Add to Tray
Public Const NIM_MODIFY = &H1 'Modify Details
Public Const NIM_DELETE = &H2 'Remove From Tray
Public Const NIF_MESSAGE = &H1 'Message
Public Const NIF_ICON = &H2 'Icon
Public Const NIF_TIP = &H4 'TooTipText
Public Const WM_MOUSEMOVE = &H200 'On Mousemove
Public Const WM_LBUTTONDOWN = &H201 'Left Button Down
Public Const WM_LBUTTONUP = &H202 'Left Button Up
Public Const WM_LBUTTONDBLCLK = &H203 'Left Double Click
Public Const WM_RBUTTONDOWN = &H204 'Right Button Down
Public Const WM_RBUTTONUP = &H205 'Right Button Up
Public Const WM_RBUTTONDBLCLK = &H206 'Right Double Click
Public Declare Function SetForegroundWindow Lib "user32" (ByVal hwnd As Long) As Long
Public Declare Function Shell_NotifyIcon Lib "shell32" Alias "Shell_NotifyIconA" (ByVal dwMessage As Long, pnid As NOTIFYICONDATA) As Boolean
Public nid As NOTIFYICONDATA
Får å se denne "seek baren" se her. Hvordan får jeg den bort?
Legg til denne koden i ActiveX kontrollen:
Private Const WM_RBUTTONDBLCLK = &H206
Private Const WM_RBUTTONDOWN = &H204
Private Const WM_LBUTTONUP = &H202
Private Const WM_MOUSEMOVE = &H200
Event MouseDown(Button As Integer, Shift As Integer, X As Single, Y As Single)
Event MouseMove(Button As Integer, Shift As Integer, X As Single, Y As Single)
Event MouseUp(Button As Integer, Shift As Integer, X As Single, Y As Single)
Event DblClick()
Private Sub UserControl_MouseDown(Button As Integer, Shift As Integer, X As Single, Y As Single)
Select Case X
Case WM_LBUTTONDOWN
RaiseEvent MouseDown(1, Shift, X, Y)
Case WM_LBUTTONUP
RaiseEvent MouseUp(1, Shift, X, Y)
Case WM_LBUTTONDBLCLK, WM_RBUTTONDBLCLK
RaiseEvent DblClick
Case WM_RBUTTONDOWN
RaiseEvent MouseDown(2, Shift, X, Y)
Case WM_RBUTTONUP
RaiseEvent MouseUp(2, Shift, X, Y)
Case WM_MOUSEMOVE
RaiseEvent MouseMove(1, Shift, X, Y)
End Select
End Sub
Skjedde ingen ting. Hva skal få vinduet opp i den koden der? ser ikke noe show e.l. Prøvde å bytte ut de raiseevent med msgbox, men ingen poppa opp. Hvis jeg gjorde usercontrolen synlig og trykka på den skjedde det heller ingen ting. :(
Endret av Jonas
Jeg trodde det var innlysende, men ok, jeg skal legge til koden du må skrive inn i formen:
Private Sub Tray1_MouseDown(Button As Integer, Shift As Integer, X As Single, Y As Single)
Show
End Sub
Denne koden skal du selvsakt legge til etter du har skrevet koden fra den forrige posten inn i ActiveX kontrollen.
