hvilken strømforsyning?
Hei!
Hvilken strømforsyning syns ni jeg ska velge: fortron source 400w för 420,- eller antec 550w true control för 700,-. Mitt krav er en stabil og "kraftig" pc som ska overklokkes. Overklokkingen ska ikke stoppe pga strømforsyningen.... Er antecen verd merprisen eller? Eller kanskje ni har noen annen "bedre" strømforsyning. Har 3x hdd, 2x cd, 4x vifte og xp2500 i pc:n. Takk för svar!
quote fra Toms hw test:
http://www6.tomshardware.com/howto/20040122/index.html
In the high-power class above 450 watts the Antec True Control 550 is the victor. With 495 watts the Antec power supply unit leads the entire test panel in the category of "measured maximum power." In addition to very good cable lengths and two connectors for case fans, it offers the option of optimizing input voltage as an equipment highlight. This is done by means of three potentiometers that are inserted into a 5.25" slot on the front of the PC case. This makes it good particularly for overclockers.
Manuell justering av spenningene via pot meter er jo genialt og ha
hvis du presser overklokkingen .
