Starte Win 98 i sikkerhetsmodus fra dos. [LØST]
Er det mulig å starte windows 98 i sikkerhetsmodus fra kommandolinje i dos? Altså å boote med en win 98 oppstartdiskett til dos og starte windows derfra.
Har problemer med en maskin med dual boot, win 98 og NT4, der det ikke er mulig å komme inn i sikkerhetsmodus ved å trykke F8 eller ctrl.
Endret av Orjanp
WIN {/D:[F] [M] [N] [V] [X]} [/W] [/WX]
/W Restores the Config.sys and Autoexec.bat files from Config.wos
and Autoexec.wos and prompts:
Press any key to continue...
Pressing a key reboots the system back to Windows 95/98.
/WX Restores the Config.sys and Autoexec.bat files from Config.wos
and Autoexec.wos and reboots the system to Windows 95/98.
NOTE: .wos files are created when you open a program requiring
MS-DOS mode and you have specified a new MS-DOS-mode
configuration. You might need to use the /W or /WX switch if you
shut off your computer while you are running an MS-DOS-based
program that requires MS-DOS mode and you want to return to
Windows 95/98.
/D: Used for troubleshooting when Windows 95/98 does not start
correctly. This switch is used with the following switches:
F Turns off 32-bit disk access. This is equivalent to
"32BitDiskAccess=false" in the System.ini file.
M Enables Safe mode. This is automatically enabled during a
Safe-mode boot (by pressing F5).
N Enables Safe mode with networking. This is automatically
enabled during a Safe-mode boot (by pressing F6).
S Specifies that Windows 95/98 should not use ROM address space
between F000:0000 and 1 MB for a break point. This is
equivalent to the "SystemROMBreakPoint=false" setting in the
[386Enh] section of the System.ini file.
V Specifies that the ROM routine handles interrupts from the
hard disk controller. This is equivalent to the
"VirtualHDIRQ=false" setting in the System.ini file.
X Excludes all of the adapter area from the range of memory that
Windows 95/98 scans to find unused space. This is equivalent to
the "EMMExclude=A000-FFFF" setting in the System.ini file.
NOTE: The following /D: parameters do not work in Windows 98:
- /D:FSVXN
- /D:N
Så du vil kunne boote med en w98 start diskett .
Flytte til c: med å skrive "C:" og enter .
Mulig du må path'e deg til windows katalogen der win.com ligger.
Først boote med A:
Deretter skrive:
C:
CD \WINDOWS
Deretter starte windows vha win.com og parameter M .
Skulle da bli slik kommando syntax:
WIN /D:M
