Feilmelding når emerging -uD world
abze
Så vidt jeg husker betyr -mcpu=i686 at koden blir optimalisert for i686, men kjørbar av alle x86, mens -march=Pentium4 gjør den enda bedre, men da bare brukbar for Pentium4. Det kan umulig være en stor feil, for det er mange som bruker -mcpu isteden for -march.
Begynner å bli pissed :angry::angry:
checking for objdir... .libs
creating libtool
updating cache ./config.cache
loading cache ./config.cache
checking whether make sets ${MAKE}... (cached) yes
checking for a BSD compatible install... /bin/install -c
checking for uname... Linux
checking for uname... i686
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for pow in -lm... yes
checking for X... libraries /usr/X11R6/lib, headers /usr/X11R6/include
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for SLsmg_init_smg in -lslang... yes
Found slang on /usr/include/slang.h
Disabling curses driver since slang is available
checking for ANSI C header files... (cached) yes
checking for fcntl.h... yes
checking for limits.h... yes
checking for malloc.h... yes
checking for sys/ioctl.h... yes
checking for sys/time.h... yes
checking for unistd.h... yes
checking for st_rdev in struct stat... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether gcc needs -traditional... no
checking return type of signal handlers... void
checking for strdup... yes
CFLAGS -O3 -mcpu=i686 -funroll-loops -pipe -I/usr/X11R6/include -I/usr/include
LDFLAGS -lslang -lm -L/usr/X11R6/lib -lX11
AA-LIBD -laa -lm -L/usr/X11R6/lib -lX11 -lslang
CC gcc
Display drivers:
slang
Linux console
x11
Keyboard drivers:
Linux console
slang
X11
Mouse drivers:
X11
creating ./config.status
creating Makefile
creating man/Makefile
creating doc/Makefile
creating src/Makefile
creating aalib-config
creating src/config.h
cd . && aclocal
cd . && automake --gnu --include-deps Makefile
cd . && autoconf
FATAL ERROR: Autoconf version 2.50 or higher is required for this script
make: *** [configure] Error 2
make: *** Waiting for unfinished jobs....
!!! ERROR: media-libs/aalib-1.4_rc4-r2 failed.
!!! Function src_compile, Line 52, Exitcode 2
!!! (no error message)
root@frode frode #
Dette kan jo ikke vær sant :cry:
skrev emerge autoconf, og den emerget, så hvorfor for jeg opp den feilmeldingen da?
Endret av abze
ok, men hvordan setter jeg den der da? trodde det hva en kommando jeg skulle kjøre ser du :) prøvde å skrive: /etc/make.conf. men fikk opp: Permission denied. Kanskje du kan forklare hvordan jeg gjør det?
prøvde enda en gang, fikk dette da: No such file or directory
Har prøvd å komme inn som root bruker, bare så det er sakt :)
Endret av abze
Da er det ikke rart alt gikk galt... Men hvordan har den blitt slettet? Rart emerge i det hele tatt fungerte...
Med mindre du er sikker på at den er det eneste som mangler, ville jeg gjort en reinstall. Ta i så fall vare på pakkene du har kompilert (og kildefilene, hvis du har treg/begrenset linje) Disse finner du i /usr/portage/packages/All og /usr/portage/distfiles.
Men jeg fant de ikke, men .... bash-2.05b# ls /etc/make.*
/etc/make.conf /etc/make.conf.example /etc/make.conf.orig /etc/make.globals ....Gjorde!
Brukte denne: nano -w /etc/make.conf for å få til forandringene, så nå er det blitt gjort :) Takk til Sveini, anderlin og Drall :) thanx dudes
Endret av abze
