Ciaran og Ciara ( Cassidy Tvillingene ) Skrevet 18. desember 2024 Del Skrevet 18. desember 2024 Maskinfører skrev (3 minutter siden): Ja det gjør vi også ❤️ ❤️ Det er vi glade for å høre.♥️♥️ 1 Lenke til kommentar
Maskinfører Skrevet 18. desember 2024 Forfatter Del Skrevet 18. desember 2024 Ciaran og Ciara ( Cassidy Tvillingene ) skrev (1 time siden): Det er vi glade for å høre.♥️♥️ Ja vi også ❤️ ❤️ 1 Lenke til kommentar
Maskinfører Skrevet 18. desember 2024 Forfatter Del Skrevet 18. desember 2024 17:47:24.0252840 Start... TO_FILE_ONLY 17:47:24.0252840 Start detect 2534 devices TO_FILE_ONLY 17:47:24.0252840 Found: TIS Techstream VIM :: C:\Program Files (x86)\Toyota Diagnostics\Techstream\Bin\ComTol32.dll TO_FILE_ONLY 17:47:24.0252840 Found: Mongoose MFC :: C:\Windows\SysWOW64\MONGM432.DLL TO_FILE_ONLY 17:47:24.0252840 Found: MRVCIPlus Aftermarket J2534 VCI :: C:\Program Files (x86)\S2\MRVCIPlus-AftermarketJ2534\mrvciplus32.dll TO_FILE_ONLY 17:47:24.0252840 Found: XHorse - MVCI :: C:\MVCI32.dll TO_FILE_ONLY 17:47:24.0252840 Found: MVCI Autokent-X64 - 1.4.8 :: E:\Autokent\1.4.8\MVCI32.dll TO_FILE_ONLY 17:47:24.0252840 Found: XHorse - MVCI :: C:\Windows\system32\MVCI32.dll TO_FILE_ONLY 17:47:24.4776848 Operating system: Microsoft Windows 7 Professional 64-bit 7601 TO_FILE_ONLY 17:47:25.9606875 CPU: Intel(R) Core(TM)2 Duo CPU L9300 @ 1.60GHz 2 cores 2 threads. TO_FILE_ONLY 17:47:25.9918875 ETACS: Start encoder TO_FILE_ONLY 17:47:26.1010877 ETACS: Encoder loaded TO_FILE_ONLY 17:47:26.1010877 Engine: Start encoder TO_FILE_ONLY 17:47:26.1010877 Engine: Encoder loaded TO_FILE_ONLY 17:47:26.1010877 Meter: Start encoder TO_FILE_ONLY 17:47:26.1010877 Meter: Encoder loaded TO_FILE_ONLY 17:47:26.1010877 Immo: Start encoder TO_FILE_ONLY 17:47:26.1010877 Immo: Encoder loaded TO_FILE_ONLY 17:47:26.1010877 CVT/AT: Start encoder TO_FILE_ONLY 17:47:26.1010877 CVT/AT: Encoder loaded TO_FILE_ONLY 17:47:26.1010877 Application loaded, current version is 0.0.2.1 TO_FILE_ONLY 17:47:30.0946947 TNDA TO_FILE_ONLY 17:47:30.1414948 LE: Logs\3-19-2023 5-47-23 PM.txt The process cannot access the file 'C:\Users\JetCarrier Inc\Desktop\Logs\3-19-2023 5-47-23 PM.txt' because it is being used by another process. TO_FILE_ONLY 17:48:28.7938045 Current version: 0.0.2.1 TO_FILE_ONLY 17:48:28.8094046 Actual version: 0.0.2.3 TO_FILE_ONLY 17:48:55.8820550 Connect pressed. TO_FILE_ONLY 17:48:55.9600551 Exchanger start... Connection type: J2534 TO_FILE_ONLY 17:48:57.8476584 Lib loaded: C:\Windows\system32\MVCI32.dll TO_FILE_ONLY 17:48:57.8476584 Name: XHorse - MVCI TO_FILE_ONLY 17:48:57.8476584 Vendor: XHorse ELECTRONICS Co.,Ltd. TO_FILE_ONLY 17:48:58.0348587 Firmware version: J2534 MINIV1.03 TO_FILE_ONLY 17:48:58.0348587 DLL version: MVCI J2534 DLL v1.4.6 TO_FILE_ONLY 17:48:58.0348587 API version: 04.04 TO_FILE_ONLY 17:48:59.0644605 Send: 620:1092 TO_FILE_ONLY 17:48:59.2204608 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:48:59.3296610 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:48:59.4544612 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:48:59.5792615 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:48:59.5792615 Receive timeout. Elapsed 468 ms TO_FILE_ONLY 17:48:59.5792615 ETACS not found. WARNING 17:48:59.6884616 Send: 7E0:1092 TO_FILE_ONLY 17:48:59.7664618 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:48:59.7664618 Received: 7E8: TO_FILE_ONLY 17:48:59.7976618 RxStatus:NONE TO_FILE_ONLY 17:48:59.7976618 Received: 7E8:5092 TO_FILE_ONLY 17:48:59.8132619 Engine found! DEFAULT 17:48:59.8132619 Send: 7E0:1A87 TO_FILE_ONLY 17:48:59.8756620 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:48:59.8912620 Received: 7E8: TO_FILE_ONLY 17:48:59.9224621 RxStatus:NONE TO_FILE_ONLY 17:48:59.9224621 Received: 7E8:5A8704250006FF303011230031383630423039392020 TO_FILE_ONLY 17:48:59.9224621 Description: Engine INFO 17:48:59.9224621 Diag version: 6 INFO 17:48:59.9224621 Supplier: DENSO INFO 17:48:59.9224621 -------------- DEFAULT 17:48:59.9224621 PN: 1860B099 TO_FILE_ONLY 17:48:59.9380621 Send: 7E0:1A9C TO_FILE_ONLY 17:49:00.0160622 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:00.0160622 Received: 7E8: TO_FILE_ONLY 17:49:00.0472623 RxStatus:NONE TO_FILE_ONLY 17:49:00.0472623 Received: 7E8:5A9C0104250006FF11230031383630423039393033 TO_FILE_ONLY 17:49:00.0472623 SW PN: 1860B09903 TO_FILE_ONLY 17:49:00.0472623 Send: 7E0:1A90 TO_FILE_ONLY 17:49:00.1252624 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:00.1252624 Received: 7E8: TO_FILE_ONLY 17:49:00.1564625 RxStatus:NONE TO_FILE_ONLY 17:49:00.1564625 Received: 7E8:5A904D4D43434E4B4234303944303032393133 TO_FILE_ONLY 17:49:00.1564625 Current VIN: MMCCNKB409D002913 TO_FILE_ONLY 17:49:00.1830631 Send: 7E0:1A88 TO_FILE_ONLY 17:49:00.2316650 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:00.2316650 Received: 7E8: TO_FILE_ONLY 17:49:00.2628651 RxStatus:NONE TO_FILE_ONLY 17:49:00.2628651 Received: 7E8:5A884D4D43434E4B4234303944303032393133 TO_FILE_ONLY 17:49:00.2628651 Original VIN: MMCCNKB409D002913 TO_FILE_ONLY 17:49:00.2784651 Send: 7E0:21E1 TO_FILE_ONLY 17:49:00.3408652 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:00.3408652 Received: 7E8: TO_FILE_ONLY 17:49:00.3720653 RxStatus:NONE TO_FILE_ONLY 17:49:00.3720653 Received: 7E8:7F2112 TO_FILE_ONLY 17:49:00.3876653 Send: 7E0:21C0 TO_FILE_ONLY 17:49:00.4656654 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:00.4656654 Received: 7E8: TO_FILE_ONLY 17:49:00.4968655 RxStatus:NONE TO_FILE_ONLY 17:49:00.4968655 Received: 7E8:7F2112 TO_FILE_ONLY 17:49:00.4968655 Send: 7E0:1081 TO_FILE_ONLY 17:49:00.5758657 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:00.5758657 Received: 7E8: TO_FILE_ONLY 17:49:00.6070658 RxStatus:NONE TO_FILE_ONLY 17:49:00.6070658 Received: 7E8:5081 TO_FILE_ONLY 17:49:00.7318660 Send: 6A0:1092 TO_FILE_ONLY 17:49:00.8888663 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:01.0136665 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:01.1384667 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:01.2788670 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:01.2788670 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:49:01.2788670 Meter not found. WARNING 17:49:24.6293104 Send: 620:1092 TO_FILE_ONLY 17:49:24.7853107 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:24.9257110 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:25.0505112 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:25.1753114 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:25.1753114 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:49:25.2689116 Send: 786:1092 TO_FILE_ONLY 17:49:25.4249118 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:25.5653121 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:25.6901123 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:25.8149125 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:25.8149125 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:49:25.9085127 Send: 7E0:1092 TO_FILE_ONLY 17:49:25.9709128 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:25.9709128 Received: 7E8: TO_FILE_ONLY 17:49:26.0021129 RxStatus:NONE TO_FILE_ONLY 17:49:26.0021129 Received: 7E8:5092 TO_FILE_ONLY 17:49:26.0021129 Send: 7E0:1A87 TO_FILE_ONLY 17:49:26.0645130 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:26.0645130 Received: 7E8: TO_FILE_ONLY 17:49:26.0957130 RxStatus:NONE TO_FILE_ONLY 17:49:26.0957130 Received: 7E8:5A8704250006FF303011230031383630423039392020 TO_FILE_ONLY 17:49:26.0957130 Description: Engine INFO 17:49:26.0957130 Diag version: 6 INFO 17:49:26.0957130 Supplier: DENSO INFO 17:49:26.0957130 -------------- DEFAULT 17:49:26.1269131 Start reading DTCs on Engine TO_FILE_ONLY 17:49:26.1269131 Send: 7E0:1800FF00 TO_FILE_ONLY 17:49:26.2049132 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:26.2049132 Received: 7E8: TO_FILE_ONLY 17:49:26.2361133 RxStatus:NONE TO_FILE_ONLY 17:49:26.2361133 Received: 7E8:5802157120D10160 TO_FILE_ONLY 17:49:26.2361133 Found P1571 DTC in Engine TO_FILE_ONLY 17:49:26.2673133 Found U1101 DTC in Engine TO_FILE_ONLY 17:49:26.2673133 Send: 7E0:1081 TO_FILE_ONLY 17:49:26.3297134 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:26.3297134 Received: 7E8: TO_FILE_ONLY 17:49:26.3609135 RxStatus:NONE TO_FILE_ONLY 17:49:26.3609135 Received: 7E8:5081 TO_FILE_ONLY 17:49:26.4545136 Send: 77B:1092 TO_FILE_ONLY 17:49:26.6105139 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:26.7353141 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:26.8445143 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:26.9693145 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:26.9693145 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:49:27.0629147 Send: 784:1092 TO_FILE_ONLY 17:49:27.1253148 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:27.1253148 Received: 785: TO_FILE_ONLY 17:49:27.1565149 RxStatus:NONE TO_FILE_ONLY 17:49:27.1565149 Received: 785:5092 TO_FILE_ONLY 17:49:27.1565149 Send: 784:1A87 TO_FILE_ONLY 17:49:27.2189150 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:27.2189150 Received: 785: TO_FILE_ONLY 17:49:27.2501150 RxStatus:NONE TO_FILE_ONLY 17:49:27.2501150 Received: 785:5A8704630003FF001030363134363730413338352020 TO_FILE_ONLY 17:49:27.2501150 Description: ABS INFO 17:49:27.2501150 Diag version: 3 INFO 17:49:27.2501150 Supplier: ADVICS INFO 17:49:27.2501150 -------------- DEFAULT 17:49:27.2969151 Start reading DTCs on ABS TO_FILE_ONLY 17:49:27.2969151 Send: 784:1800FF00 TO_FILE_ONLY 17:49:27.3593152 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:27.3593152 Received: 785: TO_FILE_ONLY 17:49:27.4217153 RxStatus:NONE TO_FILE_ONLY 17:49:27.4217153 Received: 785:580AD436E0D419E05292E05394E05506E0D10420521520521020D07320D10920 TO_FILE_ONLY 17:49:27.4217153 Found U1436 DTC in ABS TO_FILE_ONLY 17:49:27.4217153 Found U1419 DTC in ABS TO_FILE_ONLY 17:49:27.4217153 Found C1292 DTC in ABS TO_FILE_ONLY 17:49:27.4217153 Found C1394 DTC in ABS TO_FILE_ONLY 17:49:27.4217153 Found C1506 DTC