Tja, hva kalles dette? variabelskifte?
class IrcAction
public:
IrcAction(std::string s, std::string c, std::string t, std::string m)
 unsigned int pos = s.find("!",1);
 if(pos == std::string::npos) return;
 sender[0] = s.substr(1,pos-1);
 sender[1] = s.substr(pos+1,s.find("@",pos+1)-1);
 sender[2] = s.substr(s.find("@",pos+1)+1);
 command   = c;
 target    = t;
 msg       = m;
} // IrcAction constructor
std::string getAction(void)
 return command;
~IrcAction()
 delete sender;
 delete command;
 delete target;
 delete msg;
} // IrcAction destructor
private:
std::string sender [3];
std::string command;
std::string target;
std::string msg;
strlist strl = Explode(data, ' ');
     IrcAction irc(strl.getValue(0), strl.getValue(1), strl.getValue(2), Implode(strl, ' ', 3));
     switch(irc.getAction())
     	case "QUIT":
       QUIT(sender, action, target, msg);
       break;
     	case "PART":
       //action.part();
       break;
     	case "TOPIC":
       //action.topic();
       break;
     	case "KICK":
       //action.kick();
       break;
     	case "PRIVMSG":
       //action.privmsg();
       break;
     	case "NOTICE":
       //action.notice();
          break;
         case "376": // 376 = end of MOTD = we are in!
         perform(sockfd, BMAX, lastmsg);
       break;
         default:
          break;
Målet er at jeg vil kunne få tak i de forskjellige variablene på en enkel måte.
Dette er fordi jeg skal skrive logger osv, og da ville det vært kjekt å kunne skrive
// sender[0] = nick, sender[1] = ident, sender[2] = adresse
IrcAction irc;
cout << irc::getVar(sender[0]) << " (" << irc::getVar(sender[2]) << ") sendte " << irc::getVar(command) << " til " << irc::getVar(target) << " med meldingen " << irc::getVar(msg) << '\n';
Endret av Nazgul
