default så har du en adresse i 8 dager. (dette kan det stilles på hvis ønskelig). når halve tiden har gått sender maskinen din en ny request til dhcp-serveren for å beholde ip-adressen så lenge som mulig...
Og når man når T2 som er 87,5% av leietiden, vil klienten forsøke å finne en annen DHCP server å leie adresse hos (sender ut broadcast meldinger)
If the server does not respond to the DHCPREQUEST unicast message, the client continues to send requests at regular intervals until it reaches the rebinding time value or T2 value, which defaults to 87.5 percent of the lease period. At this point, the client enters the rebinding state and begins transmitting DHCPREQUEST messages as broadcasts, soliciting an address assignment from any DHCP server on the network. Again, a server can respond with either a DHCPACK or DHCPNAK message. If the lease time expires with no response from any DHCP server, the client's IP address is released and all its TCP/IP communication ceases, except for the transmission of DHCPDISCOVER broadcasts.