in ABS TO_FILE_ONLY 17:49:27.4217153 Found U1104 DTC in ABS TO_FILE_ONLY 17:49:27.4373154 Found C1215 DTC in ABS TO_FILE_ONLY 17:49:27.4373154 Found C1210 DTC in ABS TO_FILE_ONLY 17:49:27.4373154 Found U1073 DTC in ABS TO_FILE_ONLY 17:49:27.4373154 Found U1109 DTC in ABS TO_FILE_ONLY 17:49:27.4373154 Send: 784:1081 TO_FILE_ONLY 17:49:27.5153155 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:27.5153155 Received: 785: TO_FILE_ONLY 17:49:27.5465156 RxStatus:NONE TO_FILE_ONLY 17:49:27.5465156 Received: 785:5081 TO_FILE_ONLY 17:49:27.6401157 Send: 7B6:1092 TO_FILE_ONLY 17:49:27.7961160 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:27.9209162 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:28.0457164 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:28.1549166 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:28.1549166 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:49:28.2485168 Send: 622:1092 TO_FILE_ONLY 17:49:28.3109169 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:28.3109169 Received: 484: TO_FILE_ONLY 17:49:28.3421170 RxStatus:NONE TO_FILE_ONLY 17:49:28.3421170 Received: 484:5092 TO_FILE_ONLY 17:49:28.3421170 Send: 622:1A87 TO_FILE_ONLY 17:49:28.4045171 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:28.4045171 Received: 484: TO_FILE_ONLY 17:49:28.4669172 RxStatus:NONE TO_FILE_ONLY 17:49:28.4669172 Received: 484:5A8704668000FF100010000038363531413038342020 TO_FILE_ONLY 17:49:28.4669172 Description: SAS INFO 17:49:28.4669172 Diag version: 32768 INFO 17:49:28.4669172 Supplier: Methode INFO 17:49:28.4669172 -------------- DEFAULT 17:49:28.5137173 Start reading DTCs on SAS TO_FILE_ONLY 17:49:28.5137173 Send: 622:1800FF00 TO_FILE_ONLY 17:49:28.5761174 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:28.5761174 Received: 484: TO_FILE_ONLY 17:49:28.6073174 RxStatus:NONE TO_FILE_ONLY 17:49:28.6073174 Received: 484:5802555520555260 TO_FILE_ONLY 17:49:28.6073174 Found C1555 DTC in SAS TO_FILE_ONLY 17:49:28.6229175 Found C1552 DTC in SAS TO_FILE_ONLY 17:49:28.6229175 Send: 622:1081 TO_FILE_ONLY 17:49:28.7009176 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:49:28.7009176 Received: 484: TO_FILE_ONLY 17:49:28.7321176 RxStatus:NONE TO_FILE_ONLY 17:49:28.7321176 Received: 484:5081 TO_FILE_ONLY 17:49:28.8257178 Send: 7B5:1092 TO_FILE_ONLY 17:49:28.9817181 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:29.1065183 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:29.2313185 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:29.3405187 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:29.3405187 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:49:29.4341189 Send: 7E1:1092 TO_FILE_ONLY 17:49:29.5901192 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:29.7149194 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:29.8397196 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:29.9489198 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:29.9489198 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:49:30.0425199 Send: 761:1092 TO_FILE_ONLY 17:49:30.1985202 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:30.3233204 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:30.4481207 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:30.5885209 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:30.5885209 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:49:30.6821211 Send: 6A0:1092 TO_FILE_ONLY 17:49:30.8381213 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:30.9629216 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:31.0987224 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:31.2235226 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:31.2235226 Receive timeout. Elapsed 510 ms TO_FILE_ONLY 17:49:31.3171228 Send: 763:1092 TO_FILE_ONLY 17:49:31.4731231 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:31.5979233 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:31.7071235 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:31.8319237 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:31.8319237 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:49:31.9255239 Send: 688:1092 TO_FILE_ONLY 17:49:32.0815241 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:32.2063244 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:32.3155245 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:32.4403248 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:32.4403248 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:49:32.5339249 Send: 616:1092 TO_FILE_ONLY 17:49:32.6899252 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:32.8147254 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:32.9239256 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:33.0487258 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:33.0487258 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:49:33.1423260 Send: 600:1092 TO_FILE_ONLY 17:49:33.2983263 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:33.4231265 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:33.5635267 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:33.6883270 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:33.6883270 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:49:33.7819271 Send: 751:1092 TO_FILE_ONLY 17:49:33.9379274 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:34.0627276 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:34.1719278 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:34.2967280 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:34.2967280 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:49:34.3903282 Send: 6E0:1092 TO_FILE_ONLY 17:49:34.5463285 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:34.6711287 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:34.8115289 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:34.9363292 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:34.9363292 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:49:35.0299293 Send: 73A:1092 TO_FILE_ONLY 17:49:35.1859296 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:35.3107298 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:35.4199300 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:35.5447302 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:35.5447302 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:49:35.6383304 Send: 6B0:1092 TO_FILE_ONLY 17:49:35.7943307 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:35.9191309 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:36.0595311 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:36.1843313 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:36.1843313 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:49:36.2779315 Send: 796:1092 TO_FILE_ONLY 17:49:36.4339318 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:36.5587320 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:36.6679322 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:36.7927324 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:49:36.7927324 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:50:53.4140710 Send: 620:1092 TO_FILE_ONLY 17:50:53.5700713 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:53.6948715 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:53.8040717 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:53.9288719 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:53.9288719 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:50:54.0224721 Send: 786:1092 TO_FILE_ONLY 17:50:54.1784723 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:54.3032725 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:54.4124727 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:54.5372730 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:54.5372730 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:50:54.6308731 Send: 7E0:1092 TO_FILE_ONLY 17:50:54.6932732 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:50:54.6932732 Received: 7E8: TO_FILE_ONLY 17:50:54.7244733 RxStatus:NONE TO_FILE_ONLY 17:50:54.7244733 Received: 7E8:5092 TO_FILE_ONLY 17:50:54.7244733 Send: 7E0:1A87 TO_FILE_ONLY 17:50:54.7868734 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:50:54.7868734 Received: 7E8: TO_FILE_ONLY 17:50:54.8180734 RxStatus:NONE TO_FILE_ONLY 17:50:54.8180734 Received: 7E8:5A8704250006FF303011230031383630423039392020 TO_FILE_ONLY 17:50:54.8180734 Description: Engine INFO 17:50:54.8180734 Diag version: 6 INFO 17:50:54.8180734 Supplier: DENSO INFO 17:50:54.8180734 -------------- DEFAULT 17:50:54.8648735 Start reading DTCs on Engine TO_FILE_ONLY 17:50:54.8648735 Send: 7E0:1800FF00 TO_FILE_ONLY 17:50:54.9116736 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:50:54.9116736 Received: 7E8: TO_FILE_ONLY 17:50:54.9428737 RxStatus:NONE TO_FILE_ONLY 17:50:54.9428737 Received: 7E8:5802157120D10160 TO_FILE_ONLY 17:50:54.9584737 Found P1571 DTC in Engine TO_FILE_ONLY 17:50:54.9584737 Found U1101 DTC in Engine TO_FILE_ONLY 17:50:54.9584737 Send: 7E0:1081 TO_FILE_ONLY 17:50:55.0364738 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:50:55.0364738 Received: 7E8: TO_FILE_ONLY 17:50:55.0676739 RxStatus:NONE TO_FILE_ONLY 17:50:55.0676739 Received: 7E8:5081 TO_FILE_ONLY 17:50:55.1612741 Send: 77B:1092 TO_FILE_ONLY 17:50:55.3172743 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:55.4420745 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:55.5668748 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:55.6760750 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:55.6760750 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:50:55.7696751 Send: 784:1092 TO_FILE_ONLY 17:50:55.8320752 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:50:55.8320752 Received: 785: TO_FILE_ONLY 17:50:55.8632753 RxStatus:NONE TO_FILE_ONLY 17:50:55.8632753 Received: 785:5092 TO_FILE_ONLY 17:50:55.8632753 Send: 784:1A87 TO_FILE_ONLY 17:50:55.9256754 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:50:55.9256754 