gregas Skrevet 8. februar 2004 Del Skrevet 8. februar 2004 (endret) Hei, Har endelig fått til den nye dvd brenneren jeg kjøpte. Det går fint å brenne DVD plater, men det går ikke an å brenne CD plater. Jeg vet ikke om at det et problem med de CD platene jeg har, for jeg hadde akkurat det samme problemetmed CD-R brenneren jeg hadde før jeg gikk til anskaffelse av DVD brenneren. Vedlegger loggen fra Nero 6: Windows XP 5.1 IA32 WinAspi: - ahead WinASPI: File 'C:\Programfiler\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16.12.2003 19:18:06 Nero version: 6.3.0.3 (Nero Express) Recorder: <_NEC DVD_RW ND-1300A> Version: 1.08 - HA 1 TA 1 - 6.3.0.3 Adapter driver: <atapi> HA 1 Drive buffer : 2048kB Bus Type : default (0) -> ATAPI, detected: ATAPI CD-ROM: <SAMSUNG DVD-ROM SD-616T >Version: F308 - HA 1 TA 0 - 6.3.0.3 Adapter driver: <atapi> HA 1 === Scsi-Device-Map === DiskPeripheral : IC35L120AVVA07-0 atapi Port 0 ID 0 DMA: On CdRomPeripheral : SAMSUNG DVD-ROM SD-616T atapi Port 1 ID 0 DMA: On CdRomPeripheral : _NEC DVD_RW ND-1300A atapi Port 1 ID 1 DMA: On === CDRom-Device-Map === SAMSUNG DVD-ROM SD-616T D: CDRom0 _NEC DVD_RW ND-1300A E: CDRom1 ======================= AutoRun : 1 Excluded drive IDs: CmdQueuing : 1 CmdNotification: 2 WriteBufferSize: 83886080 (0) Byte ShowDrvBufStat : 0 EraseSpeed : 0 BUFE : 0 Physical memory : 1023MB (1047556kB) Free physical memory: 664MB (680512kB) Memory in use : 35 % Uncached PFiles: 0x0 Use Static Write Speed Table: 0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 8.2.2004 ===== Disc-Copy over image - 1st step : Copy to image ... 15:44:02 #1 SCSI -601 File Cdrdrv.cpp, Line 1171 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x81 (0x06, SCSI_INVALID_HA) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x1B 0x00 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 15:44:02 #2 SCSI -601 File Cdrdrv.cpp, Line 1171 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x81 (0x06, SCSI_INVALID_HA) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 15:44:02 #3 SCSI -601 File Cdrdrv.cpp, Line 1171 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x81 (0x06, SCSI_INVALID_HA) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x1E 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 15:44:02 #4 SCSI -601 File Cdrdrv.cpp, Line 1171 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x81 (0x06, SCSI_INVALID_HA) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x1B 0x00 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 15:44:30 #5 Text 0 File DlgWaitCD.cpp, Line 245 Write in overburning mode: FALSE 15:44:30 #6 Text 0 File DlgWaitCD.cpp, Line 406 >>> Protocol of DlgWaitCD activities: <<< ========================================= Insert the original disc. (Medium in drive: Unknown. Medium required by compilation: CD-R/RW.) 15:44:30 #7 Text 0 File Reader.cpp, Line 118 Reader running 15:44:30 #8 Phase 48 File dlgbrnst.cpp, Line 1800 Analyzing disc 15:44:30 #9 Text 0 File Writer.cpp, Line 124 Writer Image Recorder running 15:44:31 #10 CDCOPY -1 File CDCopy.cpp, Line 1896 The CD is copyrighted 15:44:31 #11 Text 0 File CDCopy.cpp, Line 2116 _Index0_ _______Index1_______ PostPause ___LastBlockOfTrack_ Track 1: 0 0 ( 0:02.00) 27760 27759 ( 6:12.09) Track 2: 27760 27760 ( 6:12.10) 49380 49379 ( 11:00.29) Track 3: 49380 49380 ( 11:00.30) 72610 72609 ( 16:10.09) Track 4: 72610 72610 ( 16:10.10) 98422 98421 ( 21:54.21) Track 5: 98422 98422 ( 21:54.22) 117589 117588 ( 26:09.63) Track 6: 117589 117589 ( 26:09.64) 139393 139392 ( 31:00.42) Track 7: 139393 139393 ( 31:00.43) 157524 157523 ( 35:02.23) Track 8: 157524 157524 ( 35:02.24) 175681 175680 ( 39:04.30) Track 9: 175681 175681 ( 39:04.31) 197384 197383 ( 43:53.58) Track 10: 197384 197384 ( 43:53.59) 211875 211874 ( 47:06.74) Track 11: 211875 211875 ( 47:07.00) 233403 233402 ( 51:54.02) Track 12: 233403 233403 ( 51:54.03) 254130 254129 ( 56:30.29) Track 13: 254130 254130 ( 56:30.30) 277124 277123 ( 61:36.73) Track 14: 277124 277124 ( 61:36.74) 308915 308914 ( 68:40.64) Track 15: 308915 308915 ( 68:40.65) 322741 322740 ( 71:45.15) Track 16: 322741 322741 ( 71:45.16) 342344 342343 ( 76:06.43) 15:44:31 #12 Text 0 File CDCopy.cpp, Line 840 Copy options: copy on-the-fly: ON read ISRC/MCN: OFF use jitter correction: OFF data options ignore read error: ON write defekt blocks OFF read raw data: OFF read r-w subchannel data: OFF audio options ignore read error: ON read indexes: OFF read r-w subchannel data: OFF source disc does not look like CD Extra 01. 