Tyan Thunder S4882
Simen1
Jeg kom akkutat over de første bildene jeg har sett av det omtalte Quad Opteron hovedkortet fra Tyan, S4882: Link
Specs:
Tyan Thunder K8QS ( S4882 ) Quad AMD Opteron™ 4U/Pedestal Server
Processors
- Quad µPGA 940-pin ZIF sockets
- Supports up to four AMD OpteronTM 800 series processors
- Four onboard 3-phase VRMs
- Integrated 128-bit DDR Memory Controller
Chipset
- AMD-8131TM HyperTransport PCI-X Tunnel
- AMD-8111TM HyperTransport I/O Hub
- Winbond W83627HF Super I/O chip
- Total five Hardware Monitoring IC: One ADM1027 and four LM63
Memory
- 128-bit dual channel memory bus
- Total sixteen 184-pin 2.5-Volt DDR DIMM sockets (4 on each CPU)
- Supports up to 32 GB Registered DDR
- Supports ECC and ECC with Chipkill type memory modules
- Supports PC1600, PC2100, & PC2700 DDR
Expansion Slots
- Two independent PCI-X buses
- Two 64-bit 66/33 MHz (3.3-Volt) PCI-X slots from PCI-X bridge A
- Two 64-bit 133/66/33 MHz (3.3-Volt) PCI-X slots from PCI-X bridge B
- One legacy 32-bit 33MHz (5-Volt) PCI slot
- Total of five usable slots
Integrated I/O
- One floppy connector supports one drives
- Two 9-pin serial ports (one connector and one header) and One 25-pin parallel port pin-header
- PS/2 mouse and keyboard connectors
- Four USB v1.1 front panel headers
- Two USB v2.0 connectors through VT6212
System Management
- Total nine 3-pin fan headers with tachometer monitoring
- Four fan headers with (PWM) speed control
- One 2-pin Chassis Intrusion header
- Temperature, voltage and fan monitoring
Integrated Enhanced IDE Controller
- Provides two IDE dual-drive ports for up to four EIDE devices
- Supports for UDMA 33/66/100/133 IDE drives and ATAPI compliant devices
Integrated PCI Graphics
- ATI RageTM XL PCI graphics controller
- 8MB Frame Buffer of video memory
Integrated Serial ATA Controller (manufacturing option)
- One Silicon Image SI3114 controllers
- Four SATA 1.0 ports
- Supports up Four SATA drives
- Supports RAID 0,1,0+1
Integrated Dual Channel SCSI (manufacturing option)
- LSI 53C1030 U320 SCSI controller
- Dual-channel Ultra320 SCSI
- Connects to PCI-X Bridge A
- Supports LSI ZCR (Zero Channel RAID)
Integrated LAN Controllers
- Broadcom® BCM5704C dual-channel Gigabit Ethernet
controller
♦ Two RJ-45 LAN connectors with LEDs
♦ Connected to PCI-X Bridge A
- Two Front Panel LED headers
Intelligent Platform Management Interface Header
- Tyan Server Management Daughter card (Optional)
supports features listed below via IPMI header
- QLogicTM Zircon Baseboard Management Controller
(BMC) based on powerful ARM7 technology
- Tailored for IPMI highest 1.5 Spec.
- Supports KCS and BT styles
- Flexible Windows and Linux based Management
Solution
- Supports RMCP and SNMP protocols
- Supports ASF standard and EMP
- I2C serial multi-master controllers and UARTs
- Built-in IPMB connector
- Remote power on/off and reset support (IPMI-over-
LAN)
BIOS
- Phoenix BIOS
- 4Mbit LPC Flash ROM
- Watchdog timer
- USB boot support
- 48-bit LBA Support
- Supports PXE via Ethernet
- ACPI 2.0 & 1.0B support
Form Factor
- SSI MEB footprint (13” x 16” / 330.2mm x 406.4mm)
- EPS12V power connectors
- One serial port and one VGA connector
- Stacked USB 2.0 (two) connectors
- Stacked PS/2 keyboard and mouse connectors
- Two RJ-45 side-by-side LAN connectors with LEDs
Regulatory
- FCC Class B (Declaration of Conformity)
- European Community CE (Declaration of Conformity)
Endret av Simen1
Samme som dette kortet her regner jeg med: http://afweb.hit.no/~u022932/bilder/DSCN9299.JPG
Ganske pent ja, men utrolig at de ikke har AGP på det.
På lappen forran kortet står det S2885, men jeg klarer ikke å se noen fysiske forskjeller mellom det og det som heter S4882
AGP er nok kanskje ikke mer enn av hypotetisk interresse for spillere, men det hadde jo vært gøy å se ja, særlig i tester for å skjønner ytelse-forskjellen mellom dual og quad bedre. Men for å være ærlig så tror jeg ikke det er mange av brukerene av slike kort som ville tatt i bruk AGP-porten. (Kanskje 10 kanskje 100, men neppe lønnsomme mengder)
Tja... nå er det en integrert skjermkontroller på kortet. Tyan har vel vurdert markedet til å ikke være sluttbrukere med behov for 3D grafikk da.
timtowtdi
Må jo være en drøm for brukere av f.eks. Maya, Lightwave og lignende....
timtowtdi
Om en har bruk for ekstrem renderingskraft så kan en vel ha et par servere som hjelper til. Selve workstation behøver ikke all kraften, og quad systemer er jo generelt svindyre! Typisk 20k for HK og noe i samme retning for hver CPU.
Men ja det hadde vært en drøm! :love:
Endret av Knick Knack