Received: 785: TO_FILE_ONLY 17:50:55.9568754 RxStatus:NONE TO_FILE_ONLY 17:50:55.9568754 Received: 785:5A8704630003FF001030363134363730413338352020 TO_FILE_ONLY 17:50:55.9568754 Description: ABS INFO 17:50:55.9568754 Diag version: 3 INFO 17:50:55.9568754 Supplier: ADVICS INFO 17:50:55.9568754 -------------- DEFAULT 17:50:55.9880755 Start reading DTCs on ABS TO_FILE_ONLY 17:50:55.9880755 Send: 784:1800FF00 TO_FILE_ONLY 17:50:56.0504756 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:50:56.0504756 Received: 785: TO_FILE_ONLY 17:50:56.0816757 RxStatus:NONE TO_FILE_ONLY 17:50:56.0816757 Received: 785:580AD436E0D419E05292E05394E05506E0D10420521520521020D07320D10920 TO_FILE_ONLY 17:50:56.0816757 Found U1436 DTC in ABS TO_FILE_ONLY 17:50:56.0972757 Found U1419 DTC in ABS TO_FILE_ONLY 17:50:56.0972757 Found C1292 DTC in ABS TO_FILE_ONLY 17:50:56.0972757 Found C1394 DTC in ABS TO_FILE_ONLY 17:50:56.0972757 Found C1506 DTC in ABS TO_FILE_ONLY 17:50:56.0972757 Found U1104 DTC in ABS TO_FILE_ONLY 17:50:56.0972757 Found C1215 DTC in ABS TO_FILE_ONLY 17:50:56.0972757 Found C1210 DTC in ABS TO_FILE_ONLY 17:50:56.0972757 Found U1073 DTC in ABS TO_FILE_ONLY 17:50:56.0972757 Found U1109 DTC in ABS TO_FILE_ONLY 17:50:56.0972757 Send: 784:1081 TO_FILE_ONLY 17:50:56.1596758 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:50:56.1596758 Received: 785: TO_FILE_ONLY 17:50:56.1908759 RxStatus:NONE TO_FILE_ONLY 17:50:56.1908759 Received: 785:5081 TO_FILE_ONLY 17:50:56.3000761 Send: 7B6:1092 TO_FILE_ONLY 17:50:56.4560763 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:56.5808765 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:56.7056768 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:56.8304770 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:56.8304770 Receive timeout. Elapsed 499 ms TO_FILE_ONLY 17:50:56.9396772 Send: 622:1092 TO_FILE_ONLY 17:50:57.0020773 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:50:57.0020773 Received: 484: TO_FILE_ONLY 17:50:57.0332773 RxStatus:NONE TO_FILE_ONLY 17:50:57.0332773 Received: 484:5092 TO_FILE_ONLY 17:50:57.0332773 Send: 622:1A87 TO_FILE_ONLY 17:50:57.0956774 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:50:57.0956774 Received: 484: TO_FILE_ONLY 17:50:57.1580776 RxStatus:NONE TO_FILE_ONLY 17:50:57.1580776 Received: 484:5A8704668000FF100010000038363531413038342020 TO_FILE_ONLY 17:50:57.1580776 Description: SAS INFO 17:50:57.1580776 Diag version: 32768 INFO 17:50:57.1580776 Supplier: Methode INFO 17:50:57.1580776 -------------- DEFAULT 17:50:57.2048776 Start reading DTCs on SAS TO_FILE_ONLY 17:50:57.2048776 Send: 622:1800FF00 TO_FILE_ONLY 17:50:57.2672778 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:50:57.2672778 Received: 484: TO_FILE_ONLY 17:50:57.2984778 RxStatus:NONE TO_FILE_ONLY 17:50:57.2984778 Received: 484:5802555520555260 TO_FILE_ONLY 17:50:57.2984778 Found C1555 DTC in SAS TO_FILE_ONLY 17:50:57.2984778 Found C1552 DTC in SAS TO_FILE_ONLY 17:50:57.3140778 Send: 622:1081 TO_FILE_ONLY 17:50:57.3764779 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:50:57.3764779 Received: 484: TO_FILE_ONLY 17:50:57.4076780 RxStatus:NONE TO_FILE_ONLY 17:50:57.4076780 Received: 484:5081 TO_FILE_ONLY 17:50:57.5168782 Send: 7B5:1092 TO_FILE_ONLY 17:50:57.6728785 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:57.7976787 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:57.9224789 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:58.0472791 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:58.0472791 Receive timeout. Elapsed 499 ms TO_FILE_ONLY 17:50:58.1564793 Send: 7E1:1092 TO_FILE_ONLY 17:50:58.3124796 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:58.4372798 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:58.5620800 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:58.6868802 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:58.6868802 Receive timeout. Elapsed 499 ms TO_FILE_ONLY 17:50:58.7960804 Send: 761:1092 TO_FILE_ONLY 17:50:58.9676807 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:59.0924810 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:59.2172812 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:59.3420814 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:59.3420814 Receive timeout. Elapsed 499 ms TO_FILE_ONLY 17:50:59.4512816 Send: 6A0:1092 TO_FILE_ONLY 17:50:59.6072819 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:59.7320821 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:59.8578824 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:59.9826826 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:50:59.9826826 Receive timeout. Elapsed 500 ms TO_FILE_ONLY 17:51:00.0918828 Send: 763:1092 TO_FILE_ONLY 17:51:00.2382834 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:00.3474835 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:00.4420838 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:00.5668840 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:00.5668840 Receive timeout. Elapsed 443 ms TO_FILE_ONLY 17:51:00.6604842 Send: 688:1092 TO_FILE_ONLY 17:51:00.8164844 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:00.9412846 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:01.0504848 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:01.1752851 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:01.1752851 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:01.2688852 Send: 616:1092 TO_FILE_ONLY 17:51:01.4248855 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:01.5496857 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:01.6588859 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:01.7836861 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:01.7836861 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:01.8772863 Send: 600:1092 TO_FILE_ONLY 17:51:02.0332866 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:02.1580868 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:02.2672870 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:02.3920872 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:02.3920872 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:02.4856874 Send: 751:1092 TO_FILE_ONLY 17:51:02.6416876 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:02.7664879 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:02.8756880 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:03.0014883 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:03.0014883 Receive timeout. Elapsed 484 ms TO_FILE_ONLY 17:51:03.0950885 Send: 6E0:1092 TO_FILE_ONLY 17:51:03.2510888 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:03.3758890 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:03.5006892 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:03.6098894 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:03.6098894 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:03.7034896 Send: 73A:1092 TO_FILE_ONLY 17:51:03.8594898 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:03.9842900 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:04.1090903 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:04.2192905 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:04.2192905 Receive timeout. Elapsed 484 ms TO_FILE_ONLY 17:51:04.3128907 Send: 6B0:1092 TO_FILE_ONLY 17:51:04.4688910 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:04.5936912 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:04.7184914 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:04.8276916 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:04.8276916 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:04.9212917 Send: 796:1092 TO_FILE_ONLY 17:51:05.0772920 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:05.2020922 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:05.3268925 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:05.4360927 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:05.4360927 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:11.8079042 Send: 620:1092 TO_FILE_ONLY 17:51:11.9639045 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:12.1053048 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:12.2301050 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:12.3549052 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:12.3549052 Receive timeout. Elapsed 515 ms TO_FILE_ONLY 17:51:12.4485054 Send: 786:1092 TO_FILE_ONLY 17:51:12.6045057 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:12.7137059 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:12.8385061 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:12.9633063 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:12.9633063 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:13.0569065 Send: 7E0:1092 TO_FILE_ONLY 17:51:13.1193066 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:51:13.1193066 Received: 7E8: TO_FILE_ONLY 17:51:13.1505066 RxStatus:NONE TO_FILE_ONLY 17:51:13.1505066 Received: 7E8:5092 TO_FILE_ONLY 17:51:13.1505066 Send: 7E0:1A87 TO_FILE_ONLY 17:51:13.2129068 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:51:13.2129068 Received: 7E8: TO_FILE_ONLY 17:51:13.2441068 RxStatus:NONE TO_FILE_ONLY 17:51:13.2441068 Received: 7E8:5A8704250006FF303011230031383630423039392020 TO_FILE_ONLY 17:51:13.2441068 Description: Engine INFO 17:51:13.2441068 Diag version: 6 INFO 17:51:13.2441068 Supplier: DENSO INFO 17:51:13.2441068 -------------- DEFAULT 17:51:13.2753069 Start reading TellTales on Engine TO_FILE_ONLY 17:51:13.2753069 Send: 7E0:33E2 TO_FILE_ONLY 17:51:13.5717074 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:13.8213078 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:14.0865083 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:14.3361087 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:14.3361087 Receive timeout. Elapsed 1029 ms TO_FILE_ONLY 17:51:14.3361087 No TellTales on Engine TO_FILE_ONLY 17:51:14.3361087 Send: 7E0:1081 TO_FILE_ONLY 17:51:14.3985088 