opticus Skrevet 30. mars 2004 Rapporter Del Skrevet 30. mars 2004 (endret) hardware: asus p4c800-e p4 2,8ghz radeon 9800 pro ------------------------ driver: fglrx-4.3.0-3.7.6.i386.rpm fra ati.com ------------------------ [opticus@dhcppc0 bin]$ fglrxinfo display: :0.0 screen: 0 OpenGL vendor string: ATI Technologies Inc. OpenGL renderer string: RADEON 9800 Pro Generic OpenGL version string: 1.3 (X4.3.0-3.7.6) ------------------------ [opticus@dhcppc0 bin]$ fgl_glxgears 424 frames in 5.0 seconds = 84.800 FPS 425 frames in 5.0 seconds = 85.000 FPS ------------------------ [root@dhcppc0 bin]# lsmod fglrx 204228 128 intel-agp 17372 1 agpgart 31016 2 intel-agp ------------------------ burde jeg ikke få et bedre resultat med fgl_glxgears? brukte denne guiden fra linuxquestions.org EDIT: kjører dette på mandrake 10 EDIT: fjernet den lange lista til lsmod Endret 12. april 2004 av opticus Lenke til kommentar
TanglewoodD Skrevet 6. april 2004 Rapporter Del Skrevet 6. april 2004 hardware:asus p4c800-e p4 2,8ghz radeon 9800 pro ------------------------ driver: fglrx-4.3.0-3.7.6.i386.rpm fra ati.com ------------------------ [opticus@dhcppc0 bin]$ fglrxinfo display: :0.0 screen: 0 OpenGL vendor string: ATI Technologies Inc. OpenGL renderer string: RADEON 9800 Pro Generic OpenGL version string: 1.3 (X4.3.0-3.7.6) ------------------------ [opticus@dhcppc0 bin]$ fgl_glxgears 424 frames in 5.0 seconds = 84.800 FPS 425 frames in 5.0 seconds = 85.000 FPS ------------------------ [root@dhcppc0 bin]# lsmod Module Size Used by sg 38044 0 sr_mod 17060 0 fglrx 204228 128 lp 12200 0 md5 3872 1 ipv6 232352 8 snd-seq-oss 31232 0 snd-seq-midi-event 7552 1 snd-seq-oss snd-seq 51024 4 snd-seq-oss,snd-seq-midi-event snd-pcm-oss 51812 0 snd-mixer-oss 17952 1 snd-pcm-oss snd-intel8x0 32776 0 snd-ac97-codec 58148 1 snd-intel8x0 snd-pcm 93156 2 snd-pcm-oss,snd-intel8x0 snd-timer 24484 2 snd-seq,snd-pcm gameport 4480 1 snd-intel8x0 snd-page-alloc 11972 2 snd-intel8x0,snd-pcm snd-mpu401-uart 7072 1 snd-intel8x0 snd-rawmidi 23616 1 snd-mpu401-uart snd-seq-device 8008 3 snd-seq-oss,snd-seq,snd-rawmidi snd 52484 12 snd-seq-oss,snd-seq-midi-event,snd-seq,snd-pcm-oss,snd-mixer-oss,snd-intel8x0,snd-ac97-codec,snd-pcm,snd-timer,snd-mpu401-uart,snd-rawmidi,snd-seq-device soundcore 9248 1 snd af_packet 20520 2 raw 7616 1 ide-floppy 18752 0 ide-tape 34864 0 ide-cd 40548 0 cdrom 37184 2 sr_mod,ide-cd floppy 59444 0 e1000 81764 0 ohci1394 33956 0 ieee1394 287856 1 ohci1394 nls_iso8859-1 3904 3 ntfs 85932 3 supermount 37876 3 intel-agp 17372 1 agpgart 31016 2 intel-agp ppa 12296 0 parport_pc 32832 1 imm 12360 0 scsi_mod 114744 4 sg,sr_mod,ppa,imm parport 38952 4 lp,ppa,parport_pc,imm usblp 12256 0 tsdev 7168 0 evdev 9504 0 usbmouse 5216 0 ehci-hcd 24196 0 hid 53312 0 uhci-hcd 29104 0 usbcore 99132 7 usblp,usbmouse,ehci-hcd,hid,uhci-hcd rtc 11576 0 ext3 110376 2 jbd 54328 1 ext3 ------------------------ burde jeg ikke få et bedre resultat med fgl_glxgears? brukte denne guiden fra linuxquestions.org EDIT: kjører dette på mandrake 10 Du har mye info som ikke er til noe nytte, men er det ikke et eget tema "Linux" på ATI`s hjemme side? mvh Stian_A Lenke til kommentar
