mysql_fetch_array() problem
Lager en side for å administrere en treningsdagbok for seilere. Her er koden:
<?php
echo('
<html>
<head>
<title>Treningsdagbok</title>
</head>
<body>
<H1>Treningsdagbok</H1>
  $id = $_POST['ID'];
  $password = $_POST['Passord'];
  $database = 'treningsdagbok';
  $table = $_POST['ID'];
  /* Kopler til og velger database */
  $link = mysql_connect("localhost", "stduser", "sensur");
  //    or die("Kan ikke kople til : " . mysql_error());
  $db=mysql_select_db("$database"); //or die("Finner ikke database")
  /* Sender SQL spørring om medlemsinfo, samt kontrollerer passord*/
  $row=(mysql_fetch_array(mysql_query('SELECT Passwd FROM users WHERE id='.$id)));
  if ($password=$row['Passwd']){
  $query = "SELECT * FROM $table";
  $result = mysql_query($query) or die("Spørring feilet : " . mysql_error());
   /* Skriver ut resultatet til HTML */
echo "<table border>\n<tr>";
$fields = mysql_list_fields($database, $table);
$columns = mysql_num_fields($fields);
for ($i = 0; $i < $columns; $i++)
  { echo "<th>" . mysql_field_name($fields, $i) .  "</th>"; }
echo "</tr>";
  while ($line = mysql_fetch_array($result, MYSQL_ASSOC)) {
      print "\t<tr>\n";
      foreach ($line as $col_value) {
          print "\t\t<td>$col_value</td>\n";
      print "\t</tr>\n";
  print "</table>\n";
  /* Frigjør minne */
  mysql_free_result($result);
  mysql_free_result($result_pass);
  /* Lukker forbindelse */
  mysql_close($link);
  echo('
<p>
For å legge til ny registrering, vennligst bruk skjemaet under.
</p>
<p>
<form action="medlemsupdate.php" method="post">
ID:* <input type="text" name="ID" size="5"> <br>
Passord:* <input type="password" name="Passwd" size="5"> <br>
Dato: <input type="text" name="Dato" size="20"> <br>
Vind: <input type="text" name="Vind" size="20"> <br>
Bølger: <input type="text" name="Bølger" size="20"> <br>
Strøm: <input type="text" name="Strøm" size="4"> <br>
Sted: <input type="text" name="Sted" size="20"> <br>
Mast: <input type="text" name="Mast" size="10"> <br>
Uthal: <input type="text" name="Uthal" size="8"> <br>
Innhal: <input type="text" name="Innhal" value=""> <br>
Chunningham: <input type="text" name="Chunningham" value=""> <br>
Kick: <input type="text" name="Kick" value=""> <br>
Seil: <input type="text" name="Seil" value=""> <br>
Erfaringer: <input type="text" name="Erfaringer" value=""> <br>
<input type="submit">
 else {
 echo('Passordet er feil. Vennligst prøv igjen.');
</form>
</p>
</body>
</html>
Når jeg kjører den får jeg:
Warning: mysql_fetch_array(): supplied argument is not a valid MySQL result resource in D:\Programfiler\Apache Group\Apache2\htdocs\Treningsdagbok\View.php on line 28
Selv om passordet er riktig. Noen tips?
Linje 28:
Endret av muffe
i alle tilfeller bør man nok ikke oppgi brukernavn og passord til mysqldatabaser... :) mysql_fetch_array fungerer ikke fordi scriptet finner ingen mysql database - rett og slett fordi den ikke får logget inn, noe som igjen er følgene av at passordet ikke fungerer.
Gjest Slettet-rXRozPkg
Formen:
PHP:
Bytt til:
$password = $_POST['Passwd'];
legg til denne linja etter du har prøvd å koble til databasen og kjørt den første spørringa:
echo "DB-Feil: ".mysql_error();
Hva står det da?
Endret av Slettet-rXRozPkg
I see with my little eye an ERROR... eller.no
Du har glemt en ' i den første spørringa (og lagt til en . som ikke skal være der):
Rett denne til:
$row=(mysql_fetch_array(mysql_query("SELECT Passwd FROM users WHERE id='$id'")));
