XF86Config-oppsett for X-klienter
Jeg tenker å sette opp FreeBSD-boksen min som X-klient. Spørsmålet er hvordan XF86Config skal se ut. Grafikkortet i den boksen spiller jo ingen rolle, hvordan gjør jeg det da?
Det blir aktuelt både med vanlig X11-protokoll og vnc-lignende program.
Hva mer må jeg sette opp?
Vet ikke om *bsd har en annen form for XF86config fil men hadde du lest FAQ'en hadde du funnet dette:
Ett eksempel på en "Clean" XFree86Config
#  XFree86 Config
#	--av Klette--
# Testet på:
#  Redhat9
# Specs:
#	Geforce4 Ti4400
#	Acer 712 ( lcd/tft )
#	DVi tilkoblet
#       Nyeste Nvidia driverne
###########################29/4-2003#
# Server
Section "ServerLayout"
Identifier     "Default Layout"
Screen      0  "Screen0" 0 0
InputDevice    "Mouse0" "CorePointer"
InputDevice    "Keyboard0" "CoreKeyboard"
EndSection
#Files
Section "Files"
RgbPath      "/usr/X11R6/lib/X11/rgb"
FontPath     "unix/:7100"
EndSection
#Modules
Section "Module"
Load  "dbe"
Load  "extmod"
Load  "fbdevhw"
Load  "glx"
Load  "record"
Load  "freetype"
Load  "type1"
EndSection
#Keyboard
Section "InputDevice"
Identifier  "Keyboard0"
Driver      "keyboard"
Option     "XkbRules" "xfree86"
Option     "XkbModel" "pc105"
Option     "XkbLayout" "no"
EndSection
#Mouse
Identifier  "Mouse0"
Driver      "mouse"
Option     "Protocol" "IMPS/2"
Option     "Device" "/dev/input/mice"
Option     "ZAxisMapping" "4 5"
Option     "Emulate3Buttons" "no"
EndSection
Identifier  "DevInputMice"
Driver      "mouse"
EndSection
#Monitor
Section "Monitor"
Identifier   "Monitor0"
VendorName   "Monitor Vendor"
ModelName    "DDCPROBED"
DisplaySize  340	270
HorizSync    24.0 - 80.0
VertRefresh  56.0 - 75.0
Option     "dpms"
EndSection
#Gfx Card
Section "Device"
Identifier  "Videocard0"
Driver      "nvidia"
VendorName  "Videocard vendor"
BoardName   "NVIDIA GeForce 4 (generic)"
Option "ConnectedMonitor" "DFP"
EndSection
# GfxCard vs Monitor
Section "Screen"
Identifier "Screen0"
Device     "Videocard0"
Monitor    "Monitor0"
DefaultDepth     24
SubSection "Display"
 Depth     24
 Modes    "1280x1024" "1280x960" "1152x864" "1024x768" "800x600" "640x480"
EndSubSection
EndSection
# DRI ( sux )
Section "DRI"
Group        0
Mode         0666
EndSection
Si ifra om feil e.l
Hvis du har ett standard skjermkort har vel freebsd noen standard drivere som fungerer, skal du ha opengl støtte og slikt på du legge inn drivere. Se nvidia.com for mer info om install... Som regel slipper du å redigere XF86config filen, den redigerer og tilpasser freebsd selv under install, ikke sant? Moyner? :p
xf86cfg gjør jobben for å lage en enkel config-fil. Den autodetecter slik at du kan stille inn oppløsning og slikt i et grafisk miljø med twm. De innebyggede driverene i XFree ligger der enda og er de samme som til linux. En konfigfil som er laget på en linux-maskin fungerer som oftest uten plunder på BSD.
Nå er ikke jeg 100% sikker om du vil ha annen infomasjon om X - klient/server system
På X-klienten trenger du ikke mer en X. Da kan du logge inn via X11 protocollen ved å bruke
X -query ip-til-serveren
På X-serveren trenger du en logg inn verktøy som kdm eller xdm som jeg bruker selv. Får å få den til å motta forbindelser fra andre maskiner må du endre X sikkerhets instillingene, siden disse ikke godtar dette per default.
Hmm jeg forklarte kansje litt for lite,
X-klienter kjører programmene, X-servere leverer tjenester som tastatur og monitor.
Jeg har lett litt rundt og funnet svar her:
http://www.xs4all.nl/~zweije/xauth.html
http://www.tldp.org/HOWTO/XDMCP-HOWTO/index.html
http://www.tldp.org/HOWTO/XDM-Xterm/index.html
Jeg vil kjøre programmer på FreeBSD-boksen, og ha skjermbildet på Windows-maskina.
I går installerte jeg Cygwin, og det er fantastisk tøft!
