*kremt* Hva er en swapfil
A swap file (or swap space or, in Windows NT, a pagefile) is a space on a hard disk used as the virtual memory extension of a computer's real memory (random access memory). Having a swap file allows your computer's operating system to pretend that you have more RAM than you actually do. The least recently used files in RAM can be "swapped out" to your hard disk until they are needed later so that new files can be "swapped in" to RAM. In larger operating systems (such as IBM's OS/390), the units that are moved are called pages and the swapping is called paging.
One advantage of a swap file is that it can be organized as a single contiguous space so that fewer I/O operations are required to read or write a complete file.
In general, Windows 95, Windows 98, Windows NT, and UNIX-based operating systems provide a default swap file of a certain size that the user or a system administrator can usually change.
Virtual (or logical) memory is a concept that, when implemented by a computer and its operating system, allows programmers to use a very large range of memory or storage addresses for stored data. The computing system maps the programmer's virtual addresses to real hardware storage addresses. Usually, the programmer is freed from having to be concerned about the availability of data storage.
In addition to managing the mapping of virtual storage addresses to real storage addresses, a computer implementing virtual memory or storage also manages storage swapping between active storage (RAM) and hard disk or other high volume storage devices. Data is read in units called "pages" of sizes ranging from a thousand bytes (actually 1,024 decimal bytes) up to several megabyes in size. This reduces the amount of physical storage access that is required and speeds up overall system performance.
