gamerman Skrevet 24. januar 2004 Del Skrevet 24. januar 2004 Hallo Når jeg trykker ctrl+alt+del og går på processes så ser jeg noe som heter svchost.exe, det er fire stykker. Slik er det på min Processes svchost.exe SYSTEM 00 1 584 K svchost.exe SYSTEM 00 8 736 K svchost.exe LOCAL SERVICE 00 752 K svchost.exe SYSTEM 00 1 524 K Når jeg trykker end på hver og en , så etter ca 5 sec så kommer den samme beskjeden som kommer viss man har Blaster viruset om at pc slår seg av på 1 min. Hva er dette? Kan noen hjelpe meg? Takker For Svar Lenke til kommentar
Zeph Skrevet 24. januar 2004 Del Skrevet 24. januar 2004 (endret) Svchost (1) Svchost.exe (Microsoft) Service Host – Generic Host Process for Win32 Services. Windows 2000/XP/2003 only. SVCHOST is a generic process which acts as a host for processes that run from DLLs rather than EXEs. At startup SVCHOST checks the Services portion of the Registry to construct a list of DLL-based services that it needs to load, and then loads them. There can be many instances of SVCHOST running, as there will be one instance of SVCHOST for every DLL-based service or grouping of services (the grouping of services is determined by the programmers who wrote the services in question). Under Windows XP Professional and Windows 2003 you can find out what DLL-based services SVCHOST is running by typing Tasklist /SVC at a Command/MS-DOS Prompt (this command is not available in Windows XP Home), while under Windows 2000 you need to use the TLIST –s command from a Command Prompt (MS-DOS Prompt). Recommendation : An integral part of the operating system, leave alone – multiple instances of SVCHOST is a normal occurrence. If you experience SVCHOST errors, the problem is most likely not with SVCHOST but with the DLLs it is hosting. ---------------------------------------------------------------------------------- Svchost (2) SVCHOST.EXE (???) Many viruses masquerade themselves as SVCHOST to escape detection. Some have names that are similar, such as SCCHOST, while others actually drop a program file called SVCHOST in the Windows or Windows System directory. Recommendation : The first recommendation is a simple one : always have a good antivirus product which is regularly updated (automatically preferably) and always renew your updates subscription when it expires. To detect if you have a virus that calls itself SVCHOST, first see if it shows up in The Ultimate Troubleshooter – if it does, then it is almost certain you have a virus. Secondly, if you have Windows 95/98/ME rather than WinNT4/2000/XP, then it is almost certain you have a virus. Thirdly, go to "Control Panel \ Administrative Tools \ Services" and look for any of the following services – if you find any of them, then you probably have a virus : System Important Message service Endret 24. januar 2004 av zeph Lenke til kommentar
Paulex Skrevet 24. januar 2004 Del Skrevet 24. januar 2004 Det hadde jeg. Det gjorde slik at internetten ble fucka. Lenke til kommentar
