atlef Skrevet 29. mars 2004 Del Skrevet 29. mars 2004 CopyLock is a small program that allows replacing, moving, renaming or deleting one or many files which are currently in use (e.g. system files like comctl32.dll, or virus/trojan files.) Add the files to update, click Apply, restart and that's it! You can also list and edit the pending operations from the system after you ran an installer or view the processes which use the locked files. Disclaimer: you can crash your system or make it unbootable if you are not careful, use at your own risk. Kan hentes her.[Link] Mvh Meg. Lenke til kommentar
Crack Skrevet 30. mars 2004 Del Skrevet 30. mars 2004 (endret) ==== Slettet ==== Endret 24. mai 2006 av Crack Lenke til kommentar
