dårlig?
Kan noen fortelle meg hva som er negativt ved dette? (Annet enn at det er en stasjonær prosessor.....)
CPU - Intel Pentium 4 Processors Willamette/mPGA 478 Socket- Support upto Willamette P4 1.7GHz (Throttling) / Northwood above 2.0 GHz(Throttling)- FSB 400MHz /PC133
Chipset - Intel 845 +ICH2
L2 Cache - 256KB
System BIOS - Flash EPROM (Include System BIOS and VGA BIOS)- ACPI 1.0b; DMI 2.3.1 compliant
Memory - 0MB SDRAM on board; Expandable to 1024MB- Expandable with combination of optional 64MB/128MB/256MB/512MB memory- Two 144-pin SDRAM SO-DIMM Memory Module, PC-133 specifications
ROM Drive - 12.7mm Height- 24X CD ROM Drive- 8X DVD ROM Drive-
HDD - 2.5" 9.5 mm height: 10GB; Support Ultra DMA 66/100- Reseller Exchangeable
Ext. FDD - Support External FDD w/z USB I/F; 3.5" Format for 720KB/1.2MB/1.44MB
Display - 14.1” XGA TFT display; Resolution: 1024x768- 14.1” SXGA+ TFT display; Resolution: 1280x1024
Video Controller - ATi Mobility M6-D integrated 16MB DDR SDRAM - Support Multi Monitor- Support AGP 4X
Keyboard - 19mm pitch/3.0mm stroke - Windows Logo Key x 1; Application Key x 1
Button - 5x Easy Start Buttons (functions defined by user)- 1x Mail Received Button
Pointing Device - Glide pad with 2x buttons and 1x scroll button
PCMCIA - Type II or Type I x1- CardBus Support
Audio System - Sound Blaster Pro compatible- Built-in mono microphone- Support AC97 2.1- 2X Speakers (1Watt each)
I/O Port - Bi-directional Parallel Port (EPP/ECP) x 1- Standard USB1.1 port x 2- RJ-11 port x 1- RJ-45 port x 1 - IR port x1, complies with IrDA 1.1- DC input x 1- VGA monitor port x1- Audio-out x 1 (SPIDF)- Mic-in x 1- Hardware Volume Control- IEEE1394a Port x 1- S-Video Out Port x 1 (NTSC/PAL)
Communication - Built-in 56Kbps V.90 MDC modem- Built-in 10/100 based-T LAN
Power Supply - 9-cell Li-ion (2000mAH/3.7V)- User swappable- Battery Life: 1.5 hrs- Support Power off charge : 3hr ,80% in 1.6Hrs- Support Power on charge : 4hr~5.5hr,
AC adapter Universal AC adapter 90W ; Input: 100-240V, 50/60Hz AC
Dimensions Dimension 313 x 263 x 36/41 mm
Weight 2.95kg
Accessories Power Cord, AC Adapter, RJ-11 Phone Cable, Manual, System Driver CD-Title
Architecture Support PC2001 Specification, Designed for Windows ME, Windows 2000 & Windows XP
Options 64/128MB/256MB/512MB SDRAM, 9-cell Li-ION Battery Pack, AC Adapter w/o Power Cord, Notebook
