Thunderpuss Skrevet 17. februar 2004 Del Skrevet 17. februar 2004 Hei! Håper noen kan hjelpe meg. Får feilmeldinger når jeg skal brenne filer: Windows 2000 5.0 IA32 WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0001), size=45056 bytes, created 14.08.2002 14:03:36 ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16.12.2003 19:18:06 Nero version: 6.3.0.3 (Nero Express) Recorder: <CREATIVE CD-RW RW6424E> Version: 1.41 - HA 2 TA 0 - 6.3.0.3 Adapter driver: <atapi> HA 2 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <CREATIVE CD-RW RW6424E >Version: 1.41 - HA 2 TA 0 - 6.3.0.3 Adapter driver: <atapi> HA 2 === Scsi-Device-Map === DiskPeripheral : WDC WD800BB-00CAA1 17.0 pnp680 Port 0 ID 0 DMA: Off DiskPeripheral : SAMSUNG SV0844D atapi Port 1 ID 0 DMA: On CdRomPeripheral : CREATIVE CD-RW RW6424E atapi Port 2 ID 0 DMA: On === CDRom-Device-Map === CREATIVE CD-RW RW6424E E: CDRom0 ======================= AutoRun : 0 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 57671680 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 383MB (392756kB) Free physical memory: 106MB (109384kB) Memory in use : 72 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 15.2.2004 CD-ROM (ISO) 09:17:57 #1 Text 0 File Isodoc.cpp, Line 6029 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : FALSE Multisession : TRUE Multisession type: : Start multisession Burning mode : TAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 09:17:57 #2 Text 0 File Reader.cpp, Line 118 Reader running 09:17:57 #3 Text 0 File Writer.cpp, Line 124 Writer CREATIVE CD-RW RW6424E running 09:17:57 #4 ISO9660GEN -11 File geniso.cpp, Line 3882 First writeable address = 0 (0x00000000) 09:17:57 #5 Text 0 File Burncd.cpp, Line 3101 Turn on Track-at-once, using CD-R/RW media 09:17:57 #6 Text 0 File DlgWaitCD.cpp, Line 240 Last possible write address on media: 359846 ( 79:59.71) Last address to be written: 226890 ( 50:27.15) 09:17:57 #7 Text 0 File DlgWaitCD.cpp, Line 245 Write in overburning mode: FALSE 09:17:57 #8 Text 0 File DlgWaitCD.cpp, Line 2085 Recorder: CREATIVE CD-RW RW6424E; CDR code: 00 97 32 19; OSJ entry from: Prodisc Technology Inc. ATIP Data: Special Info [hex] 1: E0 00 B0, 2: 61 20 13 (LI 97:32.19), 3: 4F 3B 48 (LO 79:59.72) Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid) 09:17:57 #9 Text 0 File DlgWaitCD.cpp, Line 406 >>> Protocol of DlgWaitCD activities: <<< ========================================= 09:17:57 #10 Text 0 File ThreadedTransferInterface.cpp, Line 779 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 (CTransferItem) 2 indices, index0 (150) not provided original disc pos #0 + 226891 (226891) = #226891/50:25.16 relocatable, disc pos for caching/writing not required/required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 226889 blocks [CREATIVE CD-RW RW6424E ] -------------------------------------------------------------- 09:17:57 #11 Text 0 File ThreadedTransferInterface.cpp, Line 948 Prepare recorder [CREATIVE CD-RW RW6424E ] for write in TAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc not fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 464979968, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x41 -150 | 1 | 0 | 0x00 | 0x41 0 | 1 | 1 | 0x00 | 0x41 226891 | lead-out | 1 | 0x00 | 0x41 09:17:57 #12 Text 0 File ThreadedTransferInterface.cpp, Line 994 Removed 2 run-out blocks from end of track 1. Length: 226891 -> 226889. 09:17:58 #13 Phase 24 File dlgbrnst.cpp, Line 1800 Caching of files started 09:17:58 #14 Text 0 File Burncd.cpp, Line 4073 Cache writing successful. 09:17:58 #15 Phase 25 File dlgbrnst.cpp, Line 1800 Caching of files completed 09:17:58 #16 Phase 36 File dlgbrnst.cpp, Line 1800 Burn process started at 6x (900 KB/s) 09:17:59 #17 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 09:19:35 #18 SCSI -1135 File Cdrdrv.cpp, Line 1431 SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x0BE80000 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x0C Sense Qual: 0x00 CDB Data: 0x2A 0x00 0x00 0x00 0x9E 0x80 0x00 0x00 0x20 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x03 0x00 0x00 0x9C 0x05 0x0C 0x00 0x00 0x00 0x00 0x0C 0x00 09:19:35 #19 CDR -1135 File Writer.cpp, Line 301 Write error 09:19:35 #20 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 09:19:35 #21 Text 0 File ThreadedTransfer.cpp, Line 223 conversion idle, stopping reader 09:19:43 #22 CDR -201 File WriterStatus.cpp, Line 196 Invalid write state CREATIVE CD-RW RW6424E\H2 T0 09:19:43 #23 TRANSFER -18 File WriterStatus.cpp, Line 196 Could not perform EndTrack 09:19:43 #24 Text 0 File Mmc.cpp, Line 14323 <CREATIVECD-RW RW6424E > start Close Session 09:20:26 #25 Text 0 File dlgbrnst.cpp, Line 1658 Set remaining time: 0:00,000 (0ms) -> OK 09:20:26 #26 Phase 38 File dlgbrnst.cpp, Line 1800 Burn process failed at 6x (900 KB/s) Existing drivers: File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 14.08.2002 14:03:36 File 'Drivers\PXHELP20.SYS': Ver=2.02.62a, size=20016 bytes, created 28.10.2003 11:02:00 (Prassi/Veritas driver for win 2K) File 'Drivers\atapi.sys': Ver=5.00.2194.1, size=84976 bytes, created 15.05.2000 03:24:52 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) Kan noen være så snill å hjlpe meg med dette? Lenke til kommentar
atlef Skrevet 17. februar 2004 Del Skrevet 17. februar 2004 Se om dette tipset hjelper. Nero AspiDriver, se også etter feilmeldingen her . Mvh meg Lenke til kommentar
OC-Freak Skrevet 17. februar 2004 Del Skrevet 17. februar 2004 Sense Key: 0x03 (KEY_MEDIUM_ERROR) = du bruker lavkvalitetsmedia eller media som ikke er støttet av brenneren. Prøv andre/bedre plater, f.eks verbatim eller plextor CD-R plater. Lenke til kommentar
Thunderpuss Skrevet 18. februar 2004 Forfatter Del Skrevet 18. februar 2004 Før funket det fint med Memorex-platene jeg bruker. Plutselig en dag ville den ikke mer. Får brent rundt 50 mb, men ikke noe over det. Lenke til kommentar
