NV40 lanseres 13. april
Fra linken til Gomp.
Halo - 1600x1200 - no AA/8X AF - 51.1fps
Far Cry - 1600x1200 - no AA/no AF - 53.4fps
UT2004 Botmatch - 1600x1200 - 4X AA/4X AF - 71.9fps, 1280x960 - 82.9fps
Star Wars Kotor - 1600x1200 - 4X AA/8X AF - 49.3fps
The forums at Beyond3D have been in a feeding frenzy tonight as a member is serving a full course dinner based on information from someone with an A2 revision of NVIDIA's next-generation NV40 GPU.
He starts off with a carefully crafted assualt by serving up an entree of three game screenshots that can be seen at this link. But alas, the mystery man exits stage left, although he promises to return to serve the main course.
Let's see what we are having tonight...
NV40 revision A2 clocked at 475MHz core and 1.2GHz memory (GDDR-3)
16 pipelines - 3DMark2001 single-texture fillrate of 7,010 MPixels/sec and multi-texture fillrate of 7,234 MPixels/sec
Pixel shader performance ranges from 2.5X to 5X over GeForce FX 5950 Ultra
Antialiasing in screenshots is 4X RGMS (Rotated Grid Multi-Sampling)
Max anisotropic filtering at 8X with tested driver, but might see 16X
Gameplay performance 2.5X to 3X faster than GeForce FX 5950 Ultra using high resolutions with AA and AF
Image quality is "far far better"
Will you be having dessert tonight sir? Sure, why not...
System Specs - Athlon 64 3200+, Gigabyte GA-K8VT800 (VIA KT880) Mainboard, 1GB PC4000 RAM, 160GB SATA HDD.
Ja, rimelig spennede det der ja, men sier igrunn lite om ytelsen. Halo er et spill som ligger på 50-60fps.
Eneste som makes sense er UT2k4 og Far Cry, og jeg er ikke så skuffet. Lurer på om det er gjennomsnittsfps eller minimumsfps.
Vi får se når kortene kommer :) Har selv vært ATi tilhenger lenge, men får jo se om NVIDIA klarer å snu troen min :)
May the highest FPS be with you :thumbup:
