Fuel Skrevet 10. mars 2004 Del Skrevet 10. mars 2004 http://www.itavisen.no/art/1303084.html?PH...dcd632fc7444b33 Lenke til kommentar
EDB Skrevet 10. mars 2004 Del Skrevet 10. mars 2004 (endret) Se anna tråd du..... Endret 10. mars 2004 av EDB Lenke til kommentar
pgdx Skrevet 10. mars 2004 Del Skrevet 10. mars 2004 For å knuse alt håp OK, just for the heck of it I tried this to see what it actually does. When you create the "magic" extra partition, what it's actually doing is creating a bogus partition table entry that OVERLAPS with your primary partition.When I booted with a knoppix cd and used fdisk, it clearly showed the two partitions overlapping. partition 1, start sector 1, end sector 1737 partition 2, start sector 780, end sector 1737. Partition 2 is the new partition created by using the method. Hentet fra Slashdot Lenke til kommentar
