opplåsing av xp multiplieren
Dimm
tidligere i dag låste jeg opp min xp1800+, den funker fint utenom at multiplier skalaen går slik:
5
5,5
6
6,5
7
7,5
8
8,5
9
9,5
10
10,5
11
11,5
12
13
14
Skulle ikk det være 12,4 13,5 og 14,5 ?
noen som vet om dette kan forårsakes av at ikke alle L1 bruene er kortsluttet, og i så fall hvilke av de?
Quote:
5
5,5
6
6,5
7
7,5
8
8,5
9
9,5
10
10,5
11
11,5
12
13
14
Trur det skal være slik men er ikke sikker.
Det skal nok være sånn desværre...Det de adresserer gjlelder nok alle kt266A kortene. Her kommer svaret jeg fikk når jeg spurte soltek om det samme;
Hello Sir:
This is Vincent from Taipei Soltek.Regarding to this problem.As below
was my answer.
1:First of all.If you ever pay more attention on the AMD website.
then.you must know that all of AMD XP processor already does
not has this function(To adjust the multiplier for the processor)
.so it is very difficult to give you any help.
2:Secondly.as following the VIA FAE information.he say that the
VIAKT266A chipset supports the maximum multiplier only up to 12.5X
.In consequence of this reason.the SL75DRV2 could not support 14X.
so this is limitation for the VIA KT266A chipset.
3:Thirdly.If you want to overclock your processor speed.Then.all of
peripherals(AGP card,PCI card,USB controller,IDE controller) will be
followed your action to increase itself bus clock.so your motherboard
could not works very well.
轉寄是經由 vincent <[email protected]>
----------------------- Original Message -----------------------
To: [email protected]
Date: Sun, 13 Jan 2002 23:09:35 +0100 (CET)
Subject:
Hello!
I have a small problem with my soltek 75DRV-2 when it comes to changing the mulitplier of the cpu. As default it stands on 11 and i can change it to 12
and lower. But when I try 12,5 /13 it won't boot. When I try 14, it thinks it is
5. So then my unlocked cpu, xp1700+, runs at 756Mhz.
