Noe feil, jeg får ikke kommet inn
Hei.
Jeg har lastet ned PHP-Nuke 7.
Jeg har lasta den opp til hovedsiden altså /public_html/.
Men da jeg konfigurerte config.php til sånn som MySQLbasen min var, og jeg går inn på adressen, så får jeg opp denne meldingen:
Fatal error: Call to undefined function: message_die() in /mnt/home3/s/sw/swaisi/public_html/db/db.php on line 88
Jeg hakke anelse på hva som er feilen, men her er kildekoden til db.php:
<?php
*                                db.php
*  begin                : Saturday, Feb 13, 2001
*  copyright            : © 2001 The phpBB Group
*  email                : [email protected]
*  $Id: db.php,v 1.10 2002/03/18 13:35:22 psotfx Exp $
*  This file is part of the phpBB2 port to Nuke 6.0 © copyright 2002
*  by Tom Nitzschner ([email protected])
http://bbtonuke.sourceforge.net (or http://www.toms-home.com)
*  As always, make a backup before messing with anything. All code
*  release by me is considered sample code only. It may be fully
*  functual, but you use it at your own risk, if you break it,
*  you get to fix it too. No waranty is given or implied.
*  Please post all questions/request about this port on http://bbtonuke.sourceforge.net first,
*  then on my site. All original header code and copyright messages will be maintained
*  to give credit where credit is due. If you modify this, the only requirement is
*  that you also maintain all original copyright messages. All my work is released
*  under the GNU GENERAL PUBLIC LICENSE. Please see the README for more information.
*  This program is free software; you can redistribute it and/or modify
*  it under the terms of the GNU General Public License as published by
*  the Free Software Foundation; either version 2 of the License, or
*  (at your option) any later version.
global $forum_admin;
if ($forum_admin == 1) {
    $the_include = "../../../db";
} elseif ($inside_mod == 1) {
    $the_include = "../../db";
} else {
    $the_include = "db";
switch($dbtype) {
case 'MySQL':
  include("".$the_include."/mysql.php");
  break;
case 'mysql4':
  include("".$the_include."/mysql4.php");
  break;
case 'postgres':
  include("".$the_include."/postgres7.php");
  break;
case 'mssql':
  include("".$the_include."/mssql.php");
  break;
case 'oracle':
  include("".$the_include."/oracle.php");
  break;
case 'msaccess':
  include("".$the_include."/msaccess.php");
  break;
case 'mssql-odbc':
  include("".$the_include."/mssql-odbc.php");
  break;
case 'db2':
  include("".$the_include."/db2.php");
  break;
$db = new sql_db($dbhost, $dbuname, $dbpass, $dbname, false);
if(!$db->db_connect_id) {
    message_die(CRITICAL_ERROR, "Kunne ikke koble til databasen");
Hva er feilen?
Takker for hjelp!!
Hei. Nå har det kommet enda en feil. Men denne gangen har det blitt verre:
Parse error: parse error in /mnt/home3/s/sw/swaisi/public_html/db/db.php on line 88
Fatal error: Call to a member function on a non-object in /mnt/home3/s/sw/swaisi/public_html/mainfile.php on line 84
Uff.
Kan dere hjelpe meg videre??
det ser ut som alt dette er ment å være en del av et større opplegg med en db_sql klasse definisjon og diverse infløkte greier.
det er meget vanskelig/umulig å si noe om dette uten å sette seg inn i alle filer du bruker, og det vil være ganske krevende å sette seg inn i det.
jeg vil foreslå at du istedet tar kontakt med forfatteren av prosjektet.
Er du sikker på at alle instillingene dine i config.php er rette ?
Det er den første plassen eg ville sjekket, eg trur det er ein liten sansynlighet for at det er ein feil i sjølve "core" filene til scriptet.
Tipper enten, $dbtype, $dbhost, $dbuname, $dbpass, $dbname eller $the_include er feil.
Endret av The Red Devil
/me hadde store problemer med PHP-nuke på min egen server for en stund siden. Fikk vel ca. 150 errors bare på forsiden, og etterhvert som jeg rettet opp i de (feil bruk av " vs. ' ), kom det flere til. Fikk tilslutt minimalisert det ned til ca. 10 feil per side...
[/off-topic]
Mener at php-nuke.org har et forum, kansje de er bedre kvalifisert til dette?