0 - 27760 = 27760, audio (TRM_AUDIO_NOPRE, block size 2352) 02. 27760 - 49380 = 21620, audio (TRM_AUDIO_NOPRE, block size 2352) 03. 49380 - 72610 = 23230, audio (TRM_AUDIO_NOPRE, block size 2352) 04. 72610 - 98422 = 25812, audio (TRM_AUDIO_NOPRE, block size 2352) 05. 98422 - 117589 = 19167, audio (TRM_AUDIO_NOPRE, block size 2352) 06. 117589 - 139393 = 21804, audio (TRM_AUDIO_NOPRE, block size 2352) 07. 139393 - 157524 = 18131, audio (TRM_AUDIO_NOPRE, block size 2352) 08. 157524 - 175681 = 18157, audio (TRM_AUDIO_NOPRE, block size 2352) 09. 175681 - 197384 = 21703, audio (TRM_AUDIO_NOPRE, block size 2352) 10. 197384 - 211875 = 14491, audio (TRM_AUDIO_NOPRE, block size 2352) 11. 211875 - 233403 = 21528, audio (TRM_AUDIO_NOPRE, block size 2352) 12. 233403 - 254130 = 20727, audio (TRM_AUDIO_NOPRE, block size 2352) 13. 254130 - 277124 = 22994, audio (TRM_AUDIO_NOPRE, block size 2352) 14. 277124 - 308915 = 31791, audio (TRM_AUDIO_NOPRE, block size 2352) 15. 308915 - 322741 = 13826, audio (TRM_AUDIO_NOPRE, block size 2352) 16. 322741 - 342344 = 19603, audio (TRM_AUDIO_NOPRE, block size 2352) 15:44:32 #13 Text 0 File Burncd.cpp, Line 3101 Turn on Disc-at-once, using CD-R/RW media 15:44:32 #14 Text 0 File DlgWaitCD.cpp, Line 240 Last possible write address on media: 2147483646 (477218:37.21) Last address to be written: 342343 ( 76:06.43) 15:44:32 #15 Text 0 File DlgWaitCD.cpp, Line 245 Write in overburning mode: FALSE 15:44:32 #16 Text 0 File DlgWaitCD.cpp, Line 2085 Recorder: Image Recorder; CD type reading failed ATIP Data: ? 15:44:32 #17 Text 0 File DlgWaitCD.cpp, Line 406 >>> Protocol of DlgWaitCD activities: <<< ========================================= 15:44:32 #18 Text 0 File ThreadedTransferInterface.cpp, Line 779 Setup items (after recorder preparation) 0: TRM_AUDIO_NOPRE (1 - Audio) 2 indices, index0 (150) not provided original disc pos #0 + 27760 (27760) = #27760/6:10.10 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 27760 blocks [ Image Recorder ] 1: TRM_AUDIO_NOPRE (2 - Audio) 2 indices, index0 (0) provided original disc pos #27760 + 21620 (21620) = #49380/10:58.30 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21620 blocks [ Image Recorder ] 2: TRM_AUDIO_NOPRE (3 - Audio) 2 indices, index0 (0) provided original disc pos #49380 + 23230 (23230) = #72610/16:8.10 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23230 blocks [ Image Recorder ] 3: TRM_AUDIO_NOPRE (4 - Audio) 2 indices, index0 (0) provided original disc pos #72610 + 25812 (25812) = #98422/21:52.22 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25812 blocks [ Image Recorder ] 4: TRM_AUDIO_NOPRE (5 - Audio) 2 indices, index0 (0) provided original disc pos #98422 + 19167 (19167) = #117589/26:7.64 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19167 blocks [ Image Recorder ] 5: TRM_AUDIO_NOPRE (6 - Audio) 2 indices, index0 (0) provided original disc pos #117589 + 21804 (21804) = #139393/30:58.43 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21804 blocks [ Image Recorder ] 6: TRM_AUDIO_NOPRE (7 - Audio) 2 indices, index0 (0) provided original disc pos #139393 + 18131 (18131) = #157524/35:0.24 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18131 blocks [ Image Recorder ] 7: TRM_AUDIO_NOPRE (8 - Audio) 2 indices, index0 (0) provided original disc pos #157524 + 18157 (18157) = #175681/39:2.31 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18157 blocks [ Image Recorder ] 8: