Kan jeg kjøre SWG
Here is the solution:  Star Wars Galaxies: What are the minimum system requirements?
Your system should have the following minimum specifications:
100% DirectX 9.0 compatible computer
Windows 98 SE, Millennium, 2000, and XP
CPU
Minimum: Intel PIII 933 MHz or AMD Athlon 900 MHz
Recommended: Intel P4 1.5+ GHz or AMD Athlon XP 1500+
Memory
Minimum: 256 MB RAM
Recommended: 512 MB RAM
Video Card
Required: 32 MB 3D Graphics card with Hardware Transform and Lighting (T&L) Capability
Recommended: 64 MB 3D Graphics card with Vertex Shader and Pixel Shader (VS/PS) Capability
Sound Card: PCI, USB or Onboard Audio Device
CD-ROM: Quad Speed CD-ROM drive or better
Keyboard and mouse
56K modem or faster Internet connection
1024x768 capable monitor
Microsoft DirectX 9.0 is included on the CD. NOTE: DirectX may require the latest updates for your operating system. This may also include the latest drivers for your particular motherboard, sound and video hardware. 2.0 GB of free hard drive space. It is recommended that you have at least an additional 500 MB of free space available after installing the game for the Windows swap/page file and additional patch downloads.
Here is the problem or goal:
