abze Skrevet 28. mars 2004 Del Skrevet 28. mars 2004 (endret) skal brenne cue fil i k3b, men når eg starte programmet kommer denne meld opp No support for ATAPI with cdrdao You will not be able to use all your reading devices as copy sources since there is at least one not configured to use SCSI emulation and your system does not support ATAPI with cdrdao. Solution: The best and recommended solution is to enable ide-scsi (SCSI emulation) for all writer devices. This way you won't have any problems. Hvordan fikser jeg dette problemet? Vet ikke hvor jeg kan enable ide-scsi... For også opp denne feilen, når eg prøver å brenne: System ----------------------- K3b Version: 0.9 KDE Version: 3.1.3 QT Version: 3.1.2 cdrecord ----------------------- scsidev: '0,0,0' scsibus: 0 target: 0 lun: 0 Linux sg driver version: 3.1.25 SCSI buffer size: 64512 Cdrecord-Clone 2.01a18-dvd (i686-pc-linux-gnu) Copyright © 1995-2003 Jörg Schilling Note: This version is an unofficial (modified) version with DVD support Note: and therefore may have bugs that are not present in the original. Note: Please send bug reports or support requests to <[email protected]>. Note: The author of cdrecord is not to be bothered with problems in this version. TOC Type: 3 = CD-ROM XA mode 2 Using libscg version 'schily-0.7' atapi: 1 Device type : Removable CD-ROM Version : 0 Response Format: 1 Vendor_info : 'PLEXTOR ' Identifikation : 'CD-R PX-W4824A' Revision : '1.01' Device seems to be: Generic mmc CD-RW. Current: 0x0009 Profile: 0x0008 Profile: 0x0009 (current) Profile: 0x000A Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr). Driver flags : MMC-3 SWABAUDIO BURNFREE VARIREC FORCESPEED SPEEDREAD SINGLESESSION HIDECDR Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R Drive buf size : 2394336 = 2338 KB FIFO size : 4194304 = 4096 KB /usr//bin/cdrecord: No such file or directory. Cannot open FILE 'SUSEL90A.BIN'. cdrecord comand: ----------------------- /usr//bin/cdrecord -v gracetime=2 dev=0,0,0 speed=44 -dao cuefile=/home/frode/SuSE Linux 9.0 Pro/susel90a.cue -eject -multi -force Endret 28. mars 2004 av abze Lenke til kommentar
Cronius Skrevet 28. mars 2004 Del Skrevet 28. mars 2004 (endret) Hvilken distro bruker du? Med 2.6 kjerne behøver du ikke scsi-emulering. For å få til scsi-emulering må kjernen ha kompilert inn ide-scsi (eller som modul), og i /etc/lilo.conf legger du til: append="hdx=ide-scsi" hvor hdx er brenneren. Deretter kjører du lilo (som root) for å oppdatere lilo. Evnt. i /boot/grub/menu.lst: finn linja som begynner på kernel /boot/bla bla og legg til dette på slutten: hdx=ide-scsi (hvor hdx er brenneren) Deretter er det bare å restarte så er alt jubalong. En modprobe ide-scsi behøvs kanskje. Hvis ide-scsi ikke er kompilert inn må du fikse dette, faq-tråden beskriver kompilering av kjerne. Som sagt så behøves ikke scsi-emulering med 2.6 kjernen. Lykke til! Edit: Etter å ha sett litt nærmere på feilmeldingen er det ikke sikkert scsi-emulering er problemet, er litt usikker på hva som foresaker feilen i så fall, kan være flere ting. Endret 28. mars 2004 av Cronius Lenke til kommentar
abze Skrevet 28. mars 2004 Forfatter Del Skrevet 28. mars 2004 jeg har 2.4 kjerne, skal legge inn suse, mandrake er jeg lei av. Lenke til kommentar
kyrsjo Skrevet 28. mars 2004 Del Skrevet 28. mars 2004 Får den jeg også. Ikke noe bry seg om med mindre du forsøker å brenne direkte fra en cd-rom til en annen. Den mener at du kansje burde aktivere ide-scsi på den andre cd-romen din også. hvis du vil aktivere det er det bare snakk om et kernel-argument (i bootloader) Lenke til kommentar