TRM_AUDIO_NOPRE (9 - Audio) 2 indices, index0 (0) provided original disc pos #175681 + 21703 (21703) = #197384/43:51.59 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21703 blocks [ Image Recorder ] 9: TRM_AUDIO_NOPRE (10 - Audio) 2 indices, index0 (0) provided original disc pos #197384 + 14491 (14491) = #211875/47:5.0 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14491 blocks [ Image Recorder ] 10: TRM_AUDIO_NOPRE (11 - Audio) 2 indices, index0 (0) provided original disc pos #211875 + 21528 (21528) = #233403/51:52.3 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21528 blocks [ Image Recorder ] 11: TRM_AUDIO_NOPRE (12 - Audio) 2 indices, index0 (0) provided original disc pos #233403 + 20727 (20727) = #254130/56:28.30 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20727 blocks [ Image Recorder ] 12: TRM_AUDIO_NOPRE (13 - Audio) 2 indices, index0 (0) provided original disc pos #254130 + 22994 (22994) = #277124/61:34.74 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22994 blocks [ Image Recorder ] 13: TRM_AUDIO_NOPRE (14 - Audio) 2 indices, index0 (0) provided original disc pos #277124 + 31791 (31791) = #308915/68:38.65 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 31791 blocks [ Image Recorder ] 14: TRM_AUDIO_NOPRE (15 - Audio) 2 indices, index0 (0) provided original disc pos #308915 + 13826 (13826) = #322741/71:43.16 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13826 blocks [ Image Recorder ] 15: TRM_AUDIO_NOPRE (16 - Audio) 2 indices, index0 (0) provided original disc pos #322741 + 19603 (19603) = #342344/76:4.44 relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19603 blocks [ Image Recorder ] -------------------------------------------------------------- 15:44:32 #19 Text 0 File ThreadedTransferInterface.cpp, Line 948 Prepare recorder [ Image Recorder ] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 16: 1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 65644320, ISRC "" 2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 65644320 65644320 116494560, ISRC "" 3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 116494560 116494560 171131520, ISRC "" 4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 171131520 171131520 231841344, ISRC "" 5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 231841344 231841344 276922128, ISRC "" 6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 276922128 276922128 328205136, ISRC "" 7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 328205136 328205136 370849248, ISRC "" 8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 370849248 370849248 413554512, ISRC "" 9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 413554512 413554512 464599968, ISRC "" 10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 464599968 464599968 498682800, ISRC "" 11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 498682800 498682800 549316656, ISRC "" 12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 549316656 549316656 598066560, ISRC "" 13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 598066560 598066560 652148448, ISRC "" 14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 652148448 652148448 726920880, ISRC "" 15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 726920880 726920880 759439632, ISRC "" 16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 759439632 759439632 805545888, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x01 -150 | 1 | 0 | 0x00 | 0x01 0 | 1 | 1 | 0x00 | 0x01 27760 | 2 | 0 | 0x00 | 0x01 27760 | 2 | 1 | 0x00 | 0x01 49380 | 3 | 0 | 0x00 | 0x01 49380 | 3 | 1 | 0x00 | 0x01 72610 | 4 | 0 | 0x00 | 0x01 72610 | 4 | 1 | 0x00 | 0x01 98422 | 5 | 0 | 0x00 | 0x01 98422 | 5 | 1 | 0x00 | 0x01 117589 | 6 | 0 | 0x00 | 0x01 117589 | 6 | 1 | 0x00 | 0x01 139393 | 7 | 0 | 0x00 | 0x01 139393 | 7 | 1 | 0x00 | 0x01 157524 | 8 | 0 | 0x00 | 0x01 157524 | 8 | 1 | 0x00 | 0x01 175681 | 9 | 0 | 0x00 | 0x01 175681 | 9 | 1 | 0x00 | 0x01 197384 | 10 | 0 | 0x00 | 0x01 197384 | 10 | 1 | 