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:51:14.3985088 Received: 7E8: TO_FILE_ONLY 17:51:14.4297089 RxStatus:NONE TO_FILE_ONLY 17:51:14.4297089 Received: 7E8:5081 TO_FILE_ONLY 17:51:14.5233091 Send: 77B:1092 TO_FILE_ONLY 17:51:14.6949094 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:14.8197096 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:14.9445098 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:15.0693100 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:15.0693100 Receive timeout. Elapsed 499 ms TO_FILE_ONLY 17:51:15.1629102 Send: 784:1092 TO_FILE_ONLY 17:51:15.2409103 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:51:15.2409103 Received: 785: TO_FILE_ONLY 17:51:15.2721104 RxStatus:NONE TO_FILE_ONLY 17:51:15.2721104 Received: 785:5092 TO_FILE_ONLY 17:51:15.2721104 Send: 784:1A87 TO_FILE_ONLY 17:51:15.3345105 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:51:15.3345105 Received: 785: TO_FILE_ONLY 17:51:15.3657105 RxStatus:NONE TO_FILE_ONLY 17:51:15.3657105 Received: 785:5A8704630003FF001030363134363730413338352020 TO_FILE_ONLY 17:51:15.3657105 Description: ABS INFO 17:51:15.3657105 Diag version: 3 INFO 17:51:15.3657105 Supplier: ADVICS INFO 17:51:15.3657105 -------------- DEFAULT 17:51:15.3969106 Start reading TellTales on ABS TO_FILE_ONLY 17:51:15.3969106 Send: 784:33E2 TO_FILE_ONLY 17:51:15.4593107 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:51:15.4593107 Received: 785: TO_FILE_ONLY 17:51:15.4905108 RxStatus:NONE TO_FILE_ONLY 17:51:15.4905108 Received: 785:7F3311 TO_FILE_ONLY 17:51:15.4905108 TellTale ABS error 0x11 - serviceNotSupported TO_FILE_ONLY 17:51:15.4905108 No TellTales on ABS TO_FILE_ONLY 17:51:15.4905108 Send: 784:1081 TO_FILE_ONLY 17:51:15.5685109 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:51:15.5685109 Received: 785: TO_FILE_ONLY 17:51:15.5997109 RxStatus:NONE TO_FILE_ONLY 17:51:15.5997109 Received: 785:5081 TO_FILE_ONLY 17:51:15.6933111 Send: 7B6:1092 TO_FILE_ONLY 17:51:15.8337114 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:15.9585116 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:16.0833118 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:16.2081120 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:16.2081120 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:16.3017122 Send: 622:1092 TO_FILE_ONLY 17:51:16.3641123 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:51:16.3641123 Received: 484: TO_FILE_ONLY 17:51:16.3953123 RxStatus:NONE TO_FILE_ONLY 17:51:16.3953123 Received: 484:5092 TO_FILE_ONLY 17:51:16.3953123 Send: 622:1A87 TO_FILE_ONLY 17:51:16.4733125 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:51:16.4733125 Received: 484: TO_FILE_ONLY 17:51:16.5357126 RxStatus:NONE TO_FILE_ONLY 17:51:16.5357126 Received: 484:5A8704668000FF100010000038363531413038342020 TO_FILE_ONLY 17:51:16.5357126 Description: SAS INFO 17:51:16.5357126 Diag version: 32768 INFO 17:51:16.5357126 Supplier: Methode INFO 17:51:16.5357126 -------------- DEFAULT 17:51:16.5669126 Start reading TellTales on SAS TO_FILE_ONLY 17:51:16.5669126 Send: 622:33E2 TO_FILE_ONLY 17:51:16.6449128 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:51:16.6449128 Received: 484: TO_FILE_ONLY 17:51:16.6761128 RxStatus:NONE TO_FILE_ONLY 17:51:16.6761128 Received: 484:7F3311 TO_FILE_ONLY 17:51:16.6761128 TellTale SAS error 0x11 - serviceNotSupported TO_FILE_ONLY 17:51:16.6761128 No TellTales on SAS TO_FILE_ONLY 17:51:16.6761128 Send: 622:1081 TO_FILE_ONLY 17:51:16.7385129 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:51:16.7385129 Received: 484: TO_FILE_ONLY 17:51:16.7697130 RxStatus:NONE TO_FILE_ONLY 17:51:16.7697130 Received: 484:5081 TO_FILE_ONLY 17:51:16.8633132 Send: 7B5:1092 TO_FILE_ONLY 17:51:17.0193134 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:17.1285136 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:17.2533139 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:17.3781141 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:17.3781141 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:17.4717142 Send: 7E1:1092 TO_FILE_ONLY 17:51:17.6277145 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:17.7369147 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:17.8617149 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:17.9865151 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:17.9865151 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:18.0801153 Send: 761:1092 TO_FILE_ONLY 17:51:18.2361156 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:18.3765158 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:18.5013160 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:18.6261163 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:18.6261163 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:51:18.7197164 Send: 6A0:1092 TO_FILE_ONLY 17:51:18.8757167 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:18.9849169 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:19.1097171 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:19.2345173 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:19.2345173 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:19.3281175 Send: 763:1092 TO_FILE_ONLY 17:51:19.4841178 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:19.6245180 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:19.7493182 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:19.8741185 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:19.8741185 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:51:19.9677186 Send: 688:1092 TO_FILE_ONLY 17:51:20.1237189 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:20.2329191 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:20.3577193 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:20.4825195 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:20.4825195 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:20.5761197 Send: 616:1092 TO_FILE_ONLY 17:51:20.7321200 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:20.8725202 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:20.9973204 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:21.1221206 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:21.1221206 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:51:21.2157208 Send: 600:1092 TO_FILE_ONLY 17:51:21.3717211 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:21.4809213 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:21.6057215 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:21.7305217 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:21.7305217 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:21.8241219 Send: 751:1092 TO_FILE_ONLY 17:51:21.9801222 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:22.1049224 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:22.2141226 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:22.3399228 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:22.3399228 Receive timeout. Elapsed 484 ms TO_FILE_ONLY 17:51:22.4335230 Send: 6E0:1092 TO_FILE_ONLY 17:51:22.5895233 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:22.7143235 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:22.8235237 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:22.9483239 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:22.9483239 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:23.0419241 Send: 73A:1092 TO_FILE_ONLY 17:51:23.1979243 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:23.3211253 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:23.4303255 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:23.5551258 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:23.5551258 Receive timeout. Elapsed 482 ms TO_FILE_ONLY 17:51:23.6487259 Send: 6B0:1092 TO_FILE_ONLY 17:51:23.8047262 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:23.9295264 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:24.0387266 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:24.1635268 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:24.1635268 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:51:24.2571270 Send: 796:1092 TO_FILE_ONLY 17:51:24.4131273 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:24.5379275 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:24.6471277 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:24.7719279 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:51:24.7719279 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:52:09.4864084 Not enough data to save file! Check your adapter for support this program. LOG_ERROR 17:52:30.0836475 TNDA TO_FILE_ONLY 17:52:30.0836475 LE: Logs\3-19-2023 5-47-23 PM.txt The process cannot access the file 'C:\Users\JetCarrier Inc\Desktop\Logs\3-19-2023 5-47-23 PM.txt' because it is being used by another process. TO_FILE_ONLY 17:52:45.2352743 Send: 7E0:1092 TO_FILE_ONLY 17:52:45.2976744 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:45.2976744 Received: 7E8: TO_FILE_ONLY 17:52:45.3288745 RxStatus:NONE TO_FILE_ONLY 17:52:45.3288745 Received: 7E8:5092 TO_FILE_ONLY 17:52:45.3288745 Send: 7E0:14FF00 TO_FILE_ONLY 17:52:45.3912746 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:45.3912746 Received: 7E8: TO_FILE_ONLY 17:52:45.4224746 RxStatus:NONE TO_FILE_ONLY 17:52:45.4224746 Received: 7E8:54FF00 TO_FILE_ONLY 17:52:45.4224746 Send: 7E0:1081 TO_FILE_ONLY 17:52:45.4848748 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:45.4848748 Received: 7E8: TO_FILE_ONLY 17:52:45.5160748 RxStatus:NONE TO_FILE_ONLY 17:52:45.5160748 Received: 7E8:5081 TO_FILE_ONLY 17:52:45.6096750 Send: 784:1092 TO_FILE_ONLY 17:52:45.6876751 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:45.6876751 Received: 785: TO_FILE_ONLY 17:52:45.7188752 RxStatus:NONE TO_FILE_ONLY 17:52:45.7188752 Received: 785:5092 TO_FILE_ONLY 17:52:45.7188752 Send: 784:14FF00 TO_FILE_ONLY 17:52:45.7812753 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:45.7812753 Received: 785: