Hjelp! BF1942 Hakker!
:dontgetit: Jamen, det skulle jo holde!
BF1942 Systemkrav:
MINIMUM CONFIGURATION
- 500 MHz CPU
- 128 Megabytes of RAM
- 3D accelerated 32 MB video card or equivalent with HTL and a 24-bit z-buffer
- 160 MB free hard disk space plus space for saved games
- 16X Speed CD-ROM/DVD-ROM
- DirectX 8 Compatible Sound Card
- MS compatible mouse
- Keyboard
Recommended
- 800 MHz CPU
- 256 Megabytes of RAM
- 3D accelerated 64 MB video card or equivalent with HTL and a 24-bit z-buffer
- Keyboard
Required Operating Systems:
- Windows 98, Windows ME, Windows XP or Windows 2000 Note that Windows 95 is not supported
Du får det nok til med litt godvilje og patching...
pass på å slå av vsync pluss hardware acc på lyden og sett ned grafikken til 800x600 16 bit..
er ikke sikker om det vil gå bedre men det fikset mye av problemet og patche hos meg. :thumbs:
Jeg har jo COD(Call Of Duty) innpå pcn, det funker jo helt fint på noe med 1000 i oppløsning 1284x800 eller noe sånnt!
3D Hardware Accelerator Card required – 100% DirectX® 9.0a compatible 32MB Hardware T&L-capable video card and drivers*
Pentium® III 700 or Athlon™processor or higher
English version of Microsoft® Windows® 98/98SE/ME/2000/XP
128MB of RAM
8x Speed CD-ROM drive (1200KB/sec sustained transfer rate) and drivers
181MB of uncompressed free hard disk space (plus 200MB for Windows swap file)
100% DirectX® 9.0a compatible 16 bit sound card and drivers
100% Windows® 98/98SE/ME/2000/XP compatible mouse, keyboard and drivers
DirectX® 9.0a (not included)
Important Note: *Some 3D accelerator cards with the chipset's listed here may not be compatible with the 3D acceleration features utilized by Call Of Duty. Please refer to your hardware manufacturer for 100% DirectX 9.0 compatibility.
SUPPORTED CHIPSETS:
ATI® Radeon 7200, 8500, 9000, 9500, 9700, 9800
All NVidia® GeForce™/Geforce FX chipset's
RECOMMENDED
Pentium® III 1000 or Athlon™processor or higher
Graphics NVidia Geforce/ FX or Ati Radeon = 128 mb or higher
256MB of RAM
52x Speed CD-ROM drive
:dontgetit:
Trådstarter: Post de innstillinger du kjører spillet på, så blir det lettere å fastslå hva du bør gjøre for å løse problemet.
Dessuten - ditt system er ikke av de hissigste, og BF krever mye for å gå glatt. Kombinasjonen av minne, prosessor og tildels grafikkort er ikke sterk nok.
Tilbake til topic; du skal kunne kjøre BF greit nok med systemet ditt. Jeg har en liten mistanke om at det kan være lydkortet ditt som skaper hakkingen - hva slags kort har du?
Lydkort (og for gode lydinnstillinger) er en av de vanligste årsakene til hakking/problemer i Refractor2-motoren som BF benytter.
[EDIT:]
Ser at harddiskene dine er svært små, og kanskje derfor også gamle? Hva slags harddisker er det - fortell oss merke, RPM og cache er du snill :)
HD kan også være en kilde til problemer, oppgraderte selv fra 5400 2MB til 7200 8MB, og WOW :D
Endret av Berrern
