aog Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 Hei. Jeg driver å skriver litt koder på en side.. Bare noen problem.. Her er siden. Den funker ikke i Opera og Mozilla. <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"> <html> <head> <title>House Ma'adiah</title> <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"> <style type="text/css" media="screen">@import "style.css";</style> <script language="JavaScript" type="text/JavaScript"> <!-- function MM_reloadPage(init) { //reloads the window if Nav4 resized if (init==true) with (navigator) {if ((appName=="Netscape")&&(parseInt(appVersion)==4)) { document.MM_pgW=innerWidth; document.MM_pgH=innerHeight; onresize=MM_reloadPage; }} else if (innerWidth!=document.MM_pgW || innerHeight!=document.MM_pgH) location.reload(); } MM_reloadPage(true); //--> </script> </head> <body id="body"> <div> <center> <table border="0" width="800" height="650" cellspacing="0" cellpadding="0"> <tr> <td width="100%" height="19"><img border="0" src="pic/header.jpg" width="800" height="201"></td> </tr> <tr> <td width="100%" height="19"><img border="0" src="pic/menu.jpg" width="800" height="86"></td> </tr> <tr> <td width="100%" height="38"><img border="0" src="pic/body.jpg" width="800" height="363"> <div id="Layer1" style="position:absolute; margin-left:-780px; margin-top:0px; width:173px; height:117px; z-index:1"> <div id="1"> <iframe name="gToday:normal:agenda.js:gfFlat:plugins1.js" id="gToday:normal:agenda.js:gfFlat:plugins1.js" src="iflateng.htm" scrolling="no" frameborder="0"></iframe><br><br> </div></div> <div id="Layer1" style="position:absolute; margin-left:-780px; padding: 175 0 0 5; width:173px; height:117px; z-index:1"> <a href="http://www.timezoneconverter.com/cgi-bin/tzc.tzc">Time Zone Converter</a><br> <a href="http://anarchy-online.com">Anarchy Online</a><br> <a href="http://ao.stratics.com/">AO Stratics</a><br> <a href="http://www.housemaadiah.com/aog/v021/">Tools</a><br> <a href="http://kuren.org/ao/">Kuren.org</a><br> <a href="mailto:[email protected]">aog</a><br> <a href="mailto:[email protected]">aog</a><br> <a href="http://host125.ipowerweb.com:8080/webmail/index.pl">Webmail</a></div> <div id="Layer1" style="position:absolute; margin-left:-785px; margin-top:-68; padding: 0 0 0 0; width:555px; height:339px; z-index:1"> <a href="index.htm">- Home</a> <a href="info/coc.htm" target="mainFrame">- CoC</a> <a href="info/members.php" target="mainFrame">- Members</a> <a href="index.htm">- Home</a> </div> <div id="Layer1" style="position:absolute; margin-left:-585px; padding: 0 0 0 0; width:555px; height:339px; z-index:1"> <iframe src="info/news.php" name="mainFrame" id="mainFrame" style="position:absolute; margin-top:1px; padding: 0 0 0 0; width:555px; height:339px; z-index:0"></iframe> </div> </td> </tr> </table> </center> </div> </body> </html> Sikkert mye rar n00b-koding her, men så er det jo jeg som gjør det. noen som kan hjelpe? Lenke til kommentar
PT Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 Du kan jo kanskje begynne med å validere siden din... Lenke til kommentar
Crack Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 (endret) ==== Slettet ==== Endret 24. mai 2006 av Crack Lenke til kommentar
aog Skrevet 17. mars 2004 Forfatter Del Skrevet 17. mars 2004 Line 24, column 39: there is no attribute "HEIGHT" (explain...). <table border="0" width="800" height="650" cellspacing="0" cellpadding="0"> ^ Line 26, column 96: required attribute "ALT" not specified (explain...). .../header.jpg" width="800" height="201"></td> ^ Og hva menes med dette? Lenke til kommentar
aog Skrevet 17. mars 2004 Forfatter Del Skrevet 17. mars 2004 (endret) Prøv å fjern javascriptet og sjekk om det funker da. Virket for meg ihvertfall.. javascript er borte.. funker ikke i Opera.. har ikke teste i mozilla... EDIT: Har teste i Mozilla også. Funker ikke der heller. Endret 17. mars 2004 av aog Lenke til kommentar
LoS Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 Hvorfor har du div's i tabellen din egentlig? Ikke det at jeg veit om det er problemet, men det kan for all del være det og Lenke til kommentar
aog Skrevet 17. mars 2004 Forfatter Del Skrevet 17. mars 2004 hehe.. vet ikke helt, men jeg fikk siden til å vise slik den skulle i IE ved å gjøre det slik, så da bare gjorde jeg det slik.. Lenke til kommentar
LoS Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 Burde vel kanskje prøve å bygge den opp med enten div's eller tables, og kun en av dem Lenke til kommentar
aog Skrevet 17. mars 2004 Forfatter Del Skrevet 17. mars 2004 Men det burde vel alikevel funk? Eller? Lenke til kommentar
Loomy Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 Line 24, column 39: there is no attribute "HEIGHT" (explain...). <table border="0" width="800" height="650" cellspacing="0" cellpadding="0"> ^ Line 26, column 96: required attribute "ALT" not specified (explain...). .../header.jpg" width="800" height="201"></td> ^ Og hva menes med dette? height er ikke lenger en gyldig HTML-atributt. Bruk CSS istedenfor ALT not specified er egentlig en bagatell, men uansett så krever den at alt er spesifisert. alt er altså teksten som kommer frem når du holder musen over bildet. Lemp inn alt="" så slipper du den til tider irriterende teksten, og samtidig får siden validert. Lenke til kommentar
aog Skrevet 17. mars 2004 Forfatter Del Skrevet 17. mars 2004 ok.. takker.. men jeg vet fremdeles ikke hvorfor siden ikke virker i Opera/mozilla.. Crack Skrevet 17/03/2004 : 20:45 Prøv å fjern javascriptet og sjekk om det funker da. Virket for meg ihvertfall.. Hvor for virker det hos deg, men ikke hos meg? Det var bare dette du fjernet sant?: <script language="JavaScript" type="text/JavaScript"> <!-- function MM_reloadPage(init) { //reloads the window if Nav4 resized if (init==true) with (navigator) {if ((appName=="Netscape")&&(parseInt(appVersion)==4)) { document.MM_pgW=innerWidth; document.MM_pgH=innerHeight; onresize=MM_reloadPage; }} else if (innerWidth!=document.MM_pgW || innerHeight!=document.MM_pgH) location.reload(); } MM_reloadPage(true); //--> </script> Lenke til kommentar
pekle Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 Posisjoneringa di er rimeleg fubar, -780px vil f.eks få elementet til å bli borte langt utanfor skjermen til venstre. Lenke til kommentar
epsil Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 DOCTYPE-deklarasjonen du nå bruker sender nettleserne inn i quirks-modus. Bytt ut <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"> med <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd"> Dette gjør det kanskje nødvendig med noen endringer i stilsettet, men du er i hvert fall sikret at nettleserne vil forsøke å vise sidene etter standardene (altså så likt som mulig). Lenke til kommentar