Manuel Skrevet 8. april 2004 Rapporter Del Skrevet 8. april 2004 (endret) Det kan virke som at ATI sine drivere bare blir dårligere jo nyere de er. Mitt forslag er at du driter i 3.7.6, da den versjonen er kjent for å ikke by på annet en kompatibilitetsproblemer og ytelsesreduksjon uansett forhold. Gå heller for 3.7 eller 3.2.8. 3.7 og 3.2.8 på patches med vmalloc-patchen for å ordne noen bugs med MTRR (som du må aktivere i kernelen) hvis du bruker linux 2.6.x. Sistnevnte må også patches med en amd-fix hvis du har en AMD cpu... display: :0.0 screen: 0 OpenGL vendor string: ATI Technologies Inc. OpenGL renderer string: RADEON 9800 Pro Generic OpenGL version string: 1.3 (X4.3.0-3.7.6) Nyere drivere er ikke optimalisert med SSE og MMX-støtte.... "Generic" betyr alltid "bedriten erstatningsdriver med dertil bedriten ytelse" Det er også viktig å ikke kompilere inn støtte for DRI i kjernen. Dvs. at du ikke kan kompilere inn noen drivere. Men det går bra å bruke dem som moduler... Men det faktum at driveren tilsynelatende er lastet riktig vitner om at du har gjort dette riktig. Det hadde vært fint om du kunne komme med litt mer info; Sjekk outputen til glxinfo og XFree86-loggen (/var/log/XFree86.0.log eller no' sånt). lsmod-outputen ser grei ut. Det som er interessant her er: fglrx 204228 128 intel-agp 17372 1 agpgart 31016 2 intel-agp agpgart-driveren er lastet, sammen med den tilhørende intel-agp-modulen til ditt brikkesett. Spørsmålet er om fglrx tar i bruk AGP... Som standard er intel-agp-modulen bare avhengig av agpgart for å fungere (dvs. at agp-gart lastes "automagically" ved modprobe intel-agp). Sjekk om du har en liknende ordning for fglrx: Jeg antar at du har en relativt ny distrubsjon som benytter seg av den nye module-init-tools-pakken (som kreves for å laste moduler med linux 2.6.x). Det skal finnes en fil som heter /etc/modprobe.conf. Dette er nyversjonen av /etc/modules.conf; Sjekk om modprobe.conf inneholder noen referanser til fglrx. Det burde se omtrent slik ut: install fglrx /sbin/modprobe intel-agp; /sbin/modprobe --ignore install fglrx Dette betyr noe ala: "Modul fglrx er avhengig av intel-agp for å fungere skikkelig (men de er ikke avengige av hverandre, derfor modprobe ikke laster dem sammen). Derfor skal intel-agp-modulen lastes før fglrx-modulen". Dette forutsetter at du har svar "ja" på om du vil bruke en ekstern agp-modul i fglrxconfig... Hvor høy fps får du i glxgears? Endret 8. april 2004 av Manuel Lenke til kommentar
objorkum Skrevet 8. april 2004 Rapporter Del Skrevet 8. april 2004 Hos meg var 3.7.6 bare ren glede! OpenGL i WineX nekta å funke når jeg gikk fra 3.2.8 til 3.7.0, og kom tilbake nå, og WineX spill flyter bedre. Må også si at spill som Quake og ET går bedre nå. Lenke til kommentar
Manuel Skrevet 8. april 2004 Rapporter Del Skrevet 8. april 2004 (endret) Hos meg var 3.7.6 bare ren glede! OpenGL i WineX nekta å funke når jeg gikk fra 3.2.8 til 3.7.0, og kom tilbake nå, og WineX spill flyter bedre. Må også si at spill som Quake og ET går bedre nå. Hmmm. Kanskje jeg skal gi de nye driverene en sjanse? Sliter med generelt dårlig 3d-ytelse i en del spill (f.eks scorched 3d). Med de gamle driverne så krever WineX en ekstra miljøvariabel: LD_PRELOAD=/usr/lib/libGL.so. Dette skal løse de værste ytelsesproblemene i WineX. edit: jeg ser at den driverversjonen som ligger på ATI.com er av nyere dato enn den jeg prøvde... Var mer enn 1 mnd. siden jeg installerte "den nyeste driveren"... Endret 8. april 2004 av Manuel Lenke til kommentar
objorkum Skrevet 8. april 2004 Rapporter Del Skrevet 8. april 2004 Jeg bruker driverene spesialpakket for SuSE: ftp://ftp.suse.com/pub/suse/i386/suppleme...90/fglrx/3.7.6/ Lenke til kommentar
opticus Skrevet 12. april 2004 Forfatter Rapporter Del Skrevet 12. april 2004 jeg testet med å kjøre extern agp og ikke extern, samme resultat. skal sjekke modprobe når jeg kommer hjem.. Lenke til kommentar
opticus Skrevet 14. april 2004 Forfatter Rapporter Del Skrevet 14. april 2004 eller burde koden se slik ut?: install fglrx /sbin/modprobe --first-time --ignore-install fglrx && { /sbin/modprobe intel-agp; /bin/true; } remove fglrx { /sbin/modprobe -r intel-agp; }; /sbin/modprobe -r --first-time --ignore-remove fglrx det står forresten ikke noe som ligner på noe av dette i modprobe.conf fila Lenke til kommentar
