Netlimiter angir syv programmer
joro
Har akkurat innstallert netlimiter og den angir at det er syv programmer som bruker adsllinja mi. Ieksplorer og msn er grei men kan noen fortelle hva disse programmene er og hva de gjør?
sahagent.exe
ccapp.exe
svchost.exe
ccpxysvc.exe
lsass.exe
Med ZoneAlarm (som finnes i gratisversjon) kan du bestemme kva programmer som bruke internett-tilkoblingen.
sjå her ang. programmene http://www.answersthatwork.com/Tasklist_pages/tasklist.htm
Sahagent: Recommendation :
Not only is this what we call spyware since it transmits information from your PC, but worse the Privacy Policy does not clearly enumerate everything that gets transmitted from your PC. And that is not all : this is badly behaved software which can be catastrophic for 56K modem users as it often completely ties up the Internet connection while at the same time generating endless disk accesses. Remove ShopAtHomeSelect through the "Add/Remove Programs" icon in the Control Panel and then check if there are any remaining entries in The Ultimate Troubleshooter – if there are, delete them.
svchost: Står masse om det på linken eg gav.
ccapp: Recommendation :
Leave well alone – this task is crucial to the proper working of your Norton 2003/4 security product. We recommend, however, that you do a manual LiveUpdate every so often in order to pick up software updates (and not just virus definitions updates) as this task has had a few irritating bugs in the past.
cpxysvc: Recommendation :
We do not know what this task/service actually does, but we do know it is essential to the proper functioning of the firewall, so leave it alone. That said, this task is often seen "not responding" on some PCs; when this happens, start any Norton program and do a manual LiveUpdate to pick up the latest software updates (as opposed to virus definitions which are the only item "Automatic LiveUpdates" pick up) – this usually solves the problem.
lsass: Recommendation :
An integral part of the operating system, leave alone.
Edit: Meir informasjon om kva programmene er og gjer står på den sida eg oppgav. Følg den og velg bokstav alt etter kva første bokstav i programmet er.
Endret av zeph