0x00 | 0x01 211875 | 11 | 0 | 0x00 | 0x01 211875 | 11 | 1 | 0x00 | 0x01 233403 | 12 | 0 | 0x00 | 0x01 233403 | 12 | 1 | 0x00 | 0x01 254130 | 13 | 0 | 0x00 | 0x01 254130 | 13 | 1 | 0x00 | 0x01 277124 | 14 | 0 | 0x00 | 0x01 277124 | 14 | 1 | 0x00 | 0x01 308915 | 15 | 0 | 0x00 | 0x01 308915 | 15 | 1 | 0x00 | 0x01 322741 | 16 | 0 | 0x00 | 0x01 322741 | 16 | 1 | 0x00 | 0x01 342344 | lead-out | 1 | 0x00 | 0x01 15:44:32 #20 Phase 120 File dlgbrnst.cpp, Line 1800 Creating the image for burning 15:44:32 #21 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0 15:44:32 #22 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #27760): write at #27760 15:44:32 #23 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #49380): write at #49380 15:44:32 #24 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #72610): write at #72610 15:44:32 #25 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 4 (relocatable, no disc pos, no patch infos, orig at #98422): write at #98422 15:44:32 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 5 (relocatable, no disc pos, no patch infos, orig at #117589): write at #117589 15:44:32 #27 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 6 (relocatable, no disc pos, no patch infos, orig at #139393): write at #139393 15:44:32 #28 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 7 (relocatable, no disc pos, no patch infos, orig at #157524): write at #157524 15:44:32 #29 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 8 (relocatable, no disc pos, no patch infos, orig at #175681): write at #175681 15:44:32 #30 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 9 (relocatable, no disc pos, no patch infos, orig at #197384): write at #197384 15:44:32 #31 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 10 (relocatable, no disc pos, no patch infos, orig at #211875): write at #211875 15:44:32 #32 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 11 (relocatable, no disc pos, no patch infos, orig at #233403): write at #233403 15:44:32 #33 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 12 (relocatable, no disc pos, no patch infos, orig at #254130): write at #254130 15:44:32 #34 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 13 (relocatable, no disc pos, no patch infos, orig at #277124): write at #277124 15:44:32 #35 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 14 (relocatable, no disc pos, no patch infos, orig at #308915): write at #308915 15:44:32 #36 Text 0 File ThreadedTransferInterface.cpp, Line 2264 Verifying disc position of item 15 (relocatable, no disc pos, no patch infos, orig at #322741): write at #322741 15:47:50 #37 Text 0 File WriterStatus.cpp, Line 115 < Image Recorder > start writing Lead-Out at LBA 342344 (53948h), lenght 0 blocks 15:47:50 #38 Text 0 File ThreadedTransfer.cpp, Line 229 all writers idle, stopping conversion 15:47:51 #39 Phase 121 File dlgbrnst.cpp, Line 1800 Creating Image completed successfully ===== Disc-Copy over image - 2nd step : Burn the image ... 15:48:08 #1 Phase 75 File dlgbrnst.cpp, Line 1800 JustLink activated 15:48:08 #2 Text 0 File Reader.cpp, Line 118 Reader running 15:48:08 #3 IMAGEGEN -10 File ImageGen.cpp, Line 366 Image was written as DAO. DAOI: MediaCatalogNumber = '' TocType = 0x00 Finalized = 1 First/Last Track = 1 / 16 1: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 0, Index1FilePos = 352800, NextTrackFilePos = 65644320 2: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 65644320, Index1FilePos = 65644320, NextTrackFilePos = 116494560 3: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 116494560, Index1FilePos = 116494560, NextTrackFilePos = 171131520 4: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 171131520, Index1FilePos = 171131520, NextTrackFilePos = 231841344 5: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 231841344, Index1FilePos = 231841344, NextTrackFilePos = 276922128 6: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 276922128, Index1FilePos = 