drall Skrevet 16. april 2004 Rapporter Del Skrevet 16. april 2004 ATI's linux-drivere er en skam. Lenke til kommentar
opticus Skrevet 16. april 2004 Forfatter Rapporter Del Skrevet 16. april 2004 ja! Lenke til kommentar
Stor Oddnoga Skrevet 16. april 2004 Rapporter Del Skrevet 16. april 2004 Fikk de til å funke perfekt i Mandrake 10. Har tidligere prøvd andre distroer, men der har jeg ikke klart det, men nå er jeg helt grønn på linux da. Ser at mange sliter. Holder meg til Mandrake 10 foreløpig, for nå funker det ihvertfall. Lenke til kommentar
Manuel Skrevet 16. april 2004 Rapporter Del Skrevet 16. april 2004 eller burde koden se slik ut?: install fglrx /sbin/modprobe --first-time --ignore-install fglrx && { /sbin/modprobe intel-agp; /bin/true; } remove fglrx { /sbin/modprobe -r intel-agp; }; /sbin/modprobe -r --first-time --ignore-remove fglrx det står forresten ikke noe som ligner på noe av dette i modprobe.conf fila Skjønner ikke hvor du har fått det fra... Bruk heller det som er skrevet tidligere. install fglrx /sbin/modprobe --first-time --ignore-install fglrx && { /sbin/modprobe intel-agp; /bin/true; } jeg har ikke hørt om "--first-time" før... Jeg får iallfall feilmelding (bruker Slackware). Hele greia ser feil ut egentlig... install <modulnavn> betyr at man istedenfor "modprobe <modulnavn>" skal kjøre kommandoen etter. Tvert imot så vil den første linjen laste agp-driveren til sist. "/bin/true" er heller ikke nødvendig med mindre du skal lage noen spesielle skript som tester som kommandoen returnerer "true". Fordi du har brukt && vil aldri kommandoene i klammeparantesen bli kjørt fordi den første (sannsynligvis" vil feile. remove fglrx { /sbin/modprobe -r intel-agp; }; /sbin/modprobe -r --first-time --ignore-remove fglrx remove-prefikset betyr at påfølgende kommando skal kjøres før modprobe -r fglrx (altså når man skal fjerne modulen fra kjernen). Den første delen (før det første semikolonet) er fullt gyldig, men gjør absoulutt ingen nytte hvis de forstående modulene (fglrx og intel-agp) ikke finnes i kjernen. Men hva slags resultater får du med glxgears? Lenke til kommentar
opticus Skrevet 17. april 2004 Forfatter Rapporter Del Skrevet 17. april 2004 [opticus@dhcppc0 bin]$ fgl_glxgears 424 frames in 5.0 seconds = 84.800 FPS 425 frames in 5.0 seconds = 85.000 FPS får ca det samme med glxgears 85 der tror jeg.. stabilt på 85, men det er veldig dårlig? Lenke til kommentar
Velmont Skrevet 17. april 2004 Rapporter Del Skrevet 17. april 2004 943 frames in 5.0 seconds = 188.600 FPS 943 frames in 5.0 seconds = 188.600 FPS 935 frames in 5.0 seconds = 187.000 FPS -- Mitt kort er ganske bra. Med glxgears blir det mye høyere.... Men du, fgl_glxgears funker ikke uten skikkelig driver installert - så det virker som det funker... Men du har tydligvis er bra kort - og at du skulle få mindre enn den meg er litt rart da. Selv har jeg ATI Mobillity Radeon 9000 Lenke til kommentar
Manuel Skrevet 17. april 2004 Rapporter Del Skrevet 17. april 2004 [opticus@dhcppc0 bin]$ fgl_glxgears424 frames in 5.0 seconds = 84.800 FPS 425 frames in 5.0 seconds = 85.000 FPS får ca det samme med glxgears 85 der tror jeg.. stabilt på 85, men det er veldig dårlig? Jeg synes at det ser ut som at du har skrudd på vsync. Det betyr at framraten ikke blir høyere enn refresh-raten på skjermen, som er 85hz? Test heller noen spill du; Ytelsen kommer neppe til å vippe deg av stolen, men den er langt bedre enn med framebuffer eller vesa-driveren. Lenke til kommentar
