Personality Disorder Test Results
b-real
hmm. I følge den testen er jeg vist klin gal :D:realmad::D:ermm:
Paranoid: Low
Schizoid: moderate
Schizotypal: High
Antisocial: Low
Borderline: Low
Histrionic: moderate
Narcissistic: Moderate
Avoidant: Low
Dependent: Low
Obsessive-Compulsive: Moderate
Forstod ikke alle spørsmålene helt tror jeg :no:
Endret av GSM
Paranoid: High
Schizoid: High
Schizotypal: Low
Antisocial: High
Borderline: Low
Histrionic: Moderate
Narcissistic: High
Avoidant: Low
Dependent: Low
Obsessive-Compulsive: Low
Får det ikke helt til å stemme. Er absolutt ikke paranoid jeg :ermm:
Disorder | Rating
Paranoid: High
Schizoid: Very High
Schizotypal: Moderate
Antisocial: High
Borderline: Low
Narcissistic: High
Avoidant: Low
Dependent: Low
men dette viste jo jeg fra før jo! :p
hahaha
The wretched King Minos has decided your fate. His tale wraps around his body 8 times.
The sweet light no longer strikes against your eyes. Your shade has been banished to... the Eigth Level of Hell - the Malebolge!
Many and varied sinners suffer eternally in the multi-leveled Malebolge, an ampitheatre-shapped pit of despair Wholly of stone and of an iron colour: Those guilty of fraudulence and malice; the seducers and pimps, who are whipped by horned demons; the hypocrites, who struggle to walk in lead-lined cloaks; the barraters, who are ducked in boiling pitch by demons known as the Malebranche. The simonists, wedged into stone holes, and whose feet are licked by flames, kick and writhe desperately. The magicians, diviners, fortune tellers, and panderers are all here, as are the thieves. Some wallow in human excrement. Serpents writhe and wrap around men, sometimes fusing into each other. Bodies are torn apart. When you arrive, you will want to put your hands over your ears because of the lamentations of the sinners here, who are afflicted with scabs like leprosy, and lay sick on the ground, furiously scratching their skin off with their nails. Indeed, justice divine doth smite them with its hammer.
The Dante's Inferno Test has banished you to the Eigth Level of Hell - the Malebolge!
Here is how you matched up against all the levels:
Level | Score
Purgatory | Very Low
Level 1 - Limbo | Very Low
Level 2 | Very High
Level 3 | High
Level 4 | Very High
Level 5 | Very High
Level 6 - The City of Dis | Very High
Level 7 | Very High
Level 8- the Malebolge | Very High
Level 9 - Cocytus | Very High
Level descriptions: http://www.4degreez.com/misc/dante-inferno-information.html
Take the test: http://www.4degreez.com/misc/dante-inferno-test.mv
jeg skal visst få det koselig når jeg tar repern og besøker :devil: Han :devil: under..
  Sitat
Disorder        Rating
Paranoid:        Low
Schizoid:        Moderate
Antisocial:        Low
Borderline:        Low
Histrionic:        Low
Avoidant:        Moderate
Dependent:        Low
Disorder Rating Information
Paranoid: High click for info
Schizoid: Low click for info
Schizotypal: Low click for info
Antisocial: Low click for info
Borderline: Low click for info
Histrionic: Very High click for info
Narcissistic: Very High click for info
Avoidant: Low click for info
Dependent: Low click for info
Obsessive-Compulsive: Moderate click for info
WTF?
er visst ikke helt rekti i hue..
Paranoid: Moderate
Schizoid: Low
Antisocial: Moderate
Borderline: Moderate
Histrionic: Low
Avoidant: High
Dependent: Moderate
:fun:
Schizoid: High
Det var ikke den verste å få high på akkurat.. er en loner, men ser ikke på det som en personlighetsforstyrrelse!?
At jeg er både narcissistic og schizoid er litt selvmotsigende, da schizoid ikke trenger ros, mens en narcissistic elsker/må ha det. Narcissistic må være det motsatte av meg, jeg blir brydd av ros og har plagsomt høy medfølelse for andre. Obsessive-compulsive på moderat er vel korrekt ja, er en liten perfeksjonist. :)
Til å være en så enkel test er jeg overrasket over hvor bra det stemte.
  Pycnopodia skrev:
Testen virker ikke hos meg.
Jeg tar utgangspunkt i slike tester at du har litt problemer hvis du tar svaret fra en slik test seriøst. Er du sinnsyk, vet du det sikkert selv :)
Det er akkurat det du ikke gjør! Det er vel det som er litt av pointet med testen. Spørsmålet er om folk som har problemer klarer å svare ærlig på en slik test, så den er kanskje dømt til å misslykkes med sitt formål? Det som kan være interessant er å ta testen for noen du kjenner godt, og slik du vil tippe den personen ville svart. Det er som regel de rundt deg som merker at det er noe.. en god idè, hvis du tar dette seriøst da, ville kanskje vært å vise resultatet til en venn, og spør om dette stemmer..
  ZkedaR skrev:
Den testen var ikke helt god da, den sa blant annet at jeg ikke er antisosial, noe jag svarte ja til og virkelig er...
Men noe var skremmende riktig, gidder ikke å poste det her men :p
  Sitat
Antisocial
A common misconception is that antisocial personality disorder refers to people who have poor social skills. The opposite is often the case. Instead, antisocial personality disorder is characterized by a lack of conscience. People with this disorder are prone to criminal behavior, believing that their victims are weak and deserving of being taken advantage of. They tend to lie and steal. Often, they are careless with money and take action without thinking about consequences. They are often agressive and are much more concerned with their own needs than the needs of others.
sikker på at du mener at du er antisocial? :) Ifølge denne definisjonen er antisocial nesten for psykopat å regne.