TO_FILE_ONLY 17:52:45.8124753 RxStatus:NONE TO_FILE_ONLY 17:52:45.8124753 Received: 785:7F1410 TO_FILE_ONLY 17:52:45.8124753 Send: 784:1081 TO_FILE_ONLY 17:52:45.8748754 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:45.8748754 Received: 785: TO_FILE_ONLY 17:52:45.9060755 RxStatus:NONE TO_FILE_ONLY 17:52:45.9060755 Received: 785:5081 TO_FILE_ONLY 17:52:45.9996757 Send: 622:1092 TO_FILE_ONLY 17:52:46.0620758 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:46.0620758 Received: 484: TO_FILE_ONLY 17:52:46.0932758 RxStatus:NONE TO_FILE_ONLY 17:52:46.0932758 Received: 484:5092 TO_FILE_ONLY 17:52:46.0932758 Send: 622:14FF00 TO_FILE_ONLY 17:52:46.1556759 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:46.1556759 Received: 484: TO_FILE_ONLY 17:52:46.1868760 RxStatus:NONE TO_FILE_ONLY 17:52:46.1868760 Received: 484:54FF00 TO_FILE_ONLY 17:52:46.1868760 Send: 622:1081 TO_FILE_ONLY 17:52:46.2648761 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:46.2648761 Received: 484: TO_FILE_ONLY 17:52:46.2960762 RxStatus:NONE TO_FILE_ONLY 17:52:46.2960762 Received: 484:5081 TO_FILE_ONLY 17:52:46.4676765 Send: 620:1092 TO_FILE_ONLY 17:52:46.6236768 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:46.7484770 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:46.8888772 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:47.0136774 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:47.0136774 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:52:47.1072776 Send: 786:1092 TO_FILE_ONLY 17:52:47.2632779 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:47.3880781 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:47.5284783 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:47.6532786 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:47.6532786 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:52:47.7478788 Send: 7E0:1092 TO_FILE_ONLY 17:52:47.8102789 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:47.8102789 Received: 7E8: TO_FILE_ONLY 17:52:47.8414790 RxStatus:NONE TO_FILE_ONLY 17:52:47.8414790 Received: 7E8:5092 TO_FILE_ONLY 17:52:47.8414790 Send: 7E0:1A87 TO_FILE_ONLY 17:52:47.9038791 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:47.9038791 Received: 7E8: TO_FILE_ONLY 17:52:47.9350791 RxStatus:NONE TO_FILE_ONLY 17:52:47.9350791 Received: 7E8:5A8704250006FF303011230031383630423039392020 TO_FILE_ONLY 17:52:47.9350791 Description: Engine INFO 17:52:47.9350791 Diag version: 6 INFO 17:52:47.9350791 Supplier: DENSO INFO 17:52:47.9350791 -------------- DEFAULT 17:52:47.9818792 Start reading DTCs on Engine TO_FILE_ONLY 17:52:47.9818792 Send: 7E0:1800FF00 TO_FILE_ONLY 17:52:48.0442793 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:48.0442793 Received: 7E8: TO_FILE_ONLY 17:52:48.0754794 RxStatus:NONE TO_FILE_ONLY 17:52:48.0754794 Received: 7E8:5801D10160 TO_FILE_ONLY 17:52:48.0910794 Found U1101 DTC in Engine TO_FILE_ONLY 17:52:48.0910794 Send: 7E0:1081 TO_FILE_ONLY 17:52:48.1544796 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:48.1544796 Received: 7E8: TO_FILE_ONLY 17:52:48.1856796 RxStatus:NONE TO_FILE_ONLY 17:52:48.2012796 Received: 7E8:5081 TO_FILE_ONLY 17:52:48.2948798 Send: 77B:1092 TO_FILE_ONLY 17:52:48.4508801 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:48.5756803 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:48.7004805 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:48.8252807 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:48.8252807 Receive timeout. Elapsed 499 ms TO_FILE_ONLY 17:52:48.9344809 Send: 784:1092 TO_FILE_ONLY 17:52:48.9978811 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:48.9978811 Received: 785: TO_FILE_ONLY 17:52:49.0290811 RxStatus:NONE TO_FILE_ONLY 17:52:49.0290811 Received: 785:5092 TO_FILE_ONLY 17:52:49.0290811 Send: 784:1A87 TO_FILE_ONLY 17:52:49.0914813 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:49.0914813 Received: 785: TO_FILE_ONLY 17:52:49.1226813 RxStatus:NONE TO_FILE_ONLY 17:52:49.1226813 Received: 785:5A8704630003FF001030363134363730413338352020 TO_FILE_ONLY 17:52:49.1226813 Description: ABS INFO 17:52:49.1226813 Diag version: 3 INFO 17:52:49.1226813 Supplier: ADVICS INFO 17:52:49.1226813 -------------- DEFAULT 17:52:49.1538814 Start reading DTCs on ABS TO_FILE_ONLY 17:52:49.1538814 Send: 784:1800FF00 TO_FILE_ONLY 17:52:49.2162815 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:49.2162815 Received: 785: TO_FILE_ONLY 17:52:49.2474815 RxStatus:NONE TO_FILE_ONLY 17:52:49.2474815 Received: 785:580AD436E0D419E05292E05394E05506E0D10420521520521020D07320D10920 TO_FILE_ONLY 17:52:49.2474815 Found U1436 DTC in ABS TO_FILE_ONLY 17:52:49.2474815 Found U1419 DTC in ABS TO_FILE_ONLY 17:52:49.2630816 Found C1292 DTC in ABS TO_FILE_ONLY 17:52:49.2630816 Found C1394 DTC in ABS TO_FILE_ONLY 17:52:49.2630816 Found C1506 DTC in ABS TO_FILE_ONLY 17:52:49.2630816 Found U1104 DTC in ABS TO_FILE_ONLY 17:52:49.2630816 Found C1215 DTC in ABS TO_FILE_ONLY 17:52:49.2630816 Found C1210 DTC in ABS TO_FILE_ONLY 17:52:49.2786816 Found U1073 DTC in ABS TO_FILE_ONLY 17:52:49.2786816 Found U1109 DTC in ABS TO_FILE_ONLY 17:52:49.2786816 Send: 784:1081 TO_FILE_ONLY 17:52:49.3410817 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:49.3410817 Received: 785: TO_FILE_ONLY 17:52:49.3722817 RxStatus:NONE TO_FILE_ONLY 17:52:49.3722817 Received: 785:5081 TO_FILE_ONLY 17:52:49.4658819 Send: 7B6:1092 TO_FILE_ONLY 17:52:49.6072822 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:49.7320824 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:49.8568827 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:49.9816829 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:49.9816829 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:52:50.0752830 Send: 622:1092 TO_FILE_ONLY 17:52:50.1376831 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:50.1376831 Received: 484: TO_FILE_ONLY 17:52:50.1688832 RxStatus:NONE TO_FILE_ONLY 17:52:50.1688832 Received: 484:5092 TO_FILE_ONLY 17:52:50.1688832 Send: 622:1A87 TO_FILE_ONLY 17:52:50.2468833 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:50.2468833 Received: 484: TO_FILE_ONLY 17:52:50.3092835 RxStatus:NONE TO_FILE_ONLY 17:52:50.3092835 Received: 484:5A8704668000FF100010000038363531413038342020 TO_FILE_ONLY 17:52:50.3092835 Description: SAS INFO 17:52:50.3092835 Diag version: 32768 INFO 17:52:50.3092835 Supplier: Methode INFO 17:52:50.3092835 -------------- DEFAULT 17:52:50.3404835 Start reading DTCs on SAS TO_FILE_ONLY 17:52:50.3404835 Send: 622:1800FF00 TO_FILE_ONLY 17:52:50.4184836 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:50.4184836 Received: 484: TO_FILE_ONLY 17:52:50.4496837 RxStatus:NONE TO_FILE_ONLY 17:52:50.4496837 Received: 484:5800 TO_FILE_ONLY 17:52:50.4496837 Send: 622:1081 TO_FILE_ONLY 17:52:50.5120838 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:52:50.5120838 Received: 484: TO_FILE_ONLY 17:52:50.5432839 RxStatus:NONE TO_FILE_ONLY 17:52:50.5432839 Received: 484:5081 TO_FILE_ONLY 17:52:50.6378841 Send: 7B5:1092 TO_FILE_ONLY 17:52:50.7938844 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:50.9030845 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:51.0278848 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:51.1526850 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:51.1526850 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:52:51.2462852 Send: 7E1:1092 TO_FILE_ONLY 17:52:51.4022854 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:51.5114856 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:51.6362858 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:51.7610861 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:51.7610861 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:52:51.8546862 Send: 761:1092 TO_FILE_ONLY 17:52:52.0106865 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:52.1198867 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:52.2446869 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:52.3694871 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:52.3694871 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:52:52.4630873 Send: 6A0:1092 TO_FILE_ONLY 17:52:52.6190876 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:52.7594878 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:52.8842880 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:53.0090882 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:53.0090882 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:52:53.1026884 Send: 763:1092 TO_FILE_ONLY 17:52:53.2586887 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:53.3678889 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:53.4926891 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:53.6174893 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:53.6174893 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:52:53.7110895 Send: 688:1092 TO_FILE_ONLY 17:52:53.8680898 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:53.9928900 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:54.1020902 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:54.2268904 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:54.2268904 Receive timeout. Elapsed 484 ms TO_FILE_ONLY 17:52:54.3204906 Send: 616:1092 TO_FILE_ONLY 17:52:54.4764909 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:54.6012911 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:54.7104913 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:54.8352915 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:54.8352915 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:52:54.9288917 Send: 600:1092 TO_FILE_ONLY 17:52:55.0848919 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:55.2096922 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:55.3188924 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:55.4436926 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:55.4436926 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:52:55.5372927 Send: 751:1092 TO_FILE_ONLY 