MySQL problem
Se om denne funker:
How to Reset a Forgotten Password
If you have forgotten the root user password for MySQL, you can restore it
with the following procedure:
1. Take down the mysqld server by sending a kill (not kill -9) to the
mysqld server. The pid is stored in a .pid file, which is normally in the
MySQL database directory:
kill `cat /mysql-data-directory/hostname.pid`
You must be either the Unix root user or the same user the server runs as to
do this.
2. Restart mysqld with the --skip-grant-tables option.
3. Connect to the mysqld server with mysql -h hostname mysql and change
the password with a GRANT command. See GRANT. You can also do this with
mysqladmin -h hostname -u user password 'new password'
4. Load the privilege tables with: mysqladmin -h hostname flush-privileges
or with the SQL command FLUSH PRIVILEGES.
Note that after you started mysqld with --skip-grant-tables, any usage of
GRANT commands will give you an Unknown command error until you have
executed FLUSH PRIVILEGES.
there's a really good MySQL help file for stuff like this you can download
from www.mysql.com (or else just search the online version on the website).
