kyrsjo Skrevet 25. februar 2004 Del Skrevet 25. februar 2004 Har en USB kotleser som støtter en rekke formater (deriblant SmartMedia, som jeg bruker). Desverre får jeg ikke denne til å fungere. Dmesg gir dette nåt jeg plugger inn: hub.c: new USB device 00:1d.1-1, assigned address 2 usb.c: USB device 2 (vend/prod 0x3538/0x15) is not claimed by any active driver.SCSI subsystem driver Revision: 1.00 Initializing USB Mass Storage driver... usb.c: registered new driver usb-storage scsi0 : SCSI emulation for USB Mass Storage devices Vendor: GENERIC Model: Card Reader CF Rev: v26F Type: Direct-Access ANSI SCSI revision: 02 WARNING: USB Mass Storage data integrity not assured USB Mass Storage device found at 2 USB Mass Storage support registered. Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0 sda: Unit Not Ready, sense: Info fld=0x0, Current 00:00: sense key Not Ready Additional sense indicates Medium not present sda : READ CAPACITY failed. sda : status = 1, message = 00, host = 0, driver = 08 Info fld=0x0, Current sd00:00: sense key Not Ready Additional sense indicates Medium not present sda : block size assumed to be 512 bytes, disk size 1GB. sda: I/O error: dev 08:00, sector 0 I/O error: dev 08:00, sector 0 unable to read partition table sda: Unit Not Ready, sense: Info fld=0x0, Current 00:00: sense key Not Ready Additional sense indicates Medium not present sda : READ CAPACITY failed. sda : status = 1, message = 00, host = 0, driver = 08 Info fld=0x0, Current sd00:00: sense key Not Ready Additional sense indicates Medium not present sda : block size assumed to be 512 bytes, disk size 1GB. sda: Write Protect is off sda: I/O error: dev 08:00, sector 0 I/O error: dev 08:00, sector 0 unable to read partition table sda: Unit Not Ready, sense: Info fld=0x0, Current 00:00: sense key Not Ready Additional sense indicates Medium not present sda : READ CAPACITY failed. sda : status = 1, message = 00, host = 0, driver = 08 Info fld=0x0, Current sd00:00: sense key Not Ready Additional sense indicates Medium not present sda : block size assumed to be 512 bytes, disk size 1GB. sda: Write Protect is off sda: I/O error: dev 08:00, sector 0 I/O error: dev 08:00, sector 0 unable to read partition table sda: Unit Not Ready, sense: Info fld=0x0, Current 00:00: sense key Not Ready Additional sense indicates Medium not present sda : READ CAPACITY failed. sda : status = 1, message = 00, host = 0, driver = 08 Info fld=0x0, Current sd00:00: sense key Not Ready Additional sense indicates Medium not present sda : block size assumed to be 512 bytes, disk size 1GB. sda: Write Protect is off sda: I/O error: dev 08:00, sector 0 I/O error: dev 08:00, sector 0 unable to read partition table sda: Unit Not Ready, sense: Info fld=0x0, Current 00:00: sense key Not Ready Additional sense indicates Medium not present sda : READ CAPACITY failed. sda : status = 1, message = 00, host = 0, driver = 08 Info fld=0x0, Current sd00:00: sense key Not Ready Additional sense indicates Medium not present sda : block size assumed to be 512 bytes, disk size 1GB. sda: Write Protect is off sda: I/O error: dev 08:00, sector 0 I/O error: dev 08:00, sector 0 unable to read partition table sda: Unit Not Ready, sense: Info fld=0x0, Current 00:00: sense key Not Ready Additional sense indicates Medium not present sda : READ CAPACITY failed. sda : status = 1, message = 00, host = 0, driver = 08 Info fld=0x0, Current sd00:00: sense key Not Ready Additional sense indicates Medium not present sda : block size assumed to be 512 bytes, disk size 1GB. sda: Write Protect is off sda: I/O error: dev 08:00, sector 0 I/O error: dev 08:00, sector 0 unable to read partition table I/O error: dev 08:00, sector 0 Jeg har prøvd utallige ganger før å få dette til å fungere, men aldri fått det til. Ja, det står i et smart-media kort. fdisk -l gir dette: [root@kyrre-laptop root]# fdisk -l Disk /dev/hda: 20.0 GB, 20003880960 bytes 240 heads, 63 sectors/track, 2584 cylinders Units = cylinders of 15120 * 512 = 7741440 bytes Device Boot Start End Blocks Id System /dev/hda1 * 1907 2584 5125680 7 HPFS/NTFS /dev/hda2 1 14 105808+ 83 Linux /dev/hda3 15 1837 13781880 83 Linux /dev/hda4 1838 1906 521640 f Win95 Ext'd (LBA) /dev/hda5 1838 1906 521608+ 82 Linux swap Partition table entries are not in disk order [root@kyrre-laptop root]# Jeg får lest alle andre USB Mass Storage ting som kameraet mit som bruker Smart Media, og minneplugger uten problemer Lenke til kommentar
Cronius Skrevet 25. februar 2004 Del Skrevet 25. februar 2004 (endret) Hvilken modell/merke er det? Et søk på google på dette +linux kanskje hjelper..? Det er i hvert fall det jeg har gjort når jeg har hatt problemer med spesifikk hardware, man kan banne på at det alltid er en eller annen som har hatt samme problem før deg. Edit: skriveleif Endret 25. februar 2004 av Cronius Lenke til kommentar
Velmont Skrevet 25. februar 2004 Del Skrevet 25. februar 2004 Min er SanDisk 6in1 SD86 eller noe i den duren og funker superb (så vet du om en som funker iallfall ) Lenke til kommentar
kyrsjo Skrevet 25. februar 2004 Forfatter Del Skrevet 25. februar 2004 hva gjør du for å mounte den? dukker den opp som flere devicer a la sda sdb osv...? Lenke til kommentar
kyrsjo Skrevet 25. februar 2004 Forfatter Del Skrevet 25. februar 2004 Hmm... Søkte litt. En hel haug som klaget over at den ikke virket, men ingen løsning. Spesiellt interessant var at en på en tysk mailingliste (så vidt jeg kunne forstå men mine heller tvilsomme tyskkunskaper), sa at den virket med 2.4.19 kernel men ikke 2.4.20?!? Mitt søk: http://www.google.com/search?hl=en&lr=&ie=...G=Google+Search Lenke til kommentar
