gdesklets 0.25.1 på fedora ?
Jeg har lastet ned gDesklets for å få litt "schjvung" over desktoppen min.
Men når jeg kjører ./configure så får jeg denne feilmeldingen. Og jeg skjønner ikke hva jeg må oppdatere,/installere :(
checking whether ln -s works... yes
checking for python... /usr/bin/python
checking for python version... 2.2
checking for python platform... linux2
checking for python script directory... ${prefix}/lib/python2.2/site-packages
checking for python extension module directory... ${exec_prefix}/lib/python2.2/site-packages
checking for pkg-config... /usr/bin/pkg-config
checking for gnome-python-2.0 >= 1.99.17 pygtk-2.0 >= 1.99.17 gdk-2.0 gtk+-2.0 libgtop-2.0 >= 2.0.0... Package libgtop-2.0 was not found in the pkg-config search path.
Perhaps you should add the directory containing `libgtop-2.0.pc'
to the PKG_CONFIG_PATH environment variable
No package 'libgtop-2.0' found
configure: error: Library requirements (gnome-python-2.0 >= 1.99.17 pygtk-2.0 >= 1.99.17 gdk-2.0 gtk+-2.0 libgtop-2.0 >= 2.0.0) not met; consider adjusting the PKG_CONFIG_PATH environment variable if your libraries are in a nonstandard prefix so pkg-config can find them.
Hva er er det som er galt?
Vel, jeg fikk installert det men så kommer dette opp når ejg prøver å starte det...
 Traceback (most recent call last):
 File "/usr/local/bin/gdesklets", line 4, in ?
   from main import HOME
 File "/usr/local/share/gdesklets/main/__init__.py", line 64, in ?
   from utils.i18n import Translator
 File "/usr/local/share/gdesklets/utils/__init__.py", line 2, in ?
   from GConfWatcher import GConfWatcher
 File "/usr/local/share/gdesklets/utils/GConfWatcher.py", line 3, in ?
   import gconf
ImportError: No module named gconf
Hva trenger jeg gjøre for å få ordnet dette da?
*oppgitt over hvor vanskelig det skulle være:/*
