Evert Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 Hi! I'm on the lookout for a Linux server. The cheaper, quieter, smaller, the better... Currently checking out the Dell SC-servers. Does anyone have better/other suggestions? I do NOT want to build this one myself, so please only suggestions for ready-built or build-on-demand options. Regards, Evert Meulie PS. I'm posting this message here because I live in Norway and will be buying the server here as well... Lenke til kommentar
Gjest Slettet+9817234daf Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 I think online shops like komplett.no builds on demand. It'll probably be more lucrative to pick out components yourself, then e-mail komplett and ask them to put it together for you. What you really should do is tell us how much you're willing to spend, then we might help you. Also mention what you're going to do with it. Lenke til kommentar
Evert Skrevet 17. mars 2004 Forfatter Del Skrevet 17. mars 2004 wh1te skrev: What you really should do is tell us how much you're willing to spend, then we might help you. Also mention what you're going to do with it. I want to spend as little as possible, and it will be used as an all-round Linux server... Lenke til kommentar
Gjest Slettet+9817234daf Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 evert skrev: wh1te skrev: What you really should do is tell us how much you're willing to spend, then we might help you. Also mention what you're going to do with it. I want to spend as little as possible, and it will be used as an all-round Linux server... I got that from the first post, but an actual figure would be much more helpful. Lenke til kommentar
CrZy_T Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 HP Proliant DL 140 if IDE and one CPU works okey. Lenke til kommentar
XzysteRr Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 (endret) What about an ordinary SFF (small Form Factor) Computer? Its almost silent and it's small! works well!! depends on how you are going to use it though... www.inout.no take a look there... It's used too.. You don't need a new one? Endret 17. mars 2004 av XzysteRr Lenke til kommentar
king_pedersen Skrevet 18. mars 2004 Del Skrevet 18. mars 2004 you can buy from www.dell.no! Lenke til kommentar
