Logitech MX510
Forskjellen er dette:
The sensor: The previous MX series used a 4.7 megapixel sensor. The MX510 is using a 5.8 megapixel sensor, which means that it is gathering more information and providing greater accuracy and precision. When moving the mouse rapidly across a desktop there is a process of reporting movement. Nearly all optical mice report 7 bits to the 7th power. This means that there tends to be gaps when moving great distances rapidly. The new MX510 has a 12 bit report rate that is 12 to 12th power. With this much detailed information, every minute movement of the mouse is registered as on screen movement. A general user would see this as overkill, but a gamer that has experienced these issues in the past will see the benefits. Many of our engineers who are hardcore gamers have finally made the move from ball based mouse to optical due to this mouse.