276922128, NextTrackFilePos = 328205136 7: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 328205136, Index1FilePos = 328205136, NextTrackFilePos = 370849248 8: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 370849248, Index1FilePos = 370849248, NextTrackFilePos = 413554512 9: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 413554512, Index1FilePos = 413554512, NextTrackFilePos = 464599968 10: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 464599968, Index1FilePos = 464599968, NextTrackFilePos = 498682800 11: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 498682800, Index1FilePos = 498682800, NextTrackFilePos = 549316656 12: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 549316656, Index1FilePos = 549316656, NextTrackFilePos = 598066560 13: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 598066560, Index1FilePos = 598066560, NextTrackFilePos = 652148448 14: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 652148448, Index1FilePos = 652148448, NextTrackFilePos = 726920880 15: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 726920880, Index1FilePos = 726920880, NextTrackFilePos = 759439632 16: ISRC = '' Blocksize = 2352 TrackMode = 'TRM_AUDIO_NOPRE' TrackConfig = 0x00 First/Last Index = 0 / 1 Index0FilePos = 759439632, Index1FilePos = 759439632, NextTrackFilePos = 805545888 CUES: 0: Ctrl=0x01 Trk= 0 (0x00) Index=00 RecDep=0x00 Start=954437:08.46 ( -150) 1: Ctrl=0x01 Trk= 1 (0x01) Index=00 RecDep=0x00 Start=954437:08.46 ( -150) 2: Ctrl=0x01 Trk= 1 (0x01) Index=01 RecDep=0x00 Start=00:00.00 ( 0) 3: Ctrl=0x01 Trk= 2 (0x02) Index=00 RecDep=0x00 Start=06:10.10 ( 27760) 4: Ctrl=0x01 Trk= 2 (0x02) Index=01 RecDep=0x00 Start=06:10.10 ( 27760) 5: Ctrl=0x01 Trk= 3 (0x03) Index=00 RecDep=0x00 Start=10:58.30 ( 49380) 6: Ctrl=0x01 Trk= 3 (0x03) Index=01 RecDep=0x00 Start=10:58.30 ( 49380) 7: Ctrl=0x01 Trk= 4 (0x04) Index=00 RecDep=0x00 Start=16:08.10 ( 72610) 8: Ctrl=0x01 Trk= 4 (0x04) Index=01 RecDep=0x00 Start=16:08.10 ( 72610) 9: Ctrl=0x01 Trk= 5 (0x05) Index=00 RecDep=0x00 Start=21:52.22 ( 98422) 10: Ctrl=0x01 Trk= 5 (0x05) Index=01 RecDep=0x00 Start=21:52.22 ( 98422) 11: Ctrl=0x01 Trk= 6 (0x06) Index=00 RecDep=0x00 Start=26:07.64 ( 117589) 12: Ctrl=0x01 Trk= 6 (0x06) Index=01 RecDep=0x00 Start=26:07.64 ( 117589) 13: Ctrl=0x01 Trk= 7 (0x07) Index=00 RecDep=0x00 Start=30:58.43 ( 139393) 14: Ctrl=0x01 Trk= 7 (0x07) Index=01 RecDep=0x00 Start=30:58.43 ( 139393) 15: Ctrl=0x01 Trk= 8 (0x08) Index=00 RecDep=0x00 Start=35:00.24 ( 157524) 16: Ctrl=0x01 Trk= 8 (0x08) Index=01 RecDep=0x00 Start=35:00.24 ( 157524) 17: Ctrl=0x01 Trk= 9 (0x09) Index=00 RecDep=0x00 Start=39:02.31 ( 175681) 18: Ctrl=0x01 Trk= 9 (0x09) Index=01 RecDep=0x00 Start=39:02.31 ( 175681) 19: Ctrl=0x01 Trk= 10 (0x10) Index=00 RecDep=0x00 Start=43:51.59 ( 197384) 20: Ctrl=0x01 Trk= 10 (0x10) Index=01 RecDep=0x00 Start=43:51.59 ( 197384) 21: Ctrl=0x01 Trk= 11 (0x11) Index=00 RecDep=0x00 Start=47:05.00 ( 211875) 22: Ctrl=0x01 Trk= 11 (0x11) Index=01 RecDep=0x00 Start=47:05.00 ( 211875) 23: Ctrl=0x01 Trk= 12 (0x12) Index=00 RecDep=0x00 Start=51:52.03 ( 233403) 24: Ctrl=0x01 Trk= 12 (0x12) Index=01 RecDep=0x00 Start=51:52.03 ( 233403) 25: Ctrl=0x01 Trk= 13 (0x13) Index=00 RecDep=0x00 Start=56:28.30 ( 254130) 26: Ctrl=0x01 Trk= 13 (0x13) Index=01 RecDep=0x00 Start=56:28.30 ( 254130) 27: Ctrl=0x01 Trk= 14 (0x14) Index=00 RecDep=0x00 Start=61:34.74 ( 277124) 28: Ctrl=0x01 Trk= 14 (0x14) Index=01 RecDep=0x00 Start=61:34.74 ( 277124) 29: Ctrl=0x01 Trk= 15 (0x15) Index=00 RecDep=0x00 Start=68:38.65 ( 308915) 30: Ctrl=0x01 Trk= 15 (0x15) Index=01 RecDep=0x00 Start=68:38.65 ( 308915) 31: Ctrl=0x01 Trk= 16 (0x16) Index=00 RecDep=0x00 Start=71:43.16 ( 322741) 32: Ctrl=0x01 Trk= 16 (0x16) Index=01 RecDep=0x00 Start=71:43.16 ( 322741) 33: Ctrl=0x01 Trk=110 (0xAA) Index=01 RecDep=0x00 Start=76:04.44 ( 342344) MTYP: Mediumtype = CD (old format) (0x1) Image file name: <C:\Documents and Settings\Georg Oftedal\Mine dokumenter\TempImage.nrg> 