17:52:55.6932930 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:55.8180932 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:55.9584935 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:56.0832937 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:56.0832937 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:52:56.1768939 Send: 6E0:1092 TO_FILE_ONLY 17:52:56.3328941 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:56.4576944 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:56.5668946 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:56.6916948 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:56.6916948 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:52:56.7852949 Send: 73A:1092 TO_FILE_ONLY 17:52:56.9412952 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:57.0660954 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:57.2064957 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:57.3312959 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:57.3312959 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:52:57.4248961 Send: 6B0:1092 TO_FILE_ONLY 17:52:57.5808963 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:57.7056966 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:57.8148967 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:57.9396970 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:57.9396970 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:52:58.0332971 Send: 796:1092 TO_FILE_ONLY 17:52:58.1892974 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:58.3140976 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:58.4544979 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:58.5792981 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:52:58.5792981 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:09.8279179 Send: 7E0:1092 TO_FILE_ONLY 17:53:09.8903180 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:09.8903180 Received: 7E8: TO_FILE_ONLY 17:53:09.9215181 RxStatus:NONE TO_FILE_ONLY 17:53:09.9215181 Received: 7E8:5092 TO_FILE_ONLY 17:53:09.9215181 Send: 7E0:14FF00 TO_FILE_ONLY 17:53:09.9839182 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:09.9839182 Received: 7E8: TO_FILE_ONLY 17:53:10.0151182 RxStatus:NONE TO_FILE_ONLY 17:53:10.0151182 Received: 7E8:54FF00 TO_FILE_ONLY 17:53:10.0151182 Send: 7E0:1081 TO_FILE_ONLY 17:53:10.0775183 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:10.0775183 Received: 7E8: TO_FILE_ONLY 17:53:10.1087184 RxStatus:NONE TO_FILE_ONLY 17:53:10.1087184 Received: 7E8:5081 TO_FILE_ONLY 17:53:10.2023186 Send: 784:1092 TO_FILE_ONLY 17:53:10.2647187 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:10.2647187 Received: 785: TO_FILE_ONLY 17:53:10.2959187 RxStatus:NONE TO_FILE_ONLY 17:53:10.2959187 Received: 785:5092 TO_FILE_ONLY 17:53:10.2959187 Send: 784:14FF00 TO_FILE_ONLY 17:53:10.3583188 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:10.3583188 Received: 785: TO_FILE_ONLY 17:53:10.3905189 RxStatus:NONE TO_FILE_ONLY 17:53:10.3905189 Received: 785:7F1410 TO_FILE_ONLY 17:53:10.3905189 Send: 784:1081 TO_FILE_ONLY 17:53:10.4685191 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:10.4685191 Received: 785: TO_FILE_ONLY 17:53:10.4997191 RxStatus:NONE TO_FILE_ONLY 17:53:10.4997191 Received: 785:5081 TO_FILE_ONLY 17:53:10.6401194 Send: 620:1092 TO_FILE_ONLY 17:53:10.7961197 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:10.9209199 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:11.0457201 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:11.1549203 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:11.1549203 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:53:11.2485205 Send: 786:1092 TO_FILE_ONLY 17:53:11.4045207 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:11.5293209 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:11.6541212 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:11.7633214 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:11.7633214 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:53:11.8569215 Send: 7E0:1092 TO_FILE_ONLY 17:53:11.9193216 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:11.9193216 Received: 7E8: TO_FILE_ONLY 17:53:11.9505217 RxStatus:NONE TO_FILE_ONLY 17:53:11.9505217 Received: 7E8:5092 TO_FILE_ONLY 17:53:11.9505217 Send: 7E0:1A87 TO_FILE_ONLY 17:53:12.0129218 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:12.0129218 Received: 7E8: TO_FILE_ONLY 17:53:12.0441218 RxStatus:NONE TO_FILE_ONLY 17:53:12.0441218 Received: 7E8:5A8704250006FF303011230031383630423039392020 TO_FILE_ONLY 17:53:12.0441218 Description: Engine INFO 17:53:12.0441218 Diag version: 6 INFO 17:53:12.0441218 Supplier: DENSO INFO 17:53:12.0441218 -------------- DEFAULT 17:53:12.0753219 Start reading DTCs on Engine TO_FILE_ONLY 17:53:12.0753219 Send: 7E0:1800FF00 TO_FILE_ONLY 17:53:12.1533220 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:12.1533220 Received: 7E8: TO_FILE_ONLY 17:53:12.1845221 RxStatus:NONE TO_FILE_ONLY 17:53:12.1845221 Received: 7E8:5801D10160 TO_FILE_ONLY 17:53:12.2001221 Found U1101 DTC in Engine TO_FILE_ONLY 17:53:12.2001221 Send: 7E0:1081 TO_FILE_ONLY 17:53:12.2625222 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:12.2625222 Received: 7E8: TO_FILE_ONLY 17:53:12.2937223 RxStatus:NONE TO_FILE_ONLY 17:53:12.2937223 Received: 7E8:5081 TO_FILE_ONLY 17:53:12.4029225 Send: 77B:1092 TO_FILE_ONLY 17:53:12.5589228 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:12.6837230 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:12.8085232 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:12.9333234 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:12.9333234 Receive timeout. Elapsed 499 ms TO_FILE_ONLY 17:53:13.0425236 Send: 784:1092 TO_FILE_ONLY 17:53:13.1059238 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:13.1059238 Received: 785: TO_FILE_ONLY 17:53:13.1371238 RxStatus:NONE TO_FILE_ONLY 17:53:13.1371238 Received: 785:5092 TO_FILE_ONLY 17:53:13.1371238 Send: 784:1A87 TO_FILE_ONLY 17:53:13.1995239 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:13.1995239 Received: 785: TO_FILE_ONLY 17:53:13.2307240 RxStatus:NONE TO_FILE_ONLY 17:53:13.2307240 Received: 785:5A8704630003FF001030363134363730413338352020 TO_FILE_ONLY 17:53:13.2307240 Description: ABS INFO 17:53:13.2307240 Diag version: 3 INFO 17:53:13.2307240 Supplier: ADVICS INFO 17:53:13.2307240 -------------- DEFAULT 17:53:13.2931241 Start reading DTCs on ABS TO_FILE_ONLY 17:53:13.2931241 Send: 784:1800FF00 TO_FILE_ONLY 17:53:13.3555242 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:13.3555242 Received: 785: TO_FILE_ONLY 17:53:13.4023243 RxStatus:NONE TO_FILE_ONLY 17:53:13.4023243 Received: 785:580AD436E0D419E05292E05394E05506E0D10420521520521020D07320D10920 TO_FILE_ONLY 17:53:13.4023243 Found U1436 DTC in ABS TO_FILE_ONLY 17:53:13.4023243 Found U1419 DTC in ABS TO_FILE_ONLY 17:53:13.4179243 Found C1292 DTC in ABS TO_FILE_ONLY 17:53:13.4179243 Found C1394 DTC in ABS TO_FILE_ONLY 17:53:13.4179243 Found C1506 DTC in ABS TO_FILE_ONLY 17:53:13.4179243 Found U1104 DTC in ABS TO_FILE_ONLY 17:53:13.4179243 Found C1215 DTC in ABS TO_FILE_ONLY 17:53:13.4179243 Found C1210 DTC in ABS TO_FILE_ONLY 17:53:13.4335243 Found U1073 DTC in ABS TO_FILE_ONLY 17:53:13.4335243 Found U1109 DTC in ABS TO_FILE_ONLY 17:53:13.4335243 Send: 784:1081 TO_FILE_ONLY 17:53:13.4959245 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:13.4959245 Received: 785: TO_FILE_ONLY 17:53:13.5271245 RxStatus:NONE TO_FILE_ONLY 17:53:13.5271245 Received: 785:5081 TO_FILE_ONLY 17:53:13.6207247 Send: 7B6:1092 TO_FILE_ONLY 17:53:13.7923250 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:13.9171252 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:14.0419254 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:14.1667256 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:14.1667256 Receive timeout. Elapsed 499 ms TO_FILE_ONLY 17:53:14.2759258 Send: 622:1092 TO_FILE_ONLY 17:53:14.3383259 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:14.3383259 Received: 484: TO_FILE_ONLY 17:53:14.3695260 RxStatus:NONE TO_FILE_ONLY 17:53:14.3695260 Received: 484:5092 TO_FILE_ONLY 17:53:14.3695260 Send: 622:1A87 TO_FILE_ONLY 17:53:14.4319261 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:14.4319261 Received: 484: TO_FILE_ONLY 17:53:14.4943262 RxStatus:NONE TO_FILE_ONLY 17:53:14.4943262 Received: 484:5A8704668000FF100010000038363531413038342020 TO_FILE_ONLY 17:53:14.4943262 Description: SAS INFO 17:53:14.4943262 Diag version: 32768 INFO 17:53:14.4943262 Supplier: Methode INFO 17:53:14.4943262 -------------- DEFAULT 17:53:14.5255263 Start reading DTCs on SAS TO_FILE_ONLY 17:53:14.5255263 Send: 622:1800FF00 TO_FILE_ONLY 17:53:14.6035264 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:14.6035264 Received: 484: TO_FILE_ONLY 17:53:14.6347265 RxStatus:NONE TO_FILE_ONLY 17:53:14.6347265 Received: 484:5800 TO_FILE_ONLY 17:53:14.6347265 Send: 622:1081 TO_FILE_ONLY 17:53:14.6971266 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:14.6971266 Received: 484: TO_FILE_ONLY 17:53:14.7283266 RxStatus:NONE TO_FILE_ONLY 17:53:14.7283266 Received: 484:5081 TO_FILE_ONLY 17:53:14.8219268 Send: 7B5:1092 TO_FILE_ONLY 17:53:14.9623270 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:15.0871272 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:15.2119275 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:15.3367277 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:15.3367277 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:53:15.4303279 Send: 7E1:1092 TO_FILE_ONLY 17:53:15.5707281 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:15.6955283 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:15.8203285 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:15.9451288 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:15.9451288 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:53:16.0387289 Send: 761:1092 TO_FILE_ONLY 17:53:16.2103292 