Leverandør forbyr emule
kingkop
:wow:
En kompis av meg fikk en mail fra sin nettleverandør, Totalnett, om at en klage var mottatt fra Paramount om at IP adressen hans distibuerte copyright materiale (Star Trek serien Enterprise) Dersom han ikke tar skritt for å stanse dette blir han blokkert fra internett.
Dette var vedlagt mailen:
Dear Sir or Madam:
> > BayTSP, Inc. ("BayTSP") swears under penalty of perjury that Paramount
> > Pictures Corporation ("Paramount") has authorized BayTSP to act as its
>agent
> > for copyright infringement notification. BayTSP's search of the protocol
> > listed below has detected infringements of Paramount's copyright
>interests
> > on your IP addresses as detailed in the attached report.
> > BayTSP has reasonable good faith belief that use for the material in the
> > manner complained of in the attached report is not authorized by
>Paramount,
> > its agents, or the law. The information provided herein is accurate to
>the
> > best of our knowledge. Therefore, this letter is an official
>notification
> > under provisions of section 512(a) of the U.S. Digital Millennium
>Copyright
> > Act to effect removal of the detected infringement listed in the
>attached
> > report. The Berne Convention for the Protection of Literary and Artistic
> > Works, the Universal Copyright Convention, as well as bilateral treaties
> > with other countries allow for protection of client's copyrighted work
>even
> > beyond U.S. borders. The attached documentation specifies the exact
>location
> > of the infringement. The Notice ID identifies the copyrighted works by
>file
> > identification number.
> > We hereby request that you immediately remove or block access to the
> > infringing material, as specified in the copyright laws, and insure the
>user
> > refrains from using or sharing with others Paramount's materials in the
> > future.
> > Please send us a prompt response indicating the actions you have taken
>to
> > resolve this matter. Please reference the Notice ID number above in your
> > response.
> > Nothing in this letter shall serve as a waiver of any rights or remedies
>of
> > Paramount with respect to the alleged infringement, all of which are
> > expressly reserved. Should you need to contact me, I may be reached at
>the
> > following address:
> > Mark Ishikawa
> > Chief Executive Officer
> > BayTSP, Inc.
> > PO Box 1314
> > Los Gatos, CA 95031
Kjenner mange som har dette selskapet, Totalnett, og som bruker emule, winmx, kazaa osv. Må jo bare være tilfeldig at denne meget moderate brukeren ble "tatt".
Er det noen som har erfaring med dette eller?
Hvordan skal man forholde seg til dette og kan Totalnett kutte han fra internett???
:angry::angry::angry:
Her slit han litt ja, det er jo mot norsk lov å distribuere beskyttet materiale.
Noe annet er nedlastning, her er det ingenting som forbyr nedlastning av
musikk f,eks, inntil videre ny lov trer i kraft fra 1 mai el 1 juni, da vil dette
også være forbudt i følge norsk lov..
Det er også de som deler ut filer som blir tatt hardest, ikkje de som kun laster ned.
De har nok tatt ham i en stikkprøve (Filmselskapene har folk som sitter og søker etter ulovlige filmer og rapporterer brukere de finner til ISP).
Det er ikke Totalnett som har sjekka emule.
Selvsagt har de full rettighet til å stenge konto hvis fyren sprer piratkopierte filmer (mao deler dem ut i Emule).
Har ingenting å si at ingen har lasta opp filmen fra ham enda. Hvis det er en virkelig stapeis av en admin som har sjekka kompisen din, kan han nok regne med å bli sjekka flere ganger for å se om han hører på tiltale. Hvis han blir tatt pånytt må han finne seg ny leverandør, og får kanskje i tillegg en heftig bot fra Paramount han IKKE slipper unna. Husker hu 12 år gamle jenta i USA som fikk 12000 dollar bot?
Den mailen ISP'n har fått fra Paramount er en av pirathunterne deres som har rapportert. Er selvsagt like enkelt for dem å finne folk som deler ulovlige filmer bare ved å søke på navnet, som det er for deg å finne en film noen andre har delt.
De kan tilogmed blokkere all trafikk hvis du er infisert av virus og sender veldig mye virusmailer ut. Da får du plutselig en mail fra ISP om at internett-tilgangen er sperra inntil du skaffer deg oppdatert viruskiller og blir kvitt viruset.
Endret av Bitex
