Når vi har startet opp PC-en kommer ofte påloggingsbildet for internett hoppende opp og det er vanskelig å få lukket det. Det kommer stadig hoppende opp selv om vi jobber med f.eks. Word, Excel eller andre program.
Når vi er pålogget internett får vi ofte opp små reklamevindu med bl.a. reklame for både viagra, penisforlengere etc.
Regner med at dette ikke kan være virus da vårt virusprogram (Norton antivirus) ikke fjerner det. Kan det være parasitter av noe slag? Vil program som SpyBoot løse problemmet?
Gratis program.(Husk å oppdatere).
Adaware: http://www.lavasoft.de/support/download/
Spybot: http://www.safer-networking.org/
Det er anbefalt å kjøre Adaware og Spybot før Spywareblaster.
Spywareblaster: http://www.javacoolsoftware.com/spywareblaster.html
SpywareBlaster doesn't scan and clean for spyware - it prevents it from ever being installed.
CWShredder og Hijackthis: http://www.spywareinfo.com/~merijn/downloads.html
CWShredder is a small utility for removing CoolWebSearch (aka CoolWwwSearch, YouFindAll, White-Pages.ws and a dozen other names). Spybot S&D and Ad-aware tend to forget essential parts of the hijack, so until they update, you can use this to completely remove the hijack. This program is updated to remove the new variants once they come out.
Hijackthis is a general homepage hijackers detector and remover. Initially based on the article Hijacked!, but expanded with almost a dozen other checks against hijacker tricks. It is continually updated to detect and remove new hijacks. It does not target specific programs/URLs, just the methods used by hijackers to force you onto their sites. As a result, false positives are imminent and unless you are sure what you're doing, you should always consult with knowledgable folks (e.g. the forums) before deleting anything.
Regcleaner: http://www.321download.com/LastFreeware/
RegCleaner 4.3.0.780 (last freeware version) OS: Win9x/NT/ME/2000/XP
RegCleaner is an easy to use program. With RegCleaner you can easily get rid of those old and obsolete registry entries created by software that you have destroyed ages ago. And by easily, I mean easily. You don't have to be any expert to use this program. Key Features: - Remove file types - Remove entries of old software - Uninstall and remove Software from the Add/Remove list - Remove unused DLL files - Remove unused Shared DLLs (Automatically detected) - Automatic backup feature Other features - Advanced automation. You can easily create scripts to make many tasks much easier.
Diskcleaner: http://www.xs4all.nl/~mp2004/
With Disk Cleaner you can easily clean up disk space that is now used by temporary files like those in the system temporary folder, the Internet Explorer Cache and Cookies folder, and the Recycle Bin.
Kjør adaware og spybot først, så eventuelt CWShredder.
Spywareblaster kan du legge inn når marskina evnt er ren.
Anbefaler også Diskcleaner for rense opp internett historie.
Regcleaner renser opp gamle filer i registeret .
