==== Slettet ====
Gearsec:
Installed by Apple Quicktime package - iPod/iTunes CDRW support. Can be disabled if you only require Quicktime player
jusched: (java update scheduler)
Checks with Sun's Java updates site to see if newer Java versions are available. Visit java.sun.com or just run the Java Plug-In Control Panel
