snorreh Skrevet 16. mars 2004 Del Skrevet 16. mars 2004 (endret) IBM IntelliStation A Pro Mer informasjon om disse kraftige arbeidsstasjonene finner dere her: http://www-1.ibm.com/press/PressServletFor...&STATUS=publish http://www-306.ibm.com/common/ssi/OIX.wss?...url=&paneltext= http://www.amd.com/us-en/Corporate/Virtual...3~83568,00.html http://www.amd.com/us-en/0,,3715_10757,00.html?redir=CPIW12 "The 64-bit transition has started, and the IntelliStation A Pro is a revolutionary evolution in the 64-bit space," said Jeff Benck, vice president of IBM eServer systems. "Our customers are demanding a versatile solution that can adapt and evolve with their changing needs. IBM has delivered with a flexible system that can run both 32- and 64-bit applications with leading performance." "The oil and gas industry demands tools that enable rapid, accurate prospect generation integrated with a full suite of geoscience applications on a single cost effective platform," said Murray Roth, executive vice president, Systems and Marketing, Landmark. "By partnering with IBM in a unique co-development process for the A Pro workstations, we have been able to bring a single, high-performance desktop solution to market that leverages the strength of the A Pro workstation and the reliability of 64-bit Linux, combined with Landmark's integrated suite of 32- and 64-bit applications. Furthermore, this platform is ideal for our volume interpretation and visualization solutions such as GeoProbe, where the ability to analyze large data volumes in real time is critical." "The A Pro offers a great alternative to Intel Itanium workstations because of its attractive price/performance as well as the simpler transition from 32- to 64-bit computing. The AMD Opteron processors enable simultaneous 32- and 64-bit computing without sacrificing performance and let you protect your investment in your current 32-bit applications. They also allow you to migrate to 64-bit applications, giving you a simplified migration path to position you for the future of 64-bit computing." "Current Intel Xeon customers will find the IntelliStation A Pro attractive. It is designed with AMD Opteron processors that enable simultaneous 32- and 64-bit computing without sacrificing performance. The AMD Opteron processor lets you protect your investment in your current 32-bit applications, while allowing you to migrate to 64-bit applications. This gives you a simplified migration path to position you for the future of 64-bit computing." Endret 17. mars 2004 av snorreh Lenke til kommentar
snorreh Skrevet 17. mars 2004 Forfatter Del Skrevet 17. mars 2004 (endret) ZDNet har også laget en sak vedrørende dette: http://zdnet.com.com/2100-1103_2-5173246.html Også Nvidia skriver om disse arbeidsstasjonene på sine sider: http://www.nvidia.com/object/IO_11744.html "According to the recently released SPECapc benchmark summaries, AMD Opteron processors are the world’s highest performing x86 workstations." Endret 17. mars 2004 av snorreh Lenke til kommentar
Arve Systad Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 AMD Har lagt gullegget ved å starte på 64 bits prosessorer så tidlig før Intel! Herfra går det kun oppover! Lenke til kommentar
AMD-King Skrevet 17. mars 2004 Del Skrevet 17. mars 2004 Noen som har 16000 $ til meg? Helt tilfeldig at jeg spør Hyggelig at IBM satser på Opteron Lenke til kommentar