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:16.3351294 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:16.4599297 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:16.5847299 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:16.5847299 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:16.6783300 Send: 6A0:1092 TO_FILE_ONLY 17:53:16.8187303 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:16.9435305 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:17.0683307 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:17.1931309 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:17.1931309 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:53:17.2867311 Send: 763:1092 TO_FILE_ONLY 17:53:17.4583314 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:17.5831316 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:17.7079319 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:17.8327321 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:17.8327321 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:17.9263322 Send: 688:1092 TO_FILE_ONLY 17:53:18.0667325 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:18.1915327 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:18.3163329 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:18.4411331 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:18.4411331 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:53:18.5347333 Send: 616:1092 TO_FILE_ONLY 17:53:18.7063336 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:18.8311338 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:18.9559340 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:19.0807343 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:19.0807343 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:19.1743344 Send: 600:1092 TO_FILE_ONLY 17:53:19.3147347 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:19.4395349 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:19.5643351 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:19.6891353 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:19.6891353 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:53:19.7827355 Send: 751:1092 TO_FILE_ONLY 17:53:19.9543358 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:20.0791360 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:20.2039362 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:20.3287365 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:20.3287365 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:20.4233367 Send: 6E0:1092 TO_FILE_ONLY 17:53:20.5949370 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:20.7197372 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:20.8445374 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:20.9693376 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:20.9693376 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:21.0629378 Send: 73A:1092 TO_FILE_ONLY 17:53:21.2345381 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:21.3749383 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:21.5037388 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:21.5037388 Receive timeout. Elapsed 409 ms TO_FILE_ONLY 17:53:21.5973390 Send: 6B0:1092 TO_FILE_ONLY 17:53:21.7533392 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:21.8781395 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:22.0039397 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:22.1131399 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:22.1131399 Receive timeout. Elapsed 484 ms TO_FILE_ONLY 17:53:22.2011406 Send: 796:1092 TO_FILE_ONLY 17:53:22.3651414 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:22.4899416 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:22.6147418 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:22.7217436 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:22.7217436 Receive timeout. Elapsed 489 ms TO_FILE_ONLY 17:53:27.9779571 Send: 7E0:1092 TO_FILE_ONLY 17:53:28.0403572 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:28.0403572 Received: 7E8: TO_FILE_ONLY 17:53:28.0715573 RxStatus:NONE TO_FILE_ONLY 17:53:28.0715573 Received: 7E8:5092 TO_FILE_ONLY 17:53:28.0715573 Send: 7E0:14FF00 TO_FILE_ONLY 17:53:28.1339574 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:28.1339574 Received: 7E8: TO_FILE_ONLY 17:53:28.1651574 RxStatus:NONE TO_FILE_ONLY 17:53:28.1651574 Received: 7E8:54FF00 TO_FILE_ONLY 17:53:28.1651574 Send: 7E0:1081 TO_FILE_ONLY 17:53:28.2275575 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:28.2275575 Received: 7E8: TO_FILE_ONLY 17:53:28.2587576 RxStatus:NONE TO_FILE_ONLY 17:53:28.2587576 Received: 7E8:5081 TO_FILE_ONLY 17:53:28.3679578 Send: 784:1092 TO_FILE_ONLY 17:53:28.4303579 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:28.4303579 Received: 785: TO_FILE_ONLY 17:53:28.4615579 RxStatus:NONE TO_FILE_ONLY 17:53:28.4615579 Received: 785:5092 TO_FILE_ONLY 17:53:28.4615579 Send: 784:14FF00 TO_FILE_ONLY 17:53:28.5239581 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:28.5239581 Received: 785: TO_FILE_ONLY 17:53:28.5551581 RxStatus:NONE TO_FILE_ONLY 17:53:28.5551581 Received: 785:7F1410 TO_FILE_ONLY 17:53:28.5551581 Send: 784:1081 TO_FILE_ONLY 17:53:28.6175582 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:28.6175582 Received: 785: TO_FILE_ONLY 17:53:28.6487583 RxStatus:NONE TO_FILE_ONLY 17:53:28.6487583 Received: 785:5081 TO_FILE_ONLY 17:53:28.7891585 Send: 620:1092 TO_FILE_ONLY 17:53:28.9607588 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:29.0855590 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:29.2103593 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:29.3351595 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:29.3351595 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:29.4287596 Send: 786:1092 TO_FILE_ONLY 17:53:29.6003599 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:29.7251602 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:29.8499604 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:29.9747606 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:29.9747606 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:30.0683608 Send: 7E0:1092 TO_FILE_ONLY 17:53:30.1307609 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:30.1307609 Received: 7E8: TO_FILE_ONLY 17:53:30.1619609 RxStatus:NONE TO_FILE_ONLY 17:53:30.1619609 Received: 7E8:5092 TO_FILE_ONLY 17:53:30.1619609 Send: 7E0:1A87 TO_FILE_ONLY 17:53:30.2399611 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:30.2399611 Received: 7E8: TO_FILE_ONLY 17:53:30.2711611 RxStatus:NONE TO_FILE_ONLY 17:53:30.2711611 Received: 7E8:5A8704250006FF303011230031383630423039392020 TO_FILE_ONLY 17:53:30.2711611 Description: Engine INFO 17:53:30.2711611 Diag version: 6 INFO 17:53:30.2711611 Supplier: DENSO INFO 17:53:30.2711611 -------------- DEFAULT 17:53:30.3023612 Start reading DTCs on Engine TO_FILE_ONLY 17:53:30.3023612 Send: 7E0:1800FF00 TO_FILE_ONLY 17:53:30.3803613 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:30.3803613 Received: 7E8: TO_FILE_ONLY 17:53:30.4115614 RxStatus:NONE TO_FILE_ONLY 17:53:30.4115614 Received: 7E8:5801D10160 TO_FILE_ONLY 17:53:30.4115614 Found U1101 DTC in Engine TO_FILE_ONLY 17:53:30.4115614 Send: 7E0:1081 TO_FILE_ONLY 17:53:30.4895615 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:30.4895615 Received: 7E8: TO_FILE_ONLY 17:53:30.5207616 RxStatus:NONE TO_FILE_ONLY 17:53:30.5207616 Received: 7E8:5081 TO_FILE_ONLY 17:53:30.6143617 Send: 77B:1092 TO_FILE_ONLY 17:53:30.7703620 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:30.8795622 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:31.0043624 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:31.1291626 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:31.1291626 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:53:31.2383628 Send: 784:1092 TO_FILE_ONLY 17:53:31.3007629 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:31.3007629 Received: 785: TO_FILE_ONLY 17:53:31.3319630 RxStatus:NONE TO_FILE_ONLY 17:53:31.3319630 Received: 785:5092 TO_FILE_ONLY 17:53:31.3319630 Send: 784:1A87 TO_FILE_ONLY 17:53:31.3943631 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:31.3943631 Received: 785: TO_FILE_ONLY 17:53:31.4255632 RxStatus:NONE TO_FILE_ONLY 17:53:31.4411632 Received: 785:5A8704630003FF001030363134363730413338352020 TO_FILE_ONLY 17:53:31.4411632 Description: ABS INFO 17:53:31.4411632 Diag version: 3 INFO 17:53:31.4411632 Supplier: ADVICS INFO 17:53:31.4411632 -------------- DEFAULT 17:53:31.4723632 Start reading DTCs on ABS TO_FILE_ONLY 17:53:31.4723632 Send: 784:1800FF00 TO_FILE_ONLY 17:53:31.5503634 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:31.5503634 Received: 785: TO_FILE_ONLY 17:53:31.5971635 RxStatus:NONE TO_FILE_ONLY 17:53:31.5971635 Received: 785:580AD436E0D419E05292E05394E05506E0D10420521520521020D07320D10920 TO_FILE_ONLY 17:53:31.5971635 Found U1436 DTC in ABS TO_FILE_ONLY 17:53:31.5971635 Found U1419 DTC in ABS TO_FILE_ONLY 17:53:31.5971635 Found C1292 DTC in ABS TO_FILE_ONLY 17:53:31.5971635 Found C1394 DTC in ABS TO_FILE_ONLY 17:53:31.6127635 Found C1506 DTC in ABS TO_FILE_ONLY 17:53:31.6127635 Found U1104 DTC in ABS TO_FILE_ONLY 17:53:31.6127635 Found C1215 DTC in ABS TO_FILE_ONLY 17:53:31.6127635 Found C1210 DTC in ABS TO_FILE_ONLY 17:53:31.6127635 Found U1073 DTC in ABS TO_FILE_ONLY 17:53:31.6127635 Found U1109 DTC in ABS TO_FILE_ONLY 17:53:31.6283635 Send: 784:1081 TO_FILE_ONLY 17:53:31.6907636 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:31.6907636 Received: 785: TO_FILE_ONLY 17:53:31.7219637 RxStatus:NONE TO_FILE_ONLY 17:53:31.7219637 Received: 785:5081 TO_FILE_ONLY 17:53:31.8155638 Send: 7B6:1092 TO_FILE_ONLY 17:53:31.9715641 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:32.0807643 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:32.2055645 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:32.3303647 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:32.3303647 