15:48:08 #4 Text 0 File Burncd.cpp, Line 3101 Turn on Disc-at-once, using CD-R/RW media 15:48:08 #5 Text 0 File DlgWaitCD.cpp, Line 240 Last possible write address on media: -151 (954437:10.45) Last address to be written: 342343 ( 76:06.43) 15:48:08 #6 Text 0 File DlgWaitCD.cpp, Line 245 Write in overburning mode: FALSE 15:48:08 #7 Text 0 File DlgWaitCD.cpp, Line 2085 Recorder: _NEC DVD_RW ND-1300A; CDR code: 00 97 27 00; OSJ entry from: DIGITAL STORAGE TECHNOLOGY CO.,LTD ATIP Data: Special Info [hex] 1: 80 00 80, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00) Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid) 15:48:08 #8 Text 0 File DlgWaitCD.cpp, Line 406 >>> Protocol of DlgWaitCD activities: <<< ========================================= 15:48:08 #9 Text 0 File ThreadedTransferInterface.cpp, Line 779 Setup items (after recorder preparation) 0: TRM_AUDIO_NOPRE (1 - Audio) 2 indices, index0 (150) provided original disc pos #0 + 27760 (27760) = #27760/6:10.10 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 27760 blocks [_NEC DVD_RW ND-1300A ] 1: TRM_AUDIO_NOPRE (2 - Audio) 2 indices, index0 (0) not provided original disc pos #27760 + 21620 (21620) = #49380/10:58.30 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21620 blocks [_NEC DVD_RW ND-1300A ] 2: TRM_AUDIO_NOPRE (3 - Audio) 2 indices, index0 (0) not provided original disc pos #49380 + 23230 (23230) = #72610/16:8.10 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 23230 blocks [_NEC DVD_RW ND-1300A ] 3: TRM_AUDIO_NOPRE (4 - Audio) 2 indices, index0 (0) not provided original disc pos #72610 + 25812 (25812) = #98422/21:52.22 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 25812 blocks [_NEC DVD_RW ND-1300A ] 4: TRM_AUDIO_NOPRE (5 - Audio) 2 indices, index0 (0) not provided original disc pos #98422 + 19167 (19167) = #117589/26:7.64 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19167 blocks [_NEC DVD_RW ND-1300A ] 5: TRM_AUDIO_NOPRE (6 - Audio) 2 indices, index0 (0) not provided original disc pos #117589 + 21804 (21804) = #139393/30:58.43 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21804 blocks [_NEC DVD_RW ND-1300A ] 6: TRM_AUDIO_NOPRE (7 - Audio) 2 indices, index0 (0) not provided original disc pos #139393 + 18131 (18131) = #157524/35:0.24 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18131 blocks [_NEC DVD_RW ND-1300A ] 7: TRM_AUDIO_NOPRE (8 - Audio) 2 indices, index0 (0) not provided original disc pos #157524 + 18157 (18157) = #175681/39:2.31 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 18157 blocks [_NEC DVD_RW ND-1300A ] 8: TRM_AUDIO_NOPRE (9 - Audio) 2 indices, index0 (0) not provided original disc pos #175681 + 21703 (21703) = #197384/43:51.59 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21703 blocks [_NEC DVD_RW ND-1300A ] 9: TRM_AUDIO_NOPRE (10 - Audio) 2 indices, index0 (0) not provided original disc pos #197384 + 14491 (14491) = #211875/47:5.0 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 14491 blocks [_NEC DVD_RW ND-1300A ] 10: TRM_AUDIO_NOPRE (11 - Audio) 2 indices, index0 (0) not provided original disc pos #211875 + 21528 (21528) = #233403/51:52.3 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 21528 blocks [_NEC DVD_RW ND-1300A ] 11: TRM_AUDIO_NOPRE (12 - Audio) 2 indices, index0 (0) not provided original disc pos #233403 + 20727 (20727) = #254130/56:28.30 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20727 blocks [_NEC DVD_RW ND-1300A ] 12: TRM_AUDIO_NOPRE (13 - Audio) 2 indices, index0 (0) not provided original disc pos #254130 + 22994 (22994) = #277124/61:34.74 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22994 blocks [_NEC DVD_RW ND-1300A ] 13: TRM_AUDIO_NOPRE (14 - Audio) 2 indices, index0 (0) not provided original disc pos #277124 + 31791 (31791) = #308915/68:38.65 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 31791 blocks [_NEC DVD_RW ND-1300A ] 14: TRM_AUDIO_NOPRE (15 - Audio) 2 indices, index0 (0) not provided original disc pos #308915 + 13826 (13826) = #322741/71:43.16 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 13826 blocks [_NEC DVD_RW ND-1300A ] 15: TRM_AUDIO_NOPRE (16 - Audio) 2 indices, index0 (0) not provided original disc pos #322741 + 19603 (19603) = #342344/76:4.44 not relocatable, disc pos for caching/writing not required/not required, no patch infos -> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 19603 blocks [_NEC DVD_RW ND-1300A ] -------------------------------------------------------------- 15:48:08 #10 Text 0 File ThreadedTransferInterface.cpp, Line 948 Prepare recorder [_NEC DVD_RW ND-1300A ] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 16: 1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 65644320, ISRC "" 2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 65644320 65644320 116494560, ISRC "" 3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 116494560 116494560 171131520, ISRC "" 4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 171131520 171131520 231841344, ISRC "" 5: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 231841344 231841344 276922128, ISRC "" 6: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 276922128 276922128 328205136, ISRC "" 7: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 328205136 328205136 370849248, ISRC "" 8: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 370849248 370849248 413554512, ISRC "" 9: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 413554512 413554512 464599968, ISRC "" 10: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 464599968 464599968 498682800, ISRC "" 11: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 498682800 498682800 549316656, ISRC "" 12: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 549316656 549316656 598066560, ISRC "" 13: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 598066560 598066560 652148448, ISRC "" 14: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 652148448 652148448 726920880, ISRC "" 15: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 726920880 726920880 759439632, ISRC "" 16: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 759439632 759439632 805545888, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_ -150 | lead-in | 0 | 0x00 | 0x01 -150 | 1 | 0 | 0x00 | 0x01 0 | 1 | 1 | 0x00 | 0x01 27760 | 2 | 0 | 0x00 | 0x01 27760 | 2 | 1 | 0x00 | 0x01 49380 | 3 | 0 | 0x00 | 0x01 49380 | 3 | 1 | 0x00 | 0x01 72610 | 4 | 0 | 0x00 | 0x01 72610 | 4 | 1 | 0x00 | 0x01 98422 | 5 | 0 | 0x00 | 0x01 98422 | 5 | 1 | 0x00 | 0x01 117589 | 6 | 0 | 0x00 | 0x01 117589 | 6 | 1 | 0x00 | 0x01 139393 | 7 | 0 | 0x00 | 0x01 139393 | 7 | 1 | 0x00 | 0x01 157524 | 8 | 0 | 0x00 | 0x01 157524 | 8 | 1 | 0x00 | 0x01 175681 | 9 | 0 | 0x00 | 0x01 175681 | 9 | 1 | 0x00 | 0x01 197384 | 10 | 0 | 0x00 | 0x01 197384 | 10 | 1 | 0x00 | 0x01 211875 | 11 | 0 | 0x00 | 0x01 211875 | 11 | 1 | 0x00 | 0x01 233403 | 12 | 0 | 0x00 | 0x01 233403 | 12 | 1 | 0x00 | 0x01 254130 | 13 | 0 | 0x00 | 0x01 254130 | 13 | 1 | 0x00 | 0x01 277124 | 14 | 0 | 0x00 | 0x01 277124 | 14 | 1 | 0x00 | 0x01 308915 | 15 | 0 | 0x00 | 0x01 308915 | 15 | 1 | 0x00 | 0x01 322741 | 16 | 0 | 0x00 | 0x01 322741 | 16 | 1 | 0x00 | 0x01 342344 | lead-out | 1 | 0x00 | 0x01 15:57:29 #11 Phase 36 File dlgbrnst.cpp, Line 1800 Burn process started at 16x (2 400 KB/s) 15:57:29 #12 SCSI -601 File Cdrdrv.cpp, Line 1171 SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03DD2330 Status: 0x81 (0x06, SCSI_INVALID_HA) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x5A 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x48 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 15:57:29 #13 CDR -601 File ThreadedTransferInterface.cpp, Line 1428 Specified host adapter invalid _NEC DVD_RW ND-1300A\H1 T1 15:57:29 #14 Phase 38 File dlgbrnst.cpp, Line 1800 Burn process failed at 16x (2 400 KB/s) 15:57:29 #15 SCSI -601 File Cdrdrv.cpp, Line 1171 SCSI Exec, HA 1, TA 1, LUN 0 Status: 0x81 (0x06, SCSI_INVALID_HA) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 15:57:29 #16 SCSI -601 File Cdrdrv.cpp, Line 1171 SCSI Exec, HA 1, TA 1, LUN 0 Status: 0x81 (0x06, SCSI_INVALID_HA) HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 CDB Data: 0x1E 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 Existing drivers: File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 17.08.2001 23:07:32 File 'Drivers\CDRALW2K.SYS': Ver=5.3.2.34, size=23420 bytes, created 10.02.2003 14:08:14 File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 29.08.2002 09:27:50 (Adapter driver for rec) Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) I dette tilfellet prøvde jeg å kopiere en musikk cd, først on the fly, men det gikk ikke, så med image, men det gikk heller ikke. Håper at dere forstår mer av dette enn jeg. På forhånd takk. Endret 8. februar 2004 av gregas Lenke til kommentar
Skandinav Skrevet 8. februar 2004 Del Skrevet 8. februar 2004 Jeg ser problemet ditt, jeg har opplevd samme problemer selv. Det skal være sagt først at NEC sine brennere er ikke High-End direkte. Noen får det til å fungere kjempebra, andre som deg og meg får problemer. Etter et antall timer lesing i forskjellige forums så er svaret entydig. NEC+NERO=OFTE ERROR. Nec har en tendens å ikke brenne lavkvalitets plater. Fint skal det være, nemlig helst den dyrere sorten. Ved å oppdatere firmware i brenneren kan det hjelpe noe, men jeg ville anbefale å teste et annet brennerprogram.Som det kan sees i loggen nedenfor så finnes det ikke noen åpenbare årsker til at det skjer, annet enn at NEC ikke liker den delen som er kursiv, nemlig platen i seg selv. Lykke til 15:57:29 #11 Phase 36 File dlgbrnst.cpp, Line 1800 Burn process started at 16x (2 400 KB/s) 15:57:29 #12 SCSI -601 File Cdrdrv.cpp, Line 1171 SCSI Exec, HA 1, TA 1, LUN 0, buffer 0x03DD2330 Status: 0x81 (0x06, SCSI_INVALID_HA) CDB Data: 0x5A 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x48 0x00 Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x26 0x02 HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED) TA-Status 0x00 (0x00, OK) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x26 Sense Qual: 0x02 15:57:29 #13 CDR -601 File ThreadedTransferInterface.cpp, Line 1428 Specified host adapter invalid _NEC DVD_RW ND-1300A\H1 T1 15:57:29 #14 Phase 38 File dlgbrnst.cpp, Line 1800 Burn process failed at 16x (2 400 KB/s) Lenke til kommentar
gregas Skrevet 8. februar 2004 Forfatter Del Skrevet 8. februar 2004 Ok. Hvilket annet brenneprogram vil du anbefale ? Lenke til kommentar
Skandinav Skrevet 8. februar 2004 Del Skrevet 8. februar 2004 Jeg bruker Nero til å lage ISO, siden brenner jeg ISO'n med DVD Decrypter http://www.dvddecrypter.com/ til cd bruker jeg Nero 6.3, jeg får det til å fungere med modifisert Firmware til NEC Lenke til kommentar
Gjest Slettet-qfohT7 Skrevet 24. februar 2004 Del Skrevet 24. februar 2004 Jeg bruker også dvd-decrypter til å brenne DVD-plater med min NEC brenner., og det virker smertefritt, men jeg har heller aldri hatt problemer med Nero. Nå bruker jeg bare Thats Write4x plater, og de har jeg heller aldri hatt problemer med, selv om de kanskje ikke er verdens beste kvalitet..? har fått power calibration error én gang, så du kan jo også evt. prøve noen andre plater Lenke til kommentar
OC-Freak Skrevet 24. februar 2004 Del Skrevet 24. februar 2004 CDR code: 00 97 27 00; OSJ entry from: DIGITAL STORAGE TECHNOLOGY CO.,LTD ATIP Data: Special Info [hex] 1: 80 00 80, 2: 00 00 00 (LI 0:00.00), 3: 00 00 00 (LO 0:00.00) Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid) Digital storage technology er en av de dårligste produsentene av media - det er en mulig grunn til problemene. Lenke til kommentar
erikos Skrevet 24. februar 2004 Del Skrevet 24. februar 2004 (endret) Ingen som nevner brenne proge easy CD & DVD Creator her.. har alderig hatt så mye som en feil brenning,,,, men derimot nero har gått ofte skjeis. Bare ett lite hint Endret 24. februar 2004 av erikos Lenke til kommentar
