Er dette en bra overklokking?
For det første syntes jeg du burde skrive litt mer detaljert og utfyllende. Brukere her på forumet tar seg ofte bedre tid til å hjelpe dem som har gjort litt mer bakgrunnsarbeid og funnet ut info om det de lurer på...
EDIT:det mener ivertfall jeg.
-correct me if i`m wrong-
Endret av T.F.T
uAMDtool CPU Utility
uAMDtool integrates an accurate AMD Quantispeed PR rating calculator with other commonly used AMD-based tools.
The Quantispeed calculator has full support of Morgan, Palomino, T-Bred, Barton and AMD64 processors, and fully supports overclocked front side bus speeds with unrivalled accuracy for all modes.
Added is a CPU stepping decoder which lists all known details about your specific CPU, a full list of stock AMD AthlonXP and Athlon64 settings so you can see how much performance you're gaining from that higher FSB, and a clutter-free small version which can be invoked from the command line or from the main interface.
Her ser du hvordan p-rating du har