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:53:32.4239649 Send: 622:1092 TO_FILE_ONLY 17:53:32.4863650 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:32.4863650 Received: 484: TO_FILE_ONLY 17:53:32.5175651 RxStatus:NONE TO_FILE_ONLY 17:53:32.5175651 Received: 484:5092 TO_FILE_ONLY 17:53:32.5175651 Send: 622:1A87 TO_FILE_ONLY 17:53:32.5799652 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:32.5799652 Received: 484: TO_FILE_ONLY 17:53:32.6423653 RxStatus:NONE TO_FILE_ONLY 17:53:32.6423653 Received: 484:5A8704668000FF100010000038363531413038342020 TO_FILE_ONLY 17:53:32.6423653 Description: SAS INFO 17:53:32.6423653 Diag version: 32768 INFO 17:53:32.6423653 Supplier: Methode INFO 17:53:32.6423653 -------------- DEFAULT 17:53:32.6891654 Start reading DTCs on SAS TO_FILE_ONLY 17:53:32.6891654 Send: 622:1800FF00 TO_FILE_ONLY 17:53:32.7681656 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:32.7681656 Received: 484: TO_FILE_ONLY 17:53:32.7993656 RxStatus:NONE TO_FILE_ONLY 17:53:32.7993656 Received: 484:5800 TO_FILE_ONLY 17:53:32.7993656 Send: 622:1081 TO_FILE_ONLY 17:53:32.8617657 RxStatus:START_OF_MESSAGE TO_FILE_ONLY 17:53:32.8617657 Received: 484: TO_FILE_ONLY 17:53:32.8929658 RxStatus:NONE TO_FILE_ONLY 17:53:32.8929658 Received: 484:5081 TO_FILE_ONLY 17:53:32.9865659 Send: 7B5:1092 TO_FILE_ONLY 17:53:33.1425662 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:33.2673664 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:33.4077667 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:33.5325669 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:33.5325669 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:33.6261671 Send: 7E1:1092 TO_FILE_ONLY 17:53:33.7861676 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:33.9109678 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:34.0357680 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:34.1761683 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:34.1761683 Receive timeout. Elapsed 518 ms TO_FILE_ONLY 17:53:34.2697684 Send: 761:1092 TO_FILE_ONLY 17:53:34.4257687 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:34.5505689 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:34.6753691 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:34.8157694 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:34.8157694 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:34.9093695 Send: 6A0:1092 TO_FILE_ONLY 17:53:35.0653698 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:35.1901700 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:35.3149703 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:35.4553705 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:35.4553705 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:35.5489707 Send: 763:1092 TO_FILE_ONLY 17:53:35.7049709 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:35.8297712 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:35.9545714 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:36.0637716 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:36.0637716 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:53:36.1573717 Send: 688:1092 TO_FILE_ONLY 17:53:36.3133720 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:36.4381722 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:36.5629725 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:36.7033727 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:36.7033727 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:36.7969729 Send: 616:1092 TO_FILE_ONLY 17:53:36.9529731 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:37.0777734 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:37.2025736 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:37.3117738 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:37.3117738 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:53:37.4053739 Send: 600:1092 TO_FILE_ONLY 17:53:37.5613742 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:37.6861744 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:37.8109746 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:37.9357749 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:37.9357749 Receive timeout. Elapsed 499 ms TO_FILE_ONLY 17:53:38.0449751 Send: 751:1092 TO_FILE_ONLY 17:53:38.2009753 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:38.3257755 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:38.4505758 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:38.5909760 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:38.5909760 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:38.6845762 Send: 6E0:1092 TO_FILE_ONLY 17:53:38.8405765 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:38.9653767 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:39.0901769 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:39.2305771 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:39.2305771 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:39.3241773 Send: 73A:1092 TO_FILE_ONLY 17:53:39.4801776 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:39.6049778 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:39.7297780 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:39.8389782 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:39.8389782 Receive timeout. Elapsed 483 ms TO_FILE_ONLY 17:53:39.9325784 Send: 6B0:1092 TO_FILE_ONLY 17:53:40.0885786 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:40.2133789 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:40.3381791 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:40.4785793 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:40.4785793 Receive timeout. Elapsed 514 ms TO_FILE_ONLY 17:53:40.5721795 Send: 796:1092 TO_FILE_ONLY 17:53:40.7281798 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 17:53:40.8529800 PassThruReadMsgs: ERR_TIMEOUT TO_FILE_ONLY 1 Lenke til kommentar
Ciaran og Ciara ( Cassidy Tvillingene ) Skrevet 18. desember 2024 Del Skrevet 18. desember 2024 Maskinfører skrev (5 timer siden): Ja vi også ❤️ ❤️ Vi ønsker dere en godonsdag.♥️♥️ 1 Lenke til kommentar
Maskinfører Skrevet 19. desember 2024 Forfatter Del Skrevet 19. desember 2024 Ciaran og Ciara ( Cassidy Tvillingene ) skrev (14 timer siden): Vi ønsker dere en godonsdag.♥️♥️ Godonsdag ❤️ ❤️ 1 Lenke til kommentar
Ciaran og Ciara ( Cassidy Tvillingene ) Skrevet 19. desember 2024 Del Skrevet 19. desember 2024 Maskinfører skrev (57 minutter siden): Godonsdag ❤️ ❤️ Tusen Takk, vi tenker på dere.♥️♥️ 1 Lenke til kommentar
Maskinfører Skrevet 19. desember 2024 Forfatter Del Skrevet 19. desember 2024 Ciaran og Ciara ( Cassidy Tvillingene ) skrev (5 timer siden): Tusen Takk, vi tenker på dere.♥️♥️ Vi tenker på dere også ❤️ ❤️ Lenke til kommentar
Ciaran og Ciara ( Cassidy Tvillingene ) Skrevet 19. desember 2024 Del Skrevet 19. desember 2024 Maskinfører skrev (52 minutter siden): Vi tenker på dere også ❤️ ❤️ Vi tenker alltid på våre venner.♥️♥️ 1 Lenke til kommentar
Maskinfører Skrevet 19. desember 2024 Forfatter Del Skrevet 19. desember 2024 Ciaran og Ciara ( Cassidy Tvillingene ) skrev (2 timer siden): Vi tenker alltid på våre venner.♥️♥️ Ja det gjør vi også ❤️ ❤️ 1 Lenke til kommentar
Ciaran og Ciara ( Cassidy Tvillingene ) Skrevet 19. desember 2024 Del Skrevet 19. desember 2024 Maskinfører skrev (7 timer siden): Ja det gjør vi også ❤️ ❤️ Vi ønsker dere en godtorsdagskveld.♥️♥️ 2 Lenke til kommentar
Delvis Skrevet 19. desember 2024 Del Skrevet 19. desember 2024 God tordags-kveld ja. Torsdag er min favorrittdag. Så vet dere det ogå 🙂 1 Lenke til kommentar
Ciaran og Ciara ( Cassidy Tvillingene ) Skrevet 19. desember 2024 Del Skrevet 19. desember 2024 Delvis skrev (1 minutt siden): God tordags-kveld ja. Torsdag er min favorrittdag. Så vet dere det ogå 🙂 Vi liker også torsdager, for torsdag er Fish and Chips dagen vår.🐟🐟🍟🍟😋😋og vi ønsker deg også en godtorsdagskveld videre vår gode venn @Delvis😊😊🥰🥰 1 Lenke til kommentar
Delvis Skrevet 19. desember 2024 Del Skrevet 19. desember 2024 Ciaran og Ciara ( Cassidy Tvillingene ) skrev (58 minutter siden): Vi liker også torsdager, for torsdag er Fish and Chips dagen vår.🐟🐟🍟🍟😋😋og vi ønsker deg også en godtorsdagskveld videre vår gode venn @Delvis😊😊🥰🥰 Takk det er fint å vite at dere er mine gode venner 🙂Fish and chips liker jeg også 👍 1 Lenke til kommentar
Ciaran og Ciara ( Cassidy Tvillingene ) Skrevet 20. desember 2024 Del Skrevet 20. desember 2024 Delvis skrev (39 minutter siden): Takk det er fint å vite at dere er mine gode venner 🙂Fish and chips liker jeg også 👍 Ja det er kjempegodt.😋😋og vi synes også at det er godt å vite at du er vår venn.♥️♥️ 1 Lenke til kommentar
Maskinfører Skrevet 20. desember 2024 Forfatter Del Skrevet 20. desember 2024 Ciaran og Ciara ( Cassidy Tvillingene ) skrev (15 timer siden): Vi ønsker dere en godtorsdagskveld.♥️♥️ Godfredag ❤️ ❤️ 1 Lenke til kommentar
Ciaran og Ciara ( Cassidy Tvillingene ) Skrevet 20. desember 2024 Del Skrevet 20. desember 2024 Maskinfører skrev (1 time siden): Godfredag ❤️ ❤️ Tusen Takk, vi tenker på dere.♥️♥️ 1 Lenke til kommentar
Maskinfører Skrevet 20. desember 2024 Forfatter Del Skrevet 20. desember 2024 Ciaran og Ciara ( Cassidy Tvillingene ) skrev (1 time siden): Tusen Takk, vi tenker på dere.♥️♥️ Vi tenker på dere også ❤️ ❤️ 1 Lenke til kommentar
Ciaran og Ciara ( Cassidy Tvillingene ) Skrevet 20. desember 2024 Del Skrevet 20. desember 2024 Maskinfører skrev (5 timer siden): Vi tenker på dere også ❤️ ❤️ Tusen Takk, vi tenker alltid på våre venner.♥️♥️ 1 Lenke til kommentar
Maskinfører Skrevet 20. desember 2024 Forfatter Del Skrevet 20. desember 2024 Ciaran og Ciara ( Cassidy Tvillingene ) skrev (2 timer siden): Tusen Takk, vi tenker alltid på våre venner.♥️♥️ Ja det er det ❤️❤️ Lenke til kommentar
Ciaran og Ciara ( Cassidy Tvillingene ) Skrevet 20. desember 2024 Del Skrevet 20. desember 2024 Maskinfører skrev (5 minutter siden): Ja det er det ❤️❤️ Det er vi glade for å høre.♥️♥️ 1 Lenke til kommentar
