Hjelp ! Elendige Benchmarks
snowdogxx
Hei !
Har litt problemer med PC'n, eks noen spill hakker litt selv om oppsettet mitt fint skal klare dem. Eks need for speed underground. Har kjørt en del benchmark tester, bla. Dacris Benchmark 5.0. Jeg får da beskjed om at skjermkortet mitt yter dårlig og at minnet er for raskt for prosessoren. :(
Har en P4 2,53 MHz med 533 systembuss. Hovedkort Aopen AX4PE-MAX, Minnet er Twinmos 2700, 333 mhz, 512 MB. Har også kjørt Aquamark og Codecreatures og på disse testene scorer ytelsen langt under det andre har på tilsvarende maskiner. Skjermkortet er et Hightech Excalibur, Radeon 9500 Pro 128MB.
Noen som har noe tips, under følger rapporten som jeg fikk med Dacris.
snowdogxx
Report
This report has also been saved in Microsoft Excel format (as CSV). To load the CSV file, look in the Dacris Benchmarks folder for Report.csv.
Click here to open the Microsoft Excel report.
Your system's overall grade is: 219 Your system does not need any hardware upgrades yet.
The component with the lowest rating is: 3D Video Speed -- 75
If you're upgrading your system, you should upgrade this component first. NOTE: If this component is 3D Video Speed, you will need to upgrade either the processor or the video card, based on the bottleneck information given later in this report.
Test Result Charts
Test Results
Processor Speed This PC:
4115.25 DacriMarks
Memory Speed This PC:
1274.00 MB/s
Hard Disk Speed This PC:
49.29 MB/s
2D Video Speed This PC:
841.56 MP/s
3D Video Speed This PC:
2.74 MTps
Bottleneck Information
Your memory is a little too fast for your processor. You may wish to upgrade your processor for better performance.
Your hard disk is just right for your processor.
Your video card is just right for your processor.
System Information
Processor: Intel® Pentium® 4 CPU 2.53GHz 2609 MHz
Number of Processors: 1
Processor Supports: MMX, SSE, SSE2
Operating system: Microsoft Windows XP Service Pack 1 (Build 2600)
Free Physical Memory: 261 MB
Total Physical Memory: 512 MB
Total Disk Space: 29.0 GB
Free Disk Space: 841.0 MB
Video Card: RADEON 9500 PRO / 9700
DirectX Version: 9.x
Bits Per Pixel: 32
Printer: Acrobat Distiller
Network Card: Realtek RTL8139 Family PCI Fast Ethernet-kort
Endret av snowdogxx
512MB er ikke for lite, men anbefalt minimum. Ville seriøst gått for 1GB...
Alt over 512MB er foreløpig bortimot overkill for spilling for de fleste ennå. Videoredigering, komprimering, bildebehandling osv. er en helt annen sak, men anbefalt minstekrav for spilling kan jo seriøst ikke være mer enn 256MB.
Uansett... det at trådstarter "bare" har 512MB har ingenting å si med benchmark-resultatene han får.
Jeg ville ha kjøpt litt mer Ram jeg. 512 MB er litt i grenseland med de nyeste spillene nå.
nei nei :no: Har du selv prøvd å kjøre noen benchmarks med 1 GB isteden for 512 MB ram??? Forskjellen er minimal, knapt merkbar i danges spill.
Er mest relevant ved foto/film redigering med enkelte untak....
Har du oppdater skjermkortdrivere installert chipsetdrivere??? Veldig viktig!
