Widget til PC5
Hei.
Hvor kjøper jeg widget til PC5 billigst?
Er software bra?
Tittet på http://www.lynxdv.com
Noen formening om dette? Lest her før at mange har problemer med DV-in!
Kan man copiere software og dermed bruke det flere ganger. Har flere kameraer.
Q. Can I enable more than one Camcorder?
A. No, only one camcorder can be enabled for DVin with each piece of software. If you want to enable more than one camcorder, you can purchase additional copies of the DVin software from the Members Area, where like other products, you get massive discounts. The reason you cannot enable more than one camcorder is because the software stores the information about your camcorder, and most importantly, what it changed, in it's program memory, therefore it is not possible to enable multiple camcorders at the